SketchUp 2015 is 64bit
@driven said:
SketchUp now starts with a 30 day trial of SketchUp Pro.
which is nice...
interesting, no more 8 hour trial period? That's too bad imo.
I'm really excited about the LayOut label tool AutoText features too. It can now read things like dynamic component attributes from your models. I'm trying to get it to be able to read dimension info from windows, so the label tool automatically shows the correct dimensions on windows from inside the layout document. A lot of hidden potential here...
I believe the majority of people use up the 8hrs in a day or two...
now that you can't instal both at the same time and switch just for the pro features, I think it's a good move.
I prefer 30 days to test any software before purchase...
john -
See the added RAM in SU.
Glass Chapel... Nice.
good move for Trimble I guess.
I can barely fit your screenshot across my screens. I had to scroll over, and over, and over. I'm jealous of your screen size
"Titan" is not an another Planet ?
Maybe it's several screens in line?
Looks like they fixed the Scrapbook window in Layout. It now sizes properly.
Where can I find the prices update pro2014- pro2015?
Look under "What are the pricing options for the Maintenance & Support Plan?" where you'll find:
Single user: $95 USD per year
Network: $150 USD per year -
Is that so? You're right on the hidden potential there, I will investigate further.
Ah, thank you Dave.
Will thumbnail previews on wondows 64bit work now without any third part software?
@thomthom said:
So all existing plugins must be adapted again
Only if they used binary libraries. Most will work as is.
I had two which needed updating; TT_Lib and Vertex Tools. Compatible versions are on PluginStore and ExtensionWarehouse.I've set X for my shortcut to Delete, still inside vertex tools it doesn't work, only the delete key delete a vertex, even if I remove it from my shortcut list and keep only the X key to delete
edit: I got it now, inside vertex tools it is called erase not delete,
@krisidious said:
Well, hello Steve... Nice to meet you.
First time I saw the template figure I thought it was Mike...
Yes - the thumbnail handler will now be 64bit if you install the 64bit version. Though I'm not sure if you will see thumbnails in 32bit applications when you use the file dialogs.
Don't know if SU2015 will be a big success or another Windows 8, but at least it is breathing new life and an air of excitement back into the forums.
And after the (IMO) lackluster attempts at taking SU forward with R13 and 14, my fears for Sketchup's future after Trimble are now somewhat laid to rest.
They seem to be getting serious about making changes that really matter.
Kudos, Trimble
