    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Conservatory
    32 Posts 18 Posters 2.7k Views 18 Watching
      Wow....
      [sockets?]
      • andybotA Offline
        andybot
        very beautiful renders and model! I love how you made the glass enclosed spaces have some real life to them. My only crit is the stone, those sharp edges at some of the geometry are harsh. (actually, just some of the vertical edges, nice job rounding the sills, the edges of the horizontal planes are great.)
        • cottyC Offline
          cotty
          Impressive project!
          my SketchUp gallery
          • FrederikF Offline
            Frederik
            Awesome... Absolutely AWESOME...!! ๐Ÿ‘
            Cheers
            Kim Frederik
              Another wow, anything else would be superfluous.
              • massimoM Offline
                massimo Moderator
                Thanks guys. ๐Ÿ˜„
                @Rich: there are a couple of sockets & switches around (actually I can see one of them), but maybe they are not in view or perhaps the displacement has "eaten" them.
                @Andy: I understand what you mean. The original stone work is a bit different, but has sharp edges. Since I was not able to find exactly the same texture, I made this one which, maybe, requires more smooth edges. Anyway I didn't want a too "rustic" look with too "shapeless" edges so I used displacement on beveled & smoothed surfaces with "normal smoothing" disabled.
                • hellnbakH Offline
                  hellnbak
                  Incredible work, incredible talent!
                  • massimoM Offline
                    massimo Moderator
                    You are very kind. Thank you. ๐Ÿ˜„
                      @Massimo
                      even with the absence of electric the quality of the image is still shockingly good!
                      You have a very beautiful home ๐Ÿ˜‰
                      • Bryan KB Offline
                        ๐Ÿ˜ฎ
                        • hellnbakH Offline
                          hellnbak
                          Wouldn't work for me -- I throw stones ๐Ÿ˜ž
                          • massimoM Offline
                            massimo Moderator
                            Eh, I would really like a home like that.
                            The big problem would be that I would not know where to put the tons of books and records I have.
                            • DanielD Offline
                              Daniel
                              You're messing with us, right? Those are really photos of an actual building, aren't they?
                              My avatar is an anachronism.
                              • massimoM Offline
                                massimo Moderator
                                Thank you Daniel. ๐Ÿ˜„
                                • BoxB Offline
                                  @rich o brien said:
                                  Wow....
                                  [sockets?]
                                  Simply stunning by the way.
                                  • massimoM Offline
                                    massimo Moderator
                                    Well done, you found it! ๐Ÿ˜„
                                    • ken28875K Offline
                                      ken28875
                                      Wow, I thought these were pictures. Amazing, some of the best photo-realistic renders I have seen in this forum. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                      Best glass rendering, too. ๐Ÿ‘ ๐Ÿ‘
                                      How did you do the rain drops on the glass roof, Massimo, if you don't mind my asking?
                                      Cheers!
                                      _KN
                                      Follow Your Dreams.
                                      • massimoM Offline
                                        massimo Moderator
                                        Thanks for the kind words Ken.
                                        The glass panels have 8 mm of thickness, are beveled and have a thin glass material applied on them with a very light bump (an enlarged perlin noise procedural) and a slight green-blue tint in the reflection's slot.
                                        For the rain drops I textured in SU only the outer faces of the panels of the roofs with a black & white map of the drops and then I've just applied it as a bump map in Thea in the glass material.
                                        • ken28875K Offline
                                          ken28875
                                          Great, thanks for the explanation, Massimo.
                                          Best,
                                          _KN
                                          Follow Your Dreams.
                                          • RichardR Offline
                                            Richard
                                            Massimo! Wow mate, that is probably one of the if not THE most difficult looking scenes to render I've ever seen! AND you NAILED IT!!!!!!
                                            INCREDIBLE WORK!!!!!!
                                            BUILTBRAND.COM.AU
