    1.5k Posts 478 Posters 4.3m Views 478 Watching
      snapster42
      Roundcorner is a very useful plugin. But I am having some trouble using it for my purpose. I am trying to create a model for 3D printing, and one of the design requirements is that sharp edges should be avoided. Another requirement, however, is that the object must be a "water-tight" solid in the end, and I am having trouble satisfying that with roundcorner. For example, if I try to round the corners on something like this:
      The plugin appears to work, but when I group it, it doesn't become a solid. I use the "solid inspector" plugin to see what's wrong, and it shows me this:
      When I zoom in to this, I can't see any problem:
      Has anyone encountered this type of problem, and found a solution?
      • cottyC
        cotty
        RoundCorner sometimes creates additional faces, in your case there is an internal face created and after you deleted this face, the object will get solid.
        my SketchUp gallery
        • fredo6F
          That's probably the explanation. A face is created between the big and the small cube.
          Actually, RoundCorner does not create the face, it is rather Sketchup that does it automatically (i.e. find_face).
          • F
            filonik
            Я никак не могу найти где скачать сам плагин.
            Не вижу слова СКАЧАТЬ.
            • pbacotP
              @sketchmax said:
              Hello Sketchupers!
              First post here for me ever, I'm currently working as a 3d-modeler for a company in Sweden and I've been on it for soon 2½ months.
              With that said I've tried to learn everything by myself now for 2½ months, so I'm still quite new to sketchup.
              But I finally have come to some struggle and i tried to look around for solutions, but unsuccessful unfortunately.
              My problem is that I got a dome-shaped object which is not entirely domy(Jokes aside) and I need the sloped side to the top to be more round without having to raise the top a few MM just to round the top of that(which also does not change the fact it won't look right).
              I'll insert a picture for better understanding my situation(I hope).
              http://i.imgur.com/kqcLh2j.png
              The reason I post here is because I'm not to familiar with forums and such,
              and for that I use your "Round Corners" ALOT! Kudos to that plugin.
              I'm also sorry if I posted in the wrong forum.
              I hope I didn't make this to complicated for you guys to understand and I thank you in advance.
              //Max
              Welcome Max! You should try starting a new thread under "SketchUp Pro and Make Discussions". Looks like a possible solution would involve creating a better profile for the dome and remaking it, using FollowMe with a circlular path.
                snapster42
                cool, thanks for the tip. I'm fairly new to sketchup; any advice on how I delete this internal face? Do I have to hide some visible faces and then delete the internal one or something?
                • cottyC
                  cotty
                  Посмотрите в первом посте.
                  (You should try to use english here in the forum.)
                  my SketchUp gallery
                  • BoxB
                    жми меня
                    • T
                      tomot
                      I don't know if problem has been resolved. I looked at the .rb files but can't a revision date. 😞
                      see attached pic.
                      my plugins
                      tomot
                      • fredo6F
                        Tomot,
                        What do you mean by inconsistent highlight?
                        How should the corner and roundings be to be OK?
                        • P
                          Pherim
                          SU2015 64bit sometimes crashes immediately after I use roundcorner... I have the newest version and I installed it with the Plugin store tool, it also works perfectly in SU2013.
                          edit: it only seems to happen on geometry that already existed in a model I took over from SU2013, but if I create new objects it works on them... strange.
                          edit2: no, I was wrong, it always crashes on geometry inside Components! It may be that another plugin is responsible for this that I haven't installed in 2013, need further investigating.
                          edit3: Alright, it's not SU2015! Apparently Components Manager causes the crashes. I didn't have that installed before, so it was one of the most probable suspects for this.
                          • T
                            tomot
                            @fredo6 said:
                            Tomot,
                            I'm not being critical of the plugin, perhaps its a rendering issue.
                            I'm trying to find out why the HDR light striking the rounded corners is not uniform along the rounded edge of each Tile as I try to show in the pic by the red line
                            For example if I had a number of tiles with rounded edges sitting in sunlight, Each rounded edge along each tile would reflect the sun uniformly. not only for 1 tile but also all other tiles.
                            my plugins
                            tomot
                            • N
                              nickcconnor
                              Thanks Fredo6, your round corner plugin has been a wonderful tool - really solid and reliable - thank you so much.
                              I was just wondering if there were any issues running this in sketchup 15, as it doesn't seem to install for me?
                              Thanks again,
                              Nick
                              • cottyC
                                cotty
                                It's 2015 compatible.
                                my SketchUp gallery
                                  It's fine in v2015.
                                  Do you also have the latest LibFredo... ?
                                  • K
                                    kittiset
                                    thank you
                                    • B
                                      buinhuthuong
                                      thankyou
                                      • HieruH
                                        Hieru
                                        Has anyone else found the plugin to be a but buggy with 2015?
                                        I'm using the latest version (along with the latest LibFredo) and I regularly find that I can't select edges on basic shapes with one or all of the RoundCorner tools.
                                        After restarting my PC everything usually goes back to normal, but the plugin will suddenly stop functioning at some point during a modelling session.
                                        www.davidhier.co.uk
                                          It's good one my end but I'm running very little enabled addons.
                                            I use Round Corner quite frequently and I haven't seen any problems with it at all on SU2015. it has behaved very well.
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 74
                                            • 75
                                            • 48 / 75
