    SketchUp 2016 Wishlist
    192 Posts 69 Posters 108.4k Views 69 Watching
    • FrederikF
      Frederik
      @box said:
      You need to be a bit careful saying that, Kim.
      Many people assume that 64 will fix all their graphic issues, but if your card isn't up to it it won't totally solve the problem.
      As you can see below , this is 64bit 2015, but on a steam driven laptop, and all the little columns in the balustrade and light fittings switch to wireframe when moving.
      I see, Box...
      It's just that IMPO it's now much more rare that I see these wireframes, when moving, so I believe that there's been a great improvement in this area already...
      Cheers
      Kim Frederik
      • BoxB
        True Kim and I'm sure there is a huge improvement. I don't expect this laptop to manage much better as I know it's graphics card is pretty basic. But thought it worth noting because people will complain when 64bit doesn't seem to make that much difference on their system.
        • oceanembersO
          oceanembers
          So since layout got a little discreet love with 2015, in the form of dynamic reporting, I'm getting quite interested in the ultimate possibilities it holds. So Imma put down my wish for layout plugin support, plus an API.
          • pbacotP
            I wish there was a date stamp that updates automatically. So many things missing in LO that make drawing production easier in CAD. This is only a small one, but saves headaches.
            • N
              numerobis
              @frederik said:
              Can you elaborate on the "Multicore support"...?
              I understand what multicore is, but unless you're talking about SU native render, what purpose would/should it serve...?
              To improve the overall sketchup performance? If you compare the single thread performance of the processors of the last years, there has been not much improvement. The last bigger jump in IPC was from Nehalem/Westmere to Sandy Bridge with maybe 15-20%. Incl. the higher possible frequency a bit more - if you overclock. But the real progress is done on the core count - we are now at 14 cores @3,5GHz and up to 18 with slower clocks.
              I'm aware that it is not an easy task to make a modeling program multithreaded and maybe there are many operations where it is impossible today. But when i look at the current and coming processors i think it is how it has to work now and that it is the only way to get more performance in the future if you look at the IPC improvements of the last two generations.
              And i think there are things that could be "easily" done using multiple cores, like exporting images (as you mentioned), background saving or if it is only opening the components window with a few thousand entries. But i think also exploding should be possible, maybe more complex ruby scripts, maybe shadow calculation, everything that can be split up in several parts for processing...
              @frederik said:
              As for the high poly support...
              Please take one of your heavy models and give it a test with SU2015 64-bit, I'm sure you'll notice that it's behaving much better now...
              I'm quite sure you can agree that the model no longer change to wireframe when orbiting or panning...
              I'll also claim that there is a much faster execution of ruby scripts...
              I'm curious about it - i will try it.
              @kaas said:
              Have you tried disabling 'redefine thumbnail on save' in Model Info - File? Should make it save instantly (on an SSD).
              i think i tried that already but i'll test it again. Thanks!
              • Chris FullmerC
                Hi Peter, Layout does have Auto-Text tags that have a current date stamp, which always shows the current date. Is that not quite the feature you need?
                Just insert this <CurrentDate> tag into any text.
                • KrisidiousK
                  Krisidious
                  Yes... I would love Layout to have Ruby. Never understood why Layout was such a separate program and had no developer support. We had all the drawing and text tools in SU. I always wondered why Layout wasn't actual inside of or part of SU.
                  By: Kristoff Rand
                  • pbacotP
                    Nice. I looked around for command. Where are these tags?
                    • N
                      numerobis
                      Comparing my wishlist for 2013, 2014, 2015...
                      • importing improvements (maybe this is improved with new face finder)
                      • Quads
                      • sub-D modeling
                      • better texturing tools
                      • 64bit ๐Ÿ‘
                      • multicore support (yes, this is the way processors evolve now - since a few years)
                      • high poly support
                      • faster ruby script execution (it's just a joke, that you have to watch a counter when you round some edges, where another app can do this instantly...)
                      • faster saving/auto-saving (!)
                      • faster explode or copy/paste (i have to test 2015...)
                      • disable/configure snapping
                      I add to my list:
                      • less wasted space around the icons, like it was up to v8. I can't find it to be better readable, it just looks worse and i have less space.
                      • a PhotoMatch window that has the same width as the other windows (layers/info etc.) so that they don't get wider when you dock it ...like it was in v8. I don't see any reason why this window has to be bigger now, same content. Just wasted space, again.
                      and... since this is a wish list (i don't really think this will ever happen): non destructive and parametrical modeling using a modifier stack or node graphs. But maybe we'll see a ruby ๐Ÿ˜‰
                      • KrisidiousK
                        Krisidious
                        You just put that code in Text pbscot.
                        By: Kristoff Rand
                        • L
                          Lushi
                          The option to move objects without sticking together, as in AutoCAD, where the "Move" tool to differentiate the "stretch", and thus without a little more "groups" that accumulate in our models .
                          A "mirror" internal tool in the program, that way it would avoid problems with external tools, and the quality of it would improve, for example, to differentiate a "2d mirror" to "3d mirror", showing in real time where would the reflected object, the option of inverted symmetry (rotating on two axes), or copied to a "group" to prevent sticking.
