    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
    • E
      eozel
      @dave r said:
      Uninstalling and reinstalling sketchUp was an unneeded step.
      As for the Shapes plugin, where did you get it?
      While other plugings works well for the shapes plugin, it gives load error msg another computer of mine when sketchup is opennig.
        That didn't answer my question. šŸ˜’
        Just forget I asked about it.
        • E
          eozel
          404 Not Found
          (sketchucation.com)
          • fredo6F
            @eozel,
            At the moment, only LibFredo6 and FredoTools has been corrected for the problem of non-ascii characters.
            So are you sure you dont find it?
            • the menu is under Tools > FredoTools
            • there is a toolbar with a single icon showing F6
              404 Not Found
              (sketchucation.com)
              Try the version from the Extension Warehouse instead.
              • E
                eozel
                @fredo6 said:
                @eozel,
                There is no fredotools.
                • fredo6F
                  @eozel,
                  Could you show a screenshort of the "check For Updates" of LibFredo6.
                  Also, can you check the footprint of plugins in the SU Plugins directory where you installed.
                  • E
                    eozel
                    @fredo6 said:
                    @eozel,
                    • fredo6F
                      Eozel,
                      Thanks. There is also a Trace log utility in the LibFredo6 menu.
                      Could you check or send me the txt or a snapshot after expanding the list.
                      Also the date of last check (1 Jan 1970) seems to have a problem. I have to check
                      • E
                        eozel
                        @fredo6 said:
                        Eozel,
                        1413369931.22969;Fredo6_!LibFredo6.rb:71: in `log'
                        DATE / TIME: 2014-10-15 13:45:31 +0300
                        SKETCHUP VERSION: 14.1.1282
                        RUBY_PLATFORM: i386-mingw32
                        LOG FILE: LibFredo6Trace_14_1413369931228.txt
                        1413369931.22969;Fredo6_!LibFredo6.rb:113: in `startup'
                        LibFredo6: Starting up Fredo6_!LibFredo6.rb
                        1413369931.319277;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
                        Temp Files directory: C:/Users/EMREZE~1/AppData/Local/Temp
                        1413369931.351414;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
                        Default Parameters folder: C:/Users/EMREZE~1/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters
                        1413369931.385449;Fredo6_!LibFredo6.rb:173: in `startup'
                        LibFredo6: Beginning of loading Cycle***+
                        1413369931.4218082;Fredo6_!LibFredo6.rb:180: in `startup'
                        LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core.rb successfully loaded
                        1413369931.5345228;Lib6Core.rb:992: in `load_full_rubies'
                        LibFredo6 6.2a: Ruby files loaded [69 ms]
                        1413369931.56119;Lib6Core.rb:921: in `effective_load_part2'
                        LibFredo6 6.2a: Startup (creating menus and icons) [10 ms]
                        1413369931.586445;Fredo6_!LibFredo6.rb:189: in `startup'
                        LibFredo6: End of loading Cycle***-
                        1413369938.4396129;Lib6Plugin.rb:150: in `load_body'
                        Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [33 ms]
                        1413369938.539354;Lib6Core.rb:85: in `use_single_library'
                        Lib6G6.rb: Loading body code from body_Lib6G6.rb [80 ms]
                        1413369938.580538;Lib6Core.rb:85: in `use_single_library'
                        Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [20 ms]
                        1413369938.621686;Lib6Core.rb:85: in `use_single_library'
                        Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [20 ms]
                        1413369938.673656;Lib6Core.rb:85: in `use_single_library'
                        Lib6WebHtml.rb: Loading body code from body_Lib6WebHtml.rb [30 ms]
                        1413369938.770474;Lib6Core.rb:85: in `use_single_library'
                        Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [77 ms]
                        1413369938.835396;Lib6Core.rb:85: in `use_single_library'
                        Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [40 ms]
                        1413369938.882689;Lib6Core.rb:85: in `use_single_library'
                        Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [23 ms]
                        1413369938.916536;Lib6Core.rb:85: in `use_single_library'
                        Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [15 ms]
                        1413369938.9848142;Lib6Core.rb:85: in `use_single_library'
                        Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [49 ms]
                        1413369939.032744;Lib6Core.rb:85: in `use_single_library'
                        Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [22 ms]
                        1413369939.0687091;Lib6Plugin.rb:150: in `load_body'
                        Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [17 ms]
                        1413369939.1184819;Lib6Plugin.rb:150: in `load_body'
                        Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [25 ms]
                        1413369939.164896;Lib6Plugin.rb:150: in `load_body'
                        Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [25 ms]
                        • fredo6F
                          Very strange.
