    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 199.8k Views 54 Watching
      @stever
      Sounds like you have installed it just fine from its RBZ archive!
      The problem seems to be you πŸ˜‰
      Please [re]read the instructions on the tool's download page: where its uses clearly explained... πŸ˜•
      The tool is only 'enabled' if you have already made an appropriate selection: ONE FACE.
      So preselect ONE FACE... and 'miraculously' you will find that the tool's toolbar button etc is then available for use...
      Surely you have noticed how some tools only become 'enabled' when circumstances are appropriate... like you have one suitable thing selected... πŸ˜’
      • K
        keyston
        excellent time saving tool, thanks Tig.
        where would sketchup be without guys like you, tom tom and fredo.
        • B
          blarvin
          Rocks.
          • TrixtaT
            Trixta
            Just wondering? Is "TIG_Random _Shape_Generator.rb.v2.1" the final offer. ❓
            Thanks for working at it over 'The End of the world', Christmas and New Years.
            Great Plugin. Thank you! You rock.
            Win7 & SU14 Pro
              No.
              It is in the middle of a revamp...
              BUT other more pressure projects have intervened.
              Keep watching, an update will arrive one day...
                dedmin
                See attached video - SU PRO 2014, Win 7 64 bit
                Video_2014-05-31_075712.wmv
                  [attachment=0:1e099geg]<!-- ia0 -->Video_2014-05-31_075712.wmv<!-- ia0 -->[/attachment:1e099geg]
                  It should offset any arcs/circles/curves as curves NOT arcs/circles.
                  BUT I' unsure why one of the curve's edges is failing to be incorporated in that new curve...
                  remember that it's not really intended to replace the native Offset for these kinds of very simple operations, but rather to avoid the annoying 'bow-tie' issues it can cause in complex concave/narrowing loops
                  This tool IS long overdue its annual update...
                  Keep watching [but don't hold your breath]... πŸ˜’
                  • T
                    tomot
                    @tig said:
                    No.
                    Does the ruby API have code similar to your offset and reveal Ruby. But that instead of selecting faces one would select lines, similar to the "edge loops" concept used in Zbrush or C4D? see attachment
                    my plugins
                    tomot
                    • E
                      edgars
                      how instal this plugin?
                        Either 1. download its RBZ from the SCF PluginStore page linked above... and 2. use the Preferences > Extensions > Install... button.
                        OR one off - get the SketchUcation Toolset RBZ from the Resources menu [above], then install it - and thereafter use that to install all of your needs from the PluginStore directly using AutoInstall from the PluginStore dialog in one step.
                          A +ve distance
                          What is the meaning of "ve" ?
                            Positive.
                              Yes, +ve and -ve are common English abbreviations for Positive and Negative respectively: used with numbers - e.g. 2, -2
                                Thx for the info! πŸ‘
                                  Version 3.0 is released. https://sketchucation.com/pluginstore?pln=TIG_Smart_offset It's now updated to work with newer versions of SketchUp [including 'signing'].
                                  If used within another tool it also properly returns the newly created face[s] within an array...
                                  See usage notes in first post...
                                    melahome12
                                    good morning I am a university student this plugin interests me many I would like to know how to download the plugin
                                      Click the Download button in TIG's post immediately above yours.
                                        Please note that the newer versions of SketchUp [v2017/2018] now have improved Offset processes which might render this tool unnecessary...
                                        • E
                                          Einstein
                                          Hi TIG!
                                          In my opinion your tool IS still necessary because sketchup is still not yet smart enough to support offsetting multiple faces πŸ˜›
                                          I think I tried out all free multi-offsetting plugins and, although Smart Offset is the slowest, it doesn't cause reversed offsets (going outsie face instead of inside).
                                            davionkia555
                                            ty sir πŸ‘ πŸ‘
                                            • 6 / 8
