    Conservatory
    32 Posts 18 Posters 4.6k Views 18 Watching
      Another wow, anything else would be superfluous.
      • massimoM
        massimo Moderator
        Thanks guys. ๐Ÿ˜„
        @Rich: there are a couple of sockets & switches around (actually I can see one of them), but maybe they are not in view or perhaps the displacement has "eaten" them.
        @Andy: I understand what you mean. The original stone work is a bit different, but has sharp edges. Since I was not able to find exactly the same texture, I made this one which, maybe, requires more smooth edges. Anyway I didn't want a too "rustic" look with too "shapeless" edges so I used displacement on beveled & smoothed surfaces with "normal smoothing" disabled.
        • hellnbakH
          hellnbak
          Incredible work, incredible talent!
          • massimoM
            massimo Moderator
            You are very kind. Thank you. ๐Ÿ˜„
              @Massimo
              even with the absence of electric the quality of the image is still shockingly good!
              You have a very beautiful home ๐Ÿ˜‰
              • Bryan KB
                ๐Ÿ˜ฎ
                • hellnbakH
                  hellnbak
                  Wouldn't work for me -- I throw stones ๐Ÿ˜ž
                  • massimoM
                    massimo Moderator
                    Eh, I would really like a home like that.
                    The big problem would be that I would not know where to put the tons of books and records I have.
                    • DanielD
                      Daniel
                      You're messing with us, right? Those are really photos of an actual building, aren't they?
                      My avatar is an anachronism.
                      • massimoM
                        massimo Moderator
                        Thank you Daniel. ๐Ÿ˜„
                        • BoxB
                          @rich o brien said:
                          Wow....
                          [sockets?]
                          Simply stunning by the way.
                          • massimoM
                            massimo Moderator
                            Well done, you found it! ๐Ÿ˜„
                            • ken28875K
                              ken28875
                              Wow, I thought these were pictures. Amazing, some of the best photo-realistic renders I have seen in this forum. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                              Best glass rendering, too. ๐Ÿ‘ ๐Ÿ‘
                              How did you do the rain drops on the glass roof, Massimo, if you don't mind my asking?
                              Cheers!
                              _KN
                              Follow Your Dreams.
                              • massimoM
                                massimo Moderator
                                Thanks for the kind words Ken.
                                The glass panels have 8 mm of thickness, are beveled and have a thin glass material applied on them with a very light bump (an enlarged perlin noise procedural) and a slight green-blue tint in the reflection's slot.
                                For the rain drops I textured in SU only the outer faces of the panels of the roofs with a black & white map of the drops and then I've just applied it as a bump map in Thea in the glass material.
                                • ken28875K
                                  ken28875
                                  Great, thanks for the explanation, Massimo.
                                  Best,
                                  _KN
                                  Follow Your Dreams.
                                  • RichardR
                                    Richard
                                    Massimo! Wow mate, that is probably one of the if not THE most difficult looking scenes to render I've ever seen! AND you NAILED IT!!!!!!
                                    INCREDIBLE WORK!!!!!!
                                    BUILTBRAND.COM.AU
                                    • cheddaC
                                      chedda
                                      Looks excellent !
                                      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                      • massimoM
                                        massimo Moderator
                                        Thanks everybody. ๐Ÿ˜„
                                        • leedeeteeL
                                          leedeetee
                                          Out of this world. Unbelievable. Bravo.
                                          • massimoM
                                            massimo Moderator
                                            Thank you Lee.