                          Could you do 2 things:
                          1. Type the following commands in the RubyConsole and tell me the result
                            LibFredo6.sudir
                            LibFredo6.path
                            LibFredo6.folder
                            LibFredo6.appdata_dir
                            LibFredo6.defparam_dir
                            defined?(FredoTools)
                          2. Remove the Fredo6_Fredotools.rb file (it is of no use actually, just for EWH compliance), exit and restart SU and see if you see FredoTools now
                          Thanks and sorry for these problems. You support is helpful
                          • E
                            eozel
                            @fredo6 said:
                            Very strange.
                              LibFredo6.sudir
                              LibFredo6.path
                              LibFredo6.folder
                            LibFredo6.sudir
                            C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                            LibFredo6.path
                            C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6
                            LibFredo6.folder
                            Fredo6_!LibFredo6
                            nil
                            1. I removed Fredo6_Fredotools.rb file, exited and restarted SU. But there is not fredotools.
                            I think there is another problem on my pc or windows settings, etc.
                            Thanks for your supports
                            • fredo6F
                              Thanks.
                              Could you show the footprint of the Fredo6_FredoTools folder. You may simply have a file missing (with extension .plugin).
                              • E
                                eozel
                                @fredo6 said:
                                Thanks.
                                • fredo6F
                                  Eozel,
                                  I think I found the problem.
                                  To be sure, could you copy the attached file into the Fredo6!_LibFredo6 subfolder and restart SU
                                  Lib6Core.rb
                                  Thanks in advance
                                  • E
                                    eozel
                                    @fredo6 said:
                                    Eozel,
                                    [attachment=2:3s9bb5jv]<!-- ia2 -->Lib6Core.rb<!-- ia2 -->[/attachment:3s9bb5jv]
                                    Thanks in advance
                                    Fredotools now can ben seen in tools menu:)).
                                    After than i install roundcorner it is working too but when opening the SU it give error below.
                                    Then i install Su draw parametric shape 2.27 but it gives error too which is given below. Error Loading File C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb
                                    Error: cannot load such file -- C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/parametric.rb
                                    C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                    C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb:8:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                                    C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in register_extension'
                                    C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in <module:Shapes>' C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:12:in module:JWM'
                                    C:/Users/emre ƶzel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:11:in `<top (required)>'
                                    Curviloft gives errors too.
                                    • fredo6F
                                      Eozel,
                                      Thanks very much. We are progressing
                                      1. for Parametric shapes, this can be a similar problem with non-ascii characters, but that's not a plugin of mine
                                      2. For RoundCorner and possibly Curviloft, could you replace the following files in the SU Plugins directory
                                        Fredo6_RoundCorner.rbFredo6_Curviloft.rb
                                      3. For Curviloft, there may be an additional problem.
                                      Anyway, once this is solved, I will republish the scripts.
                                      Thanks again
                                      • E
                                        eozel
                                        @fredo6 said:
                                        Eozel,
                                          [attachment=2:36qnwv6n]<!-- ia2 -->Fredo6_RoundCorner.rb<!-- ia2 -->[/attachment:36qnwv6n][attachment=1:36qnwv6n]<!-- ia1 -->Fredo6_Curviloft.rb<!-- ia1 -->[/attachment:36qnwv6n]
                                        Thanks again
                                        Curviloft gives following error after i replaced the Fredo6_Curviloft.rb. Round cornet works with no problem.
                                        • fredo6F
                                          Eozel,
                                          Thanks.
                                          For Curviloft, It may be due to a problem of installation in the Fredo6_Curviloft subfolder. Can you check that you have the following footprint.
                                          Also, can you check the Trace Log as it should indicate an error on loading the bootstrap_Curviloft.rb file
                                          • E
                                            eozel
                                            @fredo6 said:
                                            Eozel,
                                            Thanks.
