    [Plugin] Material Tools
    124 Posts 44 Posters 206.4k Views 44 Watching
    • L
      lubessy
      Hello,
      I have problem installing this tool..
      so after i downloaded.. I placed the "material tool rb " into the sketchup-> plugin forlder
      and so when i opened a new sketchup.. i still don't see a new plugin for material tool...
      could you tell me how to set this up after i download it???
      Don't I just need to copy and paste into the sketchup- plugin folder?
      and I am using sketchup 8pro version too....
        Notice it's an RBZ - not RB file. See this thread on how to install RBZ files: http://sketchucation.com/forums/viewtopic.php?t=42315#InstallRBZ
        (I'd forgotten to add the How To link for this download which I usually have)
          make
          Nice work, thomthom!!!!
          • Q
            Quang Le
            Very good, material tools are a great tool and helps me alot...
            Thank so much Thomthom...!
            • Q
              Quang Le
              I encountered problems when installing [Plugin] Material Tools (2.6.0). with the following error message:
              "material tools requires a newer version, 2.7.0, of TT_lib"
              I also use TT_Lib2-2.9.0, but still error...I doubt Google SketchUp 8 version is too old ...
              Can you help me?
              Thank so much.
              • tt_suT
                tt_su
                Did you have an old version of TT_Lib2 installed?
                Do you have files that have gotten stuck in the VirtualStore?
                • Q
                  Quang Le
                  Thank Thomthom...! I understand that...
                  I have removed old TT_lib and instal new TT_lib2 of you.
                  I have now used material tools and thank you so much.
                  • rami_lpmR
                    rami_lpm
                    Hi.
                    I had this error while running 'instance material to faces'
                    With and without geometry selected.
                    Error; #<NameError; undefined local variable or method `selection' for TT;;Plugins;;MaterialTools;Module>
                    C;/Users/ramiro velazco/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb;149;in `instance_materials_to_faces'
                    C;/Users/ramiro velazco/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb;40;in `block in <module;MaterialTools>'
                    -e;1;in `call'
                    I solved it(I think?) by adding
                    selection = model.selection
                    in core.rb right after line 148
                    Thanks for a wonderful tool.
                      I just noticed this post. I've filed an issue: https://bitbucket.org/thomthom/material-tools/issue/1/error-while-running-instance-material-to
                      Thanks for the report!
                      • demD
                        dem
                        Hi. Some features not works(
                        Transparent Material to Backside quetly do nothing, but with Instance Material to Faces console dsy:
                        Error: #<NameError: undefined local variable or method selection' for TT::Plugins::MaterialTools:Module> C:/Users/dem/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:149:in instance_materials_to_faces'
                        C:/Users/dem/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:40:in block in <module:MaterialTools>' -e:1:in call'
                        Tested in SU2013 & SU2014
                          Yes, this is the same issue as rami reported: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=17587%26amp;view=unread#p537988
                          • josephkim626J
                            josephkim626
                            Thanks Thomas!
                            I love the plug in, and very often use it.
                            I had some suggestion on improving this plugin:
                            All the listed functions such as "remove from all faces and edges" and "all textures" would be nice to be applied to SELECTION rather than in the entire model.
                              ddsstudio
                              I installed the plugin and everything seems to work great, except the "List Textures in Console" function. It opens the console but there is no list.
                              What am I missing?
                              Thanks for a awesome plugin!
                                What version of SU?
                                You might want to open the console before invoking that function if you are on an older SU version.
                                  Mr Lukestar
                                  Hi sorry I'm a beginner at this.
                                  I have downloaded and add the Material Tool, it in showing in extension manage (sketch 2017 pro). It is installed.
                                  But I cannot find it anywhere in the menu tabs - so how to use???
                                  Any i missing something?
                                  Luke
                                  • josephkim626J
                                    josephkim626
                                    It does not have a toolbar icon, if that is what you mean.
                                    It will show up in the menu however.
                                    Look under:
                                    Extensions > Material Tools.
                                    • H
                                      hank
                                      Thanks for a great plugin thomthom. As is mentioned on Extension Warehouse, "List Textures in Console" generates a blank console window. Is this just a SU2018 thing or are other folks experiencing that issue?
                                      • H
                                        hank
                                        OK, figured out what is up with "List Textures in Console" I think...
                                        I changed puts to print in the following def from Plugins/tt_material_tools/core.rb and it works in SU2018 (sorry ThomThom - I'm probably not supposed to be messing around in there!?). So general question... is puts no longer valid in 2018?
                                        def self.list_textures
                                            Sketchup.send_action('showRubyPanel;')
                                            # Collect textures and sort by size
                                            mats = Sketchup.active_model.materials.select { |m|
                                              !m.texture.nil?
                                            mats.sort! { |a,b|
                                              size_a = a.texture.image_width * a.texture.image_height
                                              size_b = b.texture.image_width * b.texture.image_height
                                              size_b <=> size_a
                                            # Print textures
                                            print "=== TEXTURE MATERIALS BY SIZE ==="
                                            buffer = ''
                                            mats.each { |m|
                                              next if m.texture.nil?
                                              t = m.texture
                                              size = t.image_width * t.image_height
                                              file = File.basename( t.filename )
                                              path = File.dirname( t.filename )
                                              #puts "#{m.display_name} - #{t.image_width}x#{t.image_height} - #{t.filename}"
                                              buffer << "#{m.display_name}\n"
                                              buffer << "  Size; #{t.image_width}x#{t.image_height} pixels\n"
                                              buffer << "  Size; #{self.readable_file_size(size*3, 2)} estimated uncompressed RGB\n"
                                              buffer << "  Size; #{self.readable_file_size(size*4, 2)} estimated uncompressed RGBA\n"
                                              if File.exist?( t.filename )
                                                disksize = File.size( t.filename )
                                                buffer << "  Size; #{self.readable_file_size(disksize, 2)} on disk\n"
                                              buffer << "  File; #{file}\n"
                                              buffer << "  Path; #{path}\n"
                                            print buffer
                                            print "---"
                                          stefankaplan
                                          This is a great extension! - and the only one I've found that lists in model textures and their file sizes, which is key when trying to reduce size of the SketchUp model.
                                          Only problem is: It only work on my Mac. When running "List textures in console", an empty console appears (in SketchUp 2022 and 2023) ๐Ÿ˜ž
                                          I've tried to disable all other extensions but no luck, the console still doesn't list any textures on my Windows computer.
                                          Any advice?
                                            @stefankaplan said:
                                            ... the console still doesn't list any textures on my Windows computer.
                                            Any advice?
                                            This is what I get in the console when I run this feature. This is in SketchUp 2023.
                                            Did you install SketchUp correctly? That requires right clicking on the downloaded installer file and selecting Run as administrator from the context menu. If you didn't or don't remember, close SketchUp, find the installer in your Downloads folder, right click on it, choose Run as administrtor and then Repair.
                                            BTW, did you have the Ruby Console opened before you ran the extension?
                                            • 6 / 7
