    [Plugin] Material Tools
    124 Posts 44 Posters 195.2k Views 44 Watching
      How would you handle groups with faces of multiple materials? It's just not an symmetrical operation.
        rv1974
        Only default material within the would inherit the comp\group mat. The manually set multiple mats would survive.
          Oh - I misread you. I thought you wanted face material to group materials.
          You want the instance materials to be applied to all faces with default material in the group/component? That's already there: "Instance Material to Faces"
            rv1974
            damn how could I miss it.
              rv1974
              @thomthom said:
              Give me a couple of days. I need to release an update to TT_Lib2 first.
              ...bump
              πŸ˜’
                Yeeea.... didn't happen... 😞 I've run into a bug that needs fixing.
                  Version 2.6.0
                  • Added Transparent Material to Backside.
                  • Added support Fredo updater.
                    rv1974
                    πŸ‘
                    • EarthMoverE Offline
                      EarthMover
                      Thanks for the update! The transparent material to backside is a huge help! πŸ‘
                      Content Creator at Skapeup
                        lubessy
                        Hello,
                        I have problem installing this tool..
                        so after i downloaded.. I placed the "material tool rb " into the sketchup-> plugin forlder
                        and so when i opened a new sketchup.. i still don't see a new plugin for material tool...
                        could you tell me how to set this up after i download it???
                        Don't I just need to copy and paste into the sketchup- plugin folder?
                        and I am using sketchup 8pro version too....
                          Notice it's an RBZ - not RB file. See this thread on how to install RBZ files: http://sketchucation.com/forums/viewtopic.php?t=42315#InstallRBZ
                          (I'd forgotten to add the How To link for this download which I usually have)
                            make
                            Nice work, thomthom!!!!
                            • Q Offline
                              Quang Le
                              Very good, material tools are a great tool and helps me alot...
                              Thank so much Thomthom...!
                              • Q Offline
                                Quang Le
                                I encountered problems when installing [Plugin] Material Tools (2.6.0). with the following error message:
                                "material tools requires a newer version, 2.7.0, of TT_lib"
                                I also use TT_Lib2-2.9.0, but still error...I doubt Google SketchUp 8 version is too old ...
                                Can you help me?
                                Thank so much.
                                • tt_suT Offline
                                  tt_su
                                  Did you have an old version of TT_Lib2 installed?
                                  Do you have files that have gotten stuck in the VirtualStore?
                                  • Q Offline
                                    Quang Le
                                    Thank Thomthom...! I understand that...
                                    I have removed old TT_lib and instal new TT_lib2 of you.
                                    I have now used material tools and thank you so much.
                                    • rami_lpmR Offline
                                      rami_lpm
                                      Hi.
                                      I had this error while running 'instance material to faces'
                                      With and without geometry selected.
                                      Error; #<NameError; undefined local variable or method `selection' for TT;;Plugins;;MaterialTools;Module>
                                      C;/Users/ramiro velazco/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb;149;in `instance_materials_to_faces'
                                      C;/Users/ramiro velazco/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb;40;in `block in <module;MaterialTools>'
                                      -e;1;in `call'
                                      I solved it(I think?) by adding
                                      selection = model.selection
                                      in core.rb right after line 148
                                      Thanks for a wonderful tool.
                                        I just noticed this post. I've filed an issue: https://bitbucket.org/thomthom/material-tools/issue/1/error-while-running-instance-material-to
                                        Thanks for the report!
                                        • demD Offline
                                          dem
                                          Hi. Some features not works(
                                          Transparent Material to Backside quetly do nothing, but with Instance Material to Faces console dsy:
                                          Error: #<NameError: undefined local variable or method selection' for TT::Plugins::MaterialTools:Module> C:/Users/dem/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:149:in instance_materials_to_faces'
                                          C:/Users/dem/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:40:in block in <module:MaterialTools>' -e:1:in call'
                                          Tested in SU2013 & SU2014
                                            Yes, this is the same issue as rami reported: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=17587%26amp;view=unread#p537988
                                            • 6 / 7
