    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • E Offline
      eozel
      As you said, i installed fredotools. It said that "selected extension has been succesfully installed...". When i open skecthup software again it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.).
      Thanks four your supports.
      • fredo6F Offline
        Do you see the menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a.
        At least this shows that LibFredo6 is correctly installed
        Maybe a snapshot of your Plugin directory would also help.
        • E Offline
          eozel
          I see menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a. But after i install extensions like curviloft, roundcornet, it give error msg ""you must install Libfredo 6 version 5.2..". I installed fredotools too as you said me, it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.
          thanks.
            I've seen the same sort of message in the past. The solution that worked for me was to go to the Plugins folder and delete the LibFredo6 files including the folders. Then reinstall the fresh version from the Pluginstore.
            Evidently, some file wasn't getting overwritten when the newer version was installed over the old.
            • E Offline
              eozel
              Thanks but I try to it more than 2 times, additionally i uninstalled sketchup and delete all files related with it. My problem comes from asci chracter of computer username. With new update of libfredo 6, libfredo 6 settings has been seen under windows menu. But plugings gives error whicg i said before msg.
              Additionally, another computer of mine (which hasn't got asci chracter of username) which i use libfredo 6 and most of plugins. But when i install shapes pluging, it start to give load error msg:
                Uninstalling and reinstalling sketchUp was an unneeded step.
                As for the Shapes plugin, where did you get it?
                • E Offline
                  eozel
                  While other plugings works well for the shapes plugin, it gives load error msg another computer of mine when sketchup is opennig.
                    That didn't answer my question. šŸ˜’
                    Just forget I asked about it.
                    • E Offline
                      eozel
                      SketchUp Plugins | PluginStore | SketchUcation
                      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                      (sketchucation.com)
                      • fredo6F Offline
                        @eozel,
                        At the moment, only LibFredo6 and FredoTools has been corrected for the problem of non-ascii characters.
                        So are you sure you dont find it?
                        • the menu is under Tools > FredoTools
                        • there is a toolbar with a single icon showing F6
                          (sketchucation.com)
                          Try the version from the Extension Warehouse instead.
                          • E Offline
                            eozel
                            @fredo6 said:
                            @eozel,
                            There is no fredotools.
                            • fredo6F Offline
                              @eozel,
                              Could you show a screenshort of the "check For Updates" of LibFredo6.
                              Also, can you check the footprint of plugins in the SU Plugins directory where you installed.
                              • E Offline
                                eozel
                                @fredo6 said:
                                @eozel,
                                • fredo6F Offline
                                  Eozel,
                                  Thanks. There is also a Trace log utility in the LibFredo6 menu.
                                  Could you check or send me the txt or a snapshot after expanding the list.
                                  Also the date of last check (1 Jan 1970) seems to have a problem. I have to check
                                  • E Offline
                                    eozel
                                    @fredo6 said:
                                    Eozel,
                                    1413369931.22969;Fredo6_!LibFredo6.rb:71: in `log'
                                    DATE / TIME: 2014-10-15 13:45:31 +0300
                                    SKETCHUP VERSION: 14.1.1282
                                    RUBY_PLATFORM: i386-mingw32
                                    LOG FILE: LibFredo6Trace_14_1413369931228.txt
                                    1413369931.22969;Fredo6_!LibFredo6.rb:113: in `startup'
                                    LibFredo6: Starting up Fredo6_!LibFredo6.rb
                                    1413369931.319277;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
                                    Temp Files directory: C:/Users/EMREZE~1/AppData/Local/Temp
                                    1413369931.351414;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
                                    Default Parameters folder: C:/Users/EMREZE~1/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters
                                    1413369931.385449;Fredo6_!LibFredo6.rb:173: in `startup'
                                    LibFredo6: Beginning of loading Cycle***+
                                    1413369931.4218082;Fredo6_!LibFredo6.rb:180: in `startup'
                                    LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core.rb successfully loaded
                                    1413369931.5345228;Lib6Core.rb:992: in `load_full_rubies'
                                    LibFredo6 6.2a: Ruby files loaded [69 ms]
                                    1413369931.56119;Lib6Core.rb:921: in `effective_load_part2'
                                    LibFredo6 6.2a: Startup (creating menus and icons) [10 ms]
                                    1413369931.586445;Fredo6_!LibFredo6.rb:189: in `startup'
                                    LibFredo6: End of loading Cycle***-
                                    1413369938.4396129;Lib6Plugin.rb:150: in `load_body'
                                    Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [33 ms]
                                    1413369938.539354;Lib6Core.rb:85: in `use_single_library'
                                    Lib6G6.rb: Loading body code from body_Lib6G6.rb [80 ms]
                                    1413369938.580538;Lib6Core.rb:85: in `use_single_library'
                                    Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [20 ms]
                                    1413369938.621686;Lib6Core.rb:85: in `use_single_library'
                                    Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [20 ms]
                                    1413369938.673656;Lib6Core.rb:85: in `use_single_library'
                                    Lib6WebHtml.rb: Loading body code from body_Lib6WebHtml.rb [30 ms]
                                    1413369938.770474;Lib6Core.rb:85: in `use_single_library'
                                    Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [77 ms]
                                    1413369938.835396;Lib6Core.rb:85: in `use_single_library'
                                    Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [40 ms]
                                    1413369938.882689;Lib6Core.rb:85: in `use_single_library'
                                    Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [23 ms]
                                    1413369938.916536;Lib6Core.rb:85: in `use_single_library'
                                    Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [15 ms]
                                    1413369938.9848142;Lib6Core.rb:85: in `use_single_library'
                                    Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [49 ms]
                                    1413369939.032744;Lib6Core.rb:85: in `use_single_library'
                                    Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [22 ms]
                                    1413369939.0687091;Lib6Plugin.rb:150: in `load_body'
                                    Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [17 ms]
                                    1413369939.1184819;Lib6Plugin.rb:150: in `load_body'
                                    Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [25 ms]
                                    1413369939.164896;Lib6Plugin.rb:150: in `load_body'
                                    Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [25 ms]
                                    • fredo6F Offline
                                      Very strange.
                                      Could you do 2 things:
                                      1. Type the following commands in the RubyConsole and tell me the result
                                        LibFredo6.sudir
                                        LibFredo6.path
                                        LibFredo6.folder
                                        LibFredo6.appdata_dir
                                        LibFredo6.defparam_dir
                                        defined?(FredoTools)
                                      2. Remove the Fredo6_Fredotools.rb file (it is of no use actually, just for EWH compliance), exit and restart SU and see if you see FredoTools now
                                      Thanks and sorry for these problems. You support is helpful
                                      • E Offline
                                        eozel
                                        @fredo6 said:
                                        Very strange.
                                          LibFredo6.sudir
                                          LibFredo6.path
                                          LibFredo6.folder
                                        LibFredo6.sudir
                                        C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                                        LibFredo6.path
                                        C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6
                                        LibFredo6.folder
                                        Fredo6_!LibFredo6
                                        nil
                                        1. I removed Fredo6_Fredotools.rb file, exited and restarted SU. But there is not fredotools.
                                        I think there is another problem on my pc or windows settings, etc.
                                        Thanks for your supports
                                        • fredo6F Offline
                                          Thanks.
                                          Could you show the footprint of the Fredo6_FredoTools folder. You may simply have a file missing (with extension .plugin).
                                          • E Offline
                                            eozel
                                            @fredo6 said:
                                            Thanks.
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 96
                                            • 108
                                            • 109
                                            • 94 / 109
