    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 192.3k Views 54 Watching
      Happy New Year, Simon... 😍
      I am working on an up date that should up the percentage of successful outcomes too πŸ˜‰
      • shuraS Offline
        shura
        Happy new year TIG!
        gosh, this plugin is something I've been wishing for at least a trillion of times. You are my hero Sir!
        • utilerU Offline
          utiler
          Just returned today from a few weeks holidays. Never too late to use your manners my grandma used to always say!!!
          TIG, Trimble needs you, really. Not to mention all the other programmers around here that produce everything from simple tweaks to full blown toolsets...
          A big thank you from me!!!!
          Just Curious...
          • john2J Offline
            john2
            wonder why sketchup guys don't have the normal and ordinary offset that you invented πŸ‘
            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
            • artmusicstudioA Offline
              artmusicstudio
              @tig said:
              @Stan, any donation is more than welcome... I assume you meant Β£5 because 5p=~8Β’... πŸ˜‰
              I think I have a fix for your probable issue - these 3m inset/outset offsets worked OK with a new version that I am working on [native fails with twisted parts].
              It fixes some issues with multi-curve loops and also some curves that straddle a loop's start/end vertex not all offsetting as curves...
              So far it seems to trap various permutations of offset size and loop contents and convolutions, that have been some unexpected causing issues...
              I hope to have that version ready for release tomorrow...
              hi tig, yes, i ment pounds, but had not the sign on my german keyboard.
              thanx for solving the problem, thats fantastic. i'll try soon.
              stan
                stever
                I just tried to install this into my SU ver 8, not Pro, using the Window/preference/extensions/Install extension button. The .rb file appears in my plugins directory and the icon appears on the SU screen but it is greyed out and inactive. Can you make a suggestion as to what the problem might be?
                Steve
                  @stever
                  Sounds like you have installed it just fine from its RBZ archive!
                  The problem seems to be you πŸ˜‰
                  Please [re]read the instructions on the tool's download page: where its uses clearly explained... πŸ˜•
                  The tool is only 'enabled' if you have already made an appropriate selection: ONE FACE.
                  So preselect ONE FACE... and 'miraculously' you will find that the tool's toolbar button etc is then available for use...
                  Surely you have noticed how some tools only become 'enabled' when circumstances are appropriate... like you have one suitable thing selected... πŸ˜’
                    keyston
                    excellent time saving tool, thanks Tig.
                    where would sketchup be without guys like you, tom tom and fredo.
                      blarvin
                      Rocks.
                      • TrixtaT Offline
                        Trixta
                        Just wondering? Is "TIG_Random _Shape_Generator.rb.v2.1" the final offer. ❓
                        Thanks for working at it over 'The End of the world', Christmas and New Years.
                        Great Plugin. Thank you! You rock.
                        Win7 & SU14 Pro
                          No.
                          It is in the middle of a revamp...
                          BUT other more pressure projects have intervened.
                          Keep watching, an update will arrive one day...
                            dedmin
                            See attached video - SU PRO 2014, Win 7 64 bit
                            Video_2014-05-31_075712.wmv
                              [attachment=0:1e099geg]<!-- ia0 -->Video_2014-05-31_075712.wmv<!-- ia0 -->[/attachment:1e099geg]
                              It should offset any arcs/circles/curves as curves NOT arcs/circles.
                              BUT I' unsure why one of the curve's edges is failing to be incorporated in that new curve...
                              remember that it's not really intended to replace the native Offset for these kinds of very simple operations, but rather to avoid the annoying 'bow-tie' issues it can cause in complex concave/narrowing loops
                              This tool IS long overdue its annual update...
                              Keep watching [but don't hold your breath]... πŸ˜’
                                tomot
                                @tig said:
                                No.
                                Does the ruby API have code similar to your offset and reveal Ruby. But that instead of selecting faces one would select lines, similar to the "edge loops" concept used in Zbrush or C4D? see attachment
                                my plugins
                                tomot
                                • E Offline
                                  edgars
                                  how instal this plugin?
                                    Either 1. download its RBZ from the SCF PluginStore page linked above... and 2. use the Preferences > Extensions > Install... button.
                                    OR one off - get the SketchUcation Toolset RBZ from the Resources menu [above], then install it - and thereafter use that to install all of your needs from the PluginStore directly using AutoInstall from the PluginStore dialog in one step.
                                      A +ve distance
                                      What is the meaning of "ve" ?
                                        Positive.
                                          Yes, +ve and -ve are common English abbreviations for Positive and Negative respectively: used with numbers - e.g. 2, -2
                                            Thx for the info! πŸ‘
                                            • 6 / 8
