    [Plugin] Material Tools
    124 Posts 44 Posters 206.4k Views 44 Watching
      Yeeea.... didn't happen... 😞 I've run into a bug that needs fixing.
        Version 2.6.0
        • Added Transparent Material to Backside.
        • Added support Fredo updater.
          rv1974
          πŸ‘
          • EarthMoverE
            EarthMover
            Thanks for the update! The transparent material to backside is a huge help! πŸ‘
            Content Creator at Skapeup
            • L
              lubessy
              Hello,
              I have problem installing this tool..
              so after i downloaded.. I placed the "material tool rb " into the sketchup-> plugin forlder
              and so when i opened a new sketchup.. i still don't see a new plugin for material tool...
              could you tell me how to set this up after i download it???
              Don't I just need to copy and paste into the sketchup- plugin folder?
              and I am using sketchup 8pro version too....
                Notice it's an RBZ - not RB file. See this thread on how to install RBZ files: http://sketchucation.com/forums/viewtopic.php?t=42315#InstallRBZ
                (I'd forgotten to add the How To link for this download which I usually have)
                  make
                  Nice work, thomthom!!!!
                  • Q
                    Quang Le
                    Very good, material tools are a great tool and helps me alot...
                    Thank so much Thomthom...!
                    • Q
                      Quang Le
                      I encountered problems when installing [Plugin] Material Tools (2.6.0). with the following error message:
                      "material tools requires a newer version, 2.7.0, of TT_lib"
                      I also use TT_Lib2-2.9.0, but still error...I doubt Google SketchUp 8 version is too old ...
                      Can you help me?
                      Thank so much.
                      • tt_suT
                        tt_su
                        Did you have an old version of TT_Lib2 installed?
                        Do you have files that have gotten stuck in the VirtualStore?
                        • Q
                          Quang Le
                          Thank Thomthom...! I understand that...
                          I have removed old TT_lib and instal new TT_lib2 of you.
                          I have now used material tools and thank you so much.
                          • rami_lpmR
                            rami_lpm
                            Hi.
                            I had this error while running 'instance material to faces'
                            With and without geometry selected.
                            Error; #<NameError; undefined local variable or method `selection' for TT;;Plugins;;MaterialTools;Module>
                            C;/Users/ramiro velazco/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb;149;in `instance_materials_to_faces'
                            C;/Users/ramiro velazco/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb;40;in `block in <module;MaterialTools>'
                            -e;1;in `call'
                            I solved it(I think?) by adding
                            selection = model.selection
                            in core.rb right after line 148
                            Thanks for a wonderful tool.
                              I just noticed this post. I've filed an issue: https://bitbucket.org/thomthom/material-tools/issue/1/error-while-running-instance-material-to
                              Thanks for the report!
                              • demD
                                dem
                                Hi. Some features not works(
                                Transparent Material to Backside quetly do nothing, but with Instance Material to Faces console dsy:
                                Error: #<NameError: undefined local variable or method selection' for TT::Plugins::MaterialTools:Module> C:/Users/dem/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:149:in instance_materials_to_faces'
                                C:/Users/dem/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:40:in block in <module:MaterialTools>' -e:1:in call'
                                Tested in SU2013 & SU2014
                                  Yes, this is the same issue as rami reported: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=17587%26amp;view=unread#p537988
                                  • josephkim626J
                                    josephkim626
                                    Thanks Thomas!
                                    I love the plug in, and very often use it.
                                    I had some suggestion on improving this plugin:
                                    All the listed functions such as "remove from all faces and edges" and "all textures" would be nice to be applied to SELECTION rather than in the entire model.
                                      ddsstudio
                                      I installed the plugin and everything seems to work great, except the "List Textures in Console" function. It opens the console but there is no list.
                                      What am I missing?
                                      Thanks for a awesome plugin!
                                        What version of SU?
                                        You might want to open the console before invoking that function if you are on an older SU version.
                                          Mr Lukestar
                                          Hi sorry I'm a beginner at this.
                                          I have downloaded and add the Material Tool, it in showing in extension manage (sketch 2017 pro). It is installed.
                                          But I cannot find it anywhere in the menu tabs - so how to use???
                                          Any i missing something?
                                          Luke
                                          • josephkim626J
                                            josephkim626
                                            It does not have a toolbar icon, if that is what you mean.
                                            It will show up in the menu however.
                                            Look under:
                                            Extensions > Material Tools.
                                            • 6 / 7
