    SketchUp 2015 is 64bit
    302 Posts 74 Posters 54.6k Views 74 Watching
      And this version under 64 steroรฏds is only valuable for the Pro version โ“
      If you ever experienced crashes because you ran out of memory this will be of use. Out of the box it's currently rare people hit this limit, but users of render engines which run inside the SketchUp process could easily hit the 32bit limit and find good use of 64bit.
        yes but this 64 version is also for the Make version or not ? ๐Ÿ˜‰
        • pbacotP Offline
          It's available for the Make version
            Thx for the info! โ˜€
              driven
              SketchUp now starts with a 30 day trial of SketchUp Pro.
              which is nice...
              • jeff hammondJ Offline
                nice work @suTeam.. much appreciated ๐Ÿ‘
                • BoxB Offline
                  Two things well worth pointing out.
                  It restores the thumbnails function in Explorer
                  and
                  it can easily be set not to be the default Skp opener, in other words it doesn't ride rough shod over your choice of version. You can install it to test it out and still retain your preferred version as default.
                    Cool function! ๐Ÿ˜‰
                    • andybotA Offline
                      andybot
                      which is nice...
                      interesting, no more 8 hour trial period? That's too bad imo.
                      • MsketcherM Offline
                        Msketcher
                        I'm really excited about the LayOut label tool AutoText features too. It can now read things like dynamic component attributes from your models. I'm trying to get it to be able to read dimension info from windows, so the label tool automatically shows the correct dimensions on windows from inside the layout document. A lot of hidden potential here...
                          driven
                          I believe the majority of people use up the 8hrs in a day or two...
                          now that you can't instal both at the same time and switch just for the pro features, I think it's a good move.
                          I prefer 30 days to test any software before purchase...
                          • soloS Offline
                            See the added RAM in SU.
                            • KrisidiousK Offline
                              Krisidious
                              Glass Chapel... Nice.
                              By: Kristoff Rand
                              • andybotA Offline
                                andybot
                                ๐Ÿ˜ณ good move for Trimble I guess. ๐Ÿ‘Š
                                  Msketcher
                                  I can barely fit your screenshot across my screens. I had to scroll over, and over, and over. I'm jealous of your screen size ๐Ÿ˜„
                                    "Titan" is not an another Planet ? ๐Ÿ˜„
                                    Maybe it's several screens in line? ๐Ÿ˜‰
                                      Krisidious
                                      Looks like they fixed the Scrapbook window in Layout. It now sizes properly.
                                      By: Kristoff Rand
                                      • jo-keJ Offline
                                        jo-ke
                                        Where can I find the prices update pro2014- pro2015?
                                        http://www.zz7.de
                                          Look under "What are the pricing options for the Maintenance & Support Plan?" where you'll find:
                                          Single user: $95 USD per year
                                          Network: $150 USD per year
                                          • oceanembersO Offline
                                            oceanembers
                                            Is that so? You're right on the hidden potential there, I will investigate further.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 16 / 16