                                            [attachment=1:1fbh2u6z]<!-- ia1 -->Curviloft 1.png<!-- ia1 -->[/attachment:1fbh2u6z]
                                            1413537183.466945;Fredo6_!LibFredo6.rb:71: in `log'
                                            DATE / TIME: 2014-10-17 12:13:03 +0300
                                            LOG FILE: LibFredo6Trace_14_1413537183465.txt
                                            1413537183.465944;Fredo6_!LibFredo6.rb:113: in `startup'
                                            1413537183.5357492;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
                                            1413537183.5638778;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
                                            1413537183.589764;Fredo6_!LibFredo6.rb:173: in `startup'
                                            1413537183.646673;Fredo6_!LibFredo6.rb:180: in `startup'
                                            1413537183.840369;Lib6Core.rb:992: in `load_full_rubies'
                                            LibFredo6 6.2a: Ruby files loaded [96 ms]
                                            1413537183.888124;Lib6Core.rb:921: in `effective_load_part2'
                                            LibFredo6 6.2a: Startup (creating menus and icons) [24 ms]
                                            1413537184.057875;Lib6Core.rb:992: in `load_full_rubies'
                                            Curviloft 1.3a: Ruby files loaded [71 ms]
                                            1413537184.080328;Lib6Core.rb:913: in rescue in block in effective_load_part2' ?Curviloft 1.3a: Error starting up plugin (creating menus and icons) undefined method startup' for F6_Curviloft:Module [in Lib6Core.rb - #`block in effective_load_part2(): line 909]
                                            1413537185.629963;Lib6Core.rb:992: in `load_full_rubies'
                                            FredoTools 2.1a: Ruby files loaded [33 ms]
                                            1413537185.659319;Lib6Plugin.rb:150: in `load_body'
                                            Lib6Material.rb: Loading body code from body_Lib6Material.rb [3 ms]
                                            1413537185.7227268;Lib6Core.rb:921: in `effective_load_part2'
                                            FredoTools 2.1a: Startup (creating menus and icons) [67 ms]
                                            1413537185.820959;Lib6Core.rb:963: in `load_bootstrap_rubies'
                                            RoundCorner 2.6a: Bootstrap Ruby files loaded [3 ms]
                                            1413537185.8898308;Lib6Core.rb:921: in `effective_load_part2'
                                            RoundCorner 2.6a: Startup (creating menus and icons) [42 ms]
                                            1413537185.916391;Fredo6_!LibFredo6.rb:189: in `startup'
                                            1413537200.377671;Lib6Plugin.rb:150: in `load_body'
                                            Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [28 ms]
                                            1413537200.46688;Lib6Core.rb:85: in `use_single_library'
                                            Lib6G6.rb: Loading body code from body_Lib6G6.rb [68 ms]
                                            1413537200.5250602;Lib6Core.rb:85: in `use_single_library'
                                            Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [34 ms]
                                            1413537200.5839438;Lib6Core.rb:85: in `use_single_library'
                                            Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [35 ms]
                                            1413537200.637125;Lib6Core.rb:85: in `use_single_library'
                                            1413537200.757068;Lib6Core.rb:85: in `use_single_library'
                                            Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [100 ms]
                                            1413537200.841938;Lib6Core.rb:85: in `use_single_library'
                                            Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [60 ms]
                                            1413537200.901935;Lib6Core.rb:85: in `use_single_library'
                                            Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [36 ms]
                                            1413537200.941764;Lib6Core.rb:85: in `use_single_library'
                                            Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [18 ms]
                                            1413537201.013798;Lib6Core.rb:85: in `use_single_library'
                                            Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [48 ms]
                                            1413537201.0753632;Lib6Core.rb:85: in `use_single_library'
                                            Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [34 ms]
                                            1413537201.117089;Lib6Plugin.rb:150: in `load_body'
                                            Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [19 ms]
                                            1413537201.184042;Lib6Plugin.rb:150: in `load_body'
                                            Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [43 ms]
                                            1413537201.233104;Lib6Plugin.rb:150: in `load_body'
                                            Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [20 ms]
                                            With your input, this post could be even better šŸ’—
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 113
                                            • 114
                                            • 43 / 114