                          ย
                          the possibility to enable or disable the snap, in ALL the tools
                          angular Dimensions
                          A "splice" internal tool
                          A soft line to create surfaces, but it does not hide
                          a 'ellipse' internal tool (also arcs of ellipse)
                          divide the screen into four: Top, front, right, projection (default)
                          Tool "Clone" in matrix, row, rotate, And scale
                          A "Align" internal tool
                          Export a blueprint of the current view to a 2d dwg file with Their model layers
                          View from below
                          That the sun is visible in the sky, giving us a better idea of โ€‹โ€‹where he is located
                          Improve the follow me tool
                          uv mapping
                          Button groups such as layout or bar "first steps"
                          Layout attached to sketchup (no sense having them in separate programs)
                          Launcher with recent files, templates, recovered files, and models uploaded by the community
                          Inscribed and circumscribed polygons
                          Groups of scenes to higher order and open them to more easily
                          improve tool "freehand" to deactivate the snap and lock to a 2D plane
                          achieve world peace
                          Reliving the dinosaurs
                          Get me a cup of tea
                          We could start there ๐Ÿ˜‰
                          • JQLJ
                            JQL
                            @rich o brien said:
                            or at least offload that presentational aspect to StyleBuilder.
                            Which is still the same since its inception.
                            Though I wouldn't like that, I understand it would be a good feature.
                            You can do that already if you simply Xref your model to a new file and manage styles there.
                            BTW Style builder would only be nice if shadows and face colors boundary lines would also twist and bend or if, those areas of color could also have a texture with multiple sizes as lines do right now.
                            www.casca.pt
                            Visit us on facebook!
                            • JQLJ
                              JQL
                              The idea of having more computational efforts on SU for such heavy tasks such as layout's is not easy on me.
                              Besides that I like the fact that:
                              • You can insert multiple SU files in LO;
                              • You can work on a 2D workflow;
                              • You have very high graphical output and, nowadays you go towards making a SU model only model, with all dims, texts, and leaders inside LO.
                              • PDF export is beautiful
                              I don't like the fact that:
                              • All commands are different in LO than they are from SU (we are so used to SU why reinvent the wheel in LO?);
                              • Selecting has no CTRL or CTRL+SHIFT modifier keys;
                              • Drawing commands are less effective;
                              • Lines don't break nor faces get generated, nor can we paint a shape like in SU wich is much better than filling and stroking stuff;
                              • No components, only groups;
                              • Layers are confusing to work with. In SU you CAN'T change active layer, In Layout you MUST change active layer... awkward and opposite workflows.
                              • Drag methodology for moving stuff around is awfull. Move should be "M" or Icon.;
                              • Drag+CTRL for copying is terrible;
                              • Double click for editing viewports is Dangerous as double clicking is also used to edit objects wich are always on top of viewports...
                              • Scale? SU is better;
                              • Rotate? SU is better;
                              • Inference? SU is WAY better;
                              • That dongle for inference, scale and rotate... OMG...
                              • Offset tool... where is it?
                              • Guide Lines?
                              • Ruby?
                              • DWG export is flawed;
                              • Auto text is good but limited;
                              • Auto tags are good but VERY limited.
                              I still love Layout and because of it I ditched CAD... so why am I complaining? Because I work with it a lot!
                              www.casca.pt
                              • KrisidiousK
                                Krisidious
                                agreeeeed.
                                By: Kristoff Rand
                                • FrederikF
                                  Frederik
                                  I agree 110%...
                                  The commands should be the same...
                                  All in all that's a really great list, Joao...! ๐Ÿ‘
                                  Cheers
                                  Kim Frederik
                                  • H
                                    highlander
                                    Material menu:
                                    -when right click on material it's taking so long for the pop-up to show (with lot of materials)
                                    -maybe a button for save/export the material to skm??
                                    -edit function can be a lot better, CMYK, bigger color wheel, maybe layer system with multiple textures
                                    just a tought
                                    sander
                                    Sander Hoogland
                                    SketchUp 2018 pro - Vray
                                    Beeld3d
                                    • oceanembersO
                                      oceanembers
                                      But Sketchup is not Autocad, and besides, the way the move tool functions can actually be used very effectively in the modeling process. Groups and components are there to allow exactly the kind of movement you are talking about.
                                      I do think, however, that entering and exiting of groups and components could be much more streamlined.
                                      • HieruH
                                        Hieru
                                        How about the ability to toggle camera clipping off and on?
                                        www.davidhier.co.uk
                                        • kenK
                                          ken
                                          What I would like to see are more native tools.
                                          Such as:
                                          1. Rotated Box
                                          2. 3 Point Circle and 2 point circle
                                          3. Rotated Circle/Cyclinder
                                          4. More guide lines tools
                                          5. Entity Info, be able to change the volume to another attribute, such as, weight, i.e (Steel/lbs), (Alum/lbs) etc.
                                          They did a great job with the rotated rectangle.
                                          Ken
                                          • jeff hammondJ
                                            that's a key difference between sketchup and other cad applications.
                                            in rhino, if you draw a line on top of another line, you'll have 2 lines.
                                            in sketchup, if you do the same thing, you'll have 1 line.
                                            both have advantages and i can't really say one way is better than the other.. you just have to have a slightly different mindset/approach in each program.
                                            i'm willing to bet this difference will remain for the life of the software(s).
                                            1. 3 Point Circle and 2 point circle
                                            i'd be curious to see how a 3pt circle would be implemented in sketchup..
                                            ultimately, if you're drawing a (segmented) circle using 3 points, you'd expect each point to coincide with a vertex on the circle.. but in most instances, at least one of the vertices of the circle won't fall on one of the points (unless the circle were divided into 3 separate arc segments each with a different number of segments)..
                                            anyway, it could get confusing i imagine.
                                            • 2 / 10
