    [Plugin] Material Tools
    124 Posts 44 Posters 206.4k Views 44 Watching
      Yes, this is the same issue as rami reported: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=17587%26amp;view=unread#p537988
      • josephkim626J
        josephkim626
        Thanks Thomas!
        I love the plug in, and very often use it.
        I had some suggestion on improving this plugin:
        All the listed functions such as "remove from all faces and edges" and "all textures" would be nice to be applied to SELECTION rather than in the entire model.
          ddsstudio
          I installed the plugin and everything seems to work great, except the "List Textures in Console" function. It opens the console but there is no list.
          What am I missing?
          Thanks for a awesome plugin!
            What version of SU?
            You might want to open the console before invoking that function if you are on an older SU version.
              Mr Lukestar
              Hi sorry I'm a beginner at this.
              I have downloaded and add the Material Tool, it in showing in extension manage (sketch 2017 pro). It is installed.
              But I cannot find it anywhere in the menu tabs - so how to use???
              Any i missing something?
              Luke
              • josephkim626J
                josephkim626
                It does not have a toolbar icon, if that is what you mean.
                It will show up in the menu however.
                Look under:
                Extensions > Material Tools.
                • H
                  hank
                  Thanks for a great plugin thomthom. As is mentioned on Extension Warehouse, "List Textures in Console" generates a blank console window. Is this just a SU2018 thing or are other folks experiencing that issue?
                  • H
                    hank
                    OK, figured out what is up with "List Textures in Console" I think...
                    I changed puts to print in the following def from Plugins/tt_material_tools/core.rb and it works in SU2018 (sorry ThomThom - I'm probably not supposed to be messing around in there!?). So general question... is puts no longer valid in 2018?
                    def self.list_textures
                        Sketchup.send_action('showRubyPanel;')
                        # Collect textures and sort by size
                        mats = Sketchup.active_model.materials.select { |m|
                          !m.texture.nil?
                        mats.sort! { |a,b|
                          size_a = a.texture.image_width * a.texture.image_height
                          size_b = b.texture.image_width * b.texture.image_height
                          size_b <=> size_a
                        # Print textures
                        print "=== TEXTURE MATERIALS BY SIZE ==="
                        buffer = ''
                        mats.each { |m|
                          next if m.texture.nil?
                          t = m.texture
                          size = t.image_width * t.image_height
                          file = File.basename( t.filename )
                          path = File.dirname( t.filename )
                          #puts "#{m.display_name} - #{t.image_width}x#{t.image_height} - #{t.filename}"
                          buffer << "#{m.display_name}\n"
                          buffer << "  Size; #{t.image_width}x#{t.image_height} pixels\n"
                          buffer << "  Size; #{self.readable_file_size(size*3, 2)} estimated uncompressed RGB\n"
                          buffer << "  Size; #{self.readable_file_size(size*4, 2)} estimated uncompressed RGBA\n"
                          if File.exist?( t.filename )
                            disksize = File.size( t.filename )
                            buffer << "  Size; #{self.readable_file_size(disksize, 2)} on disk\n"
                          buffer << "  File; #{file}\n"
                          buffer << "  Path; #{path}\n"
                        print buffer
                        print "---"
                      stefankaplan
                      This is a great extension! - and the only one I've found that lists in model textures and their file sizes, which is key when trying to reduce size of the SketchUp model.
                      Only problem is: It only work on my Mac. When running "List textures in console", an empty console appears (in SketchUp 2022 and 2023) 😞
                      I've tried to disable all other extensions but no luck, the console still doesn't list any textures on my Windows computer.
                      Any advice?
                        @stefankaplan said:
                        ... the console still doesn't list any textures on my Windows computer.
                        Any advice?
                        This is what I get in the console when I run this feature. This is in SketchUp 2023.
                        Did you install SketchUp correctly? That requires right clicking on the downloaded installer file and selecting Run as administrator from the context menu. If you didn't or don't remember, close SketchUp, find the installer in your Downloads folder, right click on it, choose Run as administrtor and then Repair.
                        BTW, did you have the Ruby Console opened before you ran the extension?
                        • V
                          Vendettos
                          @thomthom Same error as the others above. - When running "List textures in console", an empty console appears (in SketchUp 2025). Any solutions?
                          • 7 / 7
