    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • E
      eozel
      Hi, i installed libfredo 6.2a on my pc which inclued as a username "ö" chracter. Libfredo 6 settings now can be seen in window menu, but when i open skethup it gives an error msg: "you must install Libfredo 6 version 5.2 ....".
      • fredo6F
        @eozel,
        I think I have also to change the top rb file for all plugins (i.e. Fredo6_xxx.rb).
        I did it already for the new version of FredoTools (2.1a). Can you check that FredoTools does load correctly.
        If so, then I will republish for the other plugins.
        • B
          Ben Ritter
          The download link does not work for me for either one of the plugins.
          • fredo6F
            Which download link? I only publish via the SCF PLugin Store.
            • B
              Ben Ritter
              OK, thanks. I just thought the yellow "Download" button in your post downloaded the .rb files on some of your other plugins.
              Thanks again for sharing.
              • E
                eozel
                As you said, i installed fredotools. It said that "selected extension has been succesfully installed...". When i open skecthup software again it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.).
                Thanks four your supports.
                • fredo6F
                  Do you see the menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a.
                  At least this shows that LibFredo6 is correctly installed
                  Maybe a snapshot of your Plugin directory would also help.
                  • E
                    eozel
                    I see menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a. But after i install extensions like curviloft, roundcornet, it give error msg ""you must install Libfredo 6 version 5.2..". I installed fredotools too as you said me, it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.
                    thanks.
                      I've seen the same sort of message in the past. The solution that worked for me was to go to the Plugins folder and delete the LibFredo6 files including the folders. Then reinstall the fresh version from the Pluginstore.
                      Evidently, some file wasn't getting overwritten when the newer version was installed over the old.
                      • E
                        eozel
                        Thanks but I try to it more than 2 times, additionally i uninstalled sketchup and delete all files related with it. My problem comes from asci chracter of computer username. With new update of libfredo 6, libfredo 6 settings has been seen under windows menu. But plugings gives error whicg i said before msg.
                        Additionally, another computer of mine (which hasn't got asci chracter of username) which i use libfredo 6 and most of plugins. But when i install shapes pluging, it start to give load error msg:
                          Uninstalling and reinstalling sketchUp was an unneeded step.
                          As for the Shapes plugin, where did you get it?
                          • E
                            eozel
                            While other plugings works well for the shapes plugin, it gives load error msg another computer of mine when sketchup is opennig.
                              That didn't answer my question. 😒
                              Just forget I asked about it.
                              • E
                                eozel
                                404 Not Found
                                (sketchucation.com)
                                • fredo6F
                                  @eozel,
                                  At the moment, only LibFredo6 and FredoTools has been corrected for the problem of non-ascii characters.
                                  So are you sure you dont find it?
                                  • the menu is under Tools > FredoTools
                                  • there is a toolbar with a single icon showing F6
                                    404 Not Found
                                    (sketchucation.com)
                                    Try the version from the Extension Warehouse instead.
                                    • E
                                      eozel
                                      @fredo6 said:
                                      @eozel,
                                      There is no fredotools.
                                      • fredo6F
                                        @eozel,
                                        Could you show a screenshort of the "check For Updates" of LibFredo6.
                                        Also, can you check the footprint of plugins in the SU Plugins directory where you installed.
                                        • E
                                          eozel
                                          @fredo6 said:
                                          @eozel,
                                          • fredo6F
                                            Eozel,
                                            Thanks. There is also a Trace log utility in the LibFredo6 menu.
                                            Could you check or send me the txt or a snapshot after expanding the list.
                                            Also the date of last check (1 Jan 1970) seems to have a problem. I have to check
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 115
                                            • 116
                                            • 43 / 116
