[Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
Uninstalling and reinstalling sketchUp was an unneeded step.
As for the Shapes plugin, where did you get it?
While other plugings works well for the shapes plugin, it gives load error msg another computer of mine when sketchup is opennig.
That didn't answer my question.
Just forget I asked about it.
At the moment, only LibFredo6 and FredoTools has been corrected for the problem of non-ascii characters.
So are you sure you dont find it?
- the menu is under Tools > FredoTools
- there is a toolbar with a single icon showing F6
Could you show a screenshort of the "check For Updates" of LibFredo6.
Also, can you check the footprint of plugins in the SU Plugins directory where you installed.
Eozel,
Thanks. There is also a Trace log utility in the LibFredo6 menu.
Could you check or send me the txt or a snapshot after expanding the list.Also the date of last check (1 Jan 1970) seems to have a problem. I have to check
@fredo6 said:
Eozel,
1413369931.22969;Fredo6_!LibFredo6.rb:71: in `log'
DATE / TIME: 2014-10-15 13:45:31 +0300
SKETCHUP VERSION: 14.1.1282
RUBY_PLATFORM: i386-mingw32
LOG FILE: LibFredo6Trace_14_1413369931228.txt1413369931.22969;Fredo6_!LibFredo6.rb:113: in `startup'
LibFredo6: Starting up Fredo6_!LibFredo6.rb1413369931.319277;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
Temp Files directory: C:/Users/EMREZE~1/AppData/Local/Temp1413369931.351414;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
Default Parameters folder: C:/Users/EMREZE~1/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters1413369931.385449;Fredo6_!LibFredo6.rb:173: in `startup'
LibFredo6: Beginning of loading Cycle***+1413369931.4218082;Fredo6_!LibFredo6.rb:180: in `startup'
LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core.rb successfully loaded1413369931.5345228;Lib6Core.rb:992: in `load_full_rubies'
LibFredo6 6.2a: Ruby files loaded [69 ms]1413369931.56119;Lib6Core.rb:921: in `effective_load_part2'
LibFredo6 6.2a: Startup (creating menus and icons) [10 ms]1413369931.586445;Fredo6_!LibFredo6.rb:189: in `startup'
LibFredo6: End of loading Cycle***-1413369938.4396129;Lib6Plugin.rb:150: in `load_body'
Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [33 ms]1413369938.539354;Lib6Core.rb:85: in `use_single_library'
Lib6G6.rb: Loading body code from body_Lib6G6.rb [80 ms]1413369938.580538;Lib6Core.rb:85: in `use_single_library'
Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [20 ms]1413369938.621686;Lib6Core.rb:85: in `use_single_library'
Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [20 ms]1413369938.673656;Lib6Core.rb:85: in `use_single_library'
Lib6WebHtml.rb: Loading body code from body_Lib6WebHtml.rb [30 ms]1413369938.770474;Lib6Core.rb:85: in `use_single_library'
Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [77 ms]1413369938.835396;Lib6Core.rb:85: in `use_single_library'
Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [40 ms]1413369938.882689;Lib6Core.rb:85: in `use_single_library'
Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [23 ms]1413369938.916536;Lib6Core.rb:85: in `use_single_library'
Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [15 ms]1413369938.9848142;Lib6Core.rb:85: in `use_single_library'
Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [49 ms]1413369939.032744;Lib6Core.rb:85: in `use_single_library'
Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [22 ms]1413369939.0687091;Lib6Plugin.rb:150: in `load_body'
Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [17 ms]1413369939.1184819;Lib6Plugin.rb:150: in `load_body'
Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [25 ms]1413369939.164896;Lib6Plugin.rb:150: in `load_body'
Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [25 ms]
Very strange.
Could you do 2 things:
Type the following commands in the RubyConsole and tell me the result
LibFredo6.sudir
LibFredo6.path
LibFredo6.folder
LibFredo6.appdata_dir
LibFredo6.defparam_dir
defined?(FredoTools) -
Remove the Fredo6_Fredotools.rb file (it is of no use actually, just for EWH compliance), exit and restart SU and see if you see FredoTools now
Thanks and sorry for these problems. You support is helpful
@fredo6 said:
Very strange.
LibFredo6.sudir
LibFredo6.path
LibFredo6.folder
LibFredo6.sudir
C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
LibFredo6.path
C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6
LibFredo6.folder
Fredo6_!LibFredo6
nil- I removed Fredo6_Fredotools.rb file, exited and restarted SU. But there is not fredotools.
I think there is another problem on my pc or windows settings, etc.
Thanks for your supports
Thanks.
Could you show the footprint of the Fredo6_FredoTools folder. You may simply have a file missing (with extension .plugin).
@fredo6 said:
Thanks.
Eozel,
I think I found the problem.
To be sure, could you copy the attached file into the Fredo6!_LibFredo6 subfolder and restart SU
Lib6Core.rbThanks in advance
@fredo6 said:
Eozel,
[attachment=2:3s9bb5jv]<!-- ia2 -->Lib6Core.rb<!-- ia2 -->[/attachment:3s9bb5jv]Thanks in advance
Fredotools now can ben seen in tools menu:)).
After than i install roundcorner it is working too but when opening the SU it give error below.
Then i install Su draw parametric shape 2.27 but it gives error too which is given below. Error Loading File C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb
Error: cannot load such file -- C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/parametric.rb
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:inrequire' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:inrequire'
C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb:8:in<top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inrequire'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:inload' C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:inregister_extension'
C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in<module:Shapes>' C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:12:inmodule:JWM'
C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:11:in `<top (required)>'Curviloft gives errors too.
Eozel,
Thanks very much. We are progressing
for Parametric shapes, this can be a similar problem with non-ascii characters, but that's not a plugin of mine
For RoundCorner and possibly Curviloft, could you replace the following files in the SU Plugins directory
Fredo6_RoundCorner.rbFredo6_Curviloft.rb -
For Curviloft, there may be an additional problem.
Anyway, once this is solved, I will republish the scripts.
Thanks again
@fredo6 said:
Eozel,
[attachment=2:36qnwv6n]<!-- ia2 -->Fredo6_RoundCorner.rb<!-- ia2 -->[/attachment:36qnwv6n][attachment=1:36qnwv6n]<!-- ia1 -->Fredo6_Curviloft.rb<!-- ia1 -->[/attachment:36qnwv6n] -
Thanks again
Curviloft gives following error after i replaced the Fredo6_Curviloft.rb. Round cornet works with no problem.
Eozel,
Thanks.
For Curviloft, It may be due to a problem of installation in the Fredo6_Curviloft subfolder. Can you check that you have the following footprint.
Also, can you check the Trace Log as it should indicate an error on loading the bootstrap_Curviloft.rb file
With your input, this post could be even better š
