    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
      I've seen the same sort of message in the past. The solution that worked for me was to go to the Plugins folder and delete the LibFredo6 files including the folders. Then reinstall the fresh version from the Pluginstore.
      Evidently, some file wasn't getting overwritten when the newer version was installed over the old.
      • E
        eozel
        Thanks but I try to it more than 2 times, additionally i uninstalled sketchup and delete all files related with it. My problem comes from asci chracter of computer username. With new update of libfredo 6, libfredo 6 settings has been seen under windows menu. But plugings gives error whicg i said before msg.
        Additionally, another computer of mine (which hasn't got asci chracter of username) which i use libfredo 6 and most of plugins. But when i install shapes pluging, it start to give load error msg:
          Uninstalling and reinstalling sketchUp was an unneeded step.
          As for the Shapes plugin, where did you get it?
          • E
            eozel
            While other plugings works well for the shapes plugin, it gives load error msg another computer of mine when sketchup is opennig.
              That didn't answer my question. 😒
              Just forget I asked about it.
              • E
                eozel
                404 Not Found
                (sketchucation.com)
                • fredo6F
                  @eozel,
                  At the moment, only LibFredo6 and FredoTools has been corrected for the problem of non-ascii characters.
                  So are you sure you dont find it?
                  • the menu is under Tools > FredoTools
                  • there is a toolbar with a single icon showing F6
                    404 Not Found
                    (sketchucation.com)
                    Try the version from the Extension Warehouse instead.
                    • E
                      eozel
                      @fredo6 said:
                      @eozel,
                      There is no fredotools.
                      • fredo6F
                        @eozel,
                        Could you show a screenshort of the "check For Updates" of LibFredo6.
                        Also, can you check the footprint of plugins in the SU Plugins directory where you installed.
                        • E
                          eozel
                          @fredo6 said:
                          @eozel,
                          • fredo6F
                            Eozel,
                            Thanks. There is also a Trace log utility in the LibFredo6 menu.
                            Could you check or send me the txt or a snapshot after expanding the list.
                            Also the date of last check (1 Jan 1970) seems to have a problem. I have to check
                            • E
                              eozel
                              @fredo6 said:
                              Eozel,
                              1413369931.22969;Fredo6_!LibFredo6.rb:71: in `log'
                              DATE / TIME: 2014-10-15 13:45:31 +0300
                              SKETCHUP VERSION: 14.1.1282
                              RUBY_PLATFORM: i386-mingw32
                              LOG FILE: LibFredo6Trace_14_1413369931228.txt
                              1413369931.22969;Fredo6_!LibFredo6.rb:113: in `startup'
                              LibFredo6: Starting up Fredo6_!LibFredo6.rb
                              1413369931.319277;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
                              Temp Files directory: C:/Users/EMREZE~1/AppData/Local/Temp
                              1413369931.351414;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
                              Default Parameters folder: C:/Users/EMREZE~1/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters
                              1413369931.385449;Fredo6_!LibFredo6.rb:173: in `startup'
                              LibFredo6: Beginning of loading Cycle***+
                              1413369931.4218082;Fredo6_!LibFredo6.rb:180: in `startup'
                              LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core.rb successfully loaded
                              1413369931.5345228;Lib6Core.rb:992: in `load_full_rubies'
                              LibFredo6 6.2a: Ruby files loaded [69 ms]
                              1413369931.56119;Lib6Core.rb:921: in `effective_load_part2'
                              LibFredo6 6.2a: Startup (creating menus and icons) [10 ms]
                              1413369931.586445;Fredo6_!LibFredo6.rb:189: in `startup'
                              LibFredo6: End of loading Cycle***-
                              1413369938.4396129;Lib6Plugin.rb:150: in `load_body'
                              Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [33 ms]
                              1413369938.539354;Lib6Core.rb:85: in `use_single_library'
                              Lib6G6.rb: Loading body code from body_Lib6G6.rb [80 ms]
                              1413369938.580538;Lib6Core.rb:85: in `use_single_library'
                              Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [20 ms]
                              1413369938.621686;Lib6Core.rb:85: in `use_single_library'
                              Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [20 ms]
                              1413369938.673656;Lib6Core.rb:85: in `use_single_library'
                              Lib6WebHtml.rb: Loading body code from body_Lib6WebHtml.rb [30 ms]
                              1413369938.770474;Lib6Core.rb:85: in `use_single_library'
                              Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [77 ms]
                              1413369938.835396;Lib6Core.rb:85: in `use_single_library'
                              Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [40 ms]
                              1413369938.882689;Lib6Core.rb:85: in `use_single_library'
                              Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [23 ms]
                              1413369938.916536;Lib6Core.rb:85: in `use_single_library'
                              Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [15 ms]
                              1413369938.9848142;Lib6Core.rb:85: in `use_single_library'
                              Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [49 ms]
                              1413369939.032744;Lib6Core.rb:85: in `use_single_library'
                              Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [22 ms]
                              1413369939.0687091;Lib6Plugin.rb:150: in `load_body'
                              Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [17 ms]
                              1413369939.1184819;Lib6Plugin.rb:150: in `load_body'
                              Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [25 ms]
                              1413369939.164896;Lib6Plugin.rb:150: in `load_body'
                              Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [25 ms]
                              • fredo6F
                                Very strange.
                                Could you do 2 things:
                                1. Type the following commands in the RubyConsole and tell me the result
                                  LibFredo6.sudir
                                  LibFredo6.path
                                  LibFredo6.folder
                                  LibFredo6.appdata_dir
                                  LibFredo6.defparam_dir
                                  defined?(FredoTools)
                                2. Remove the Fredo6_Fredotools.rb file (it is of no use actually, just for EWH compliance), exit and restart SU and see if you see FredoTools now
                                Thanks and sorry for these problems. You support is helpful
                                • E
                                  eozel
                                  @fredo6 said:
                                  Very strange.
                                    LibFredo6.sudir
                                    LibFredo6.path
                                    LibFredo6.folder
                                  LibFredo6.sudir
                                  C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                                  LibFredo6.path
                                  C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6
                                  LibFredo6.folder
                                  Fredo6_!LibFredo6
                                  nil
                                  1. I removed Fredo6_Fredotools.rb file, exited and restarted SU. But there is not fredotools.
                                  I think there is another problem on my pc or windows settings, etc.
                                  Thanks for your supports
                                  • fredo6F
                                    Thanks.
                                    Could you show the footprint of the Fredo6_FredoTools folder. You may simply have a file missing (with extension .plugin).
                                    • E
                                      eozel
                                      @fredo6 said:
                                      Thanks.
                                      • fredo6F
                                        Eozel,
                                        I think I found the problem.
                                        To be sure, could you copy the attached file into the Fredo6!_LibFredo6 subfolder and restart SU
                                        Lib6Core.rb
                                        Thanks in advance
                                        • E
                                          eozel
                                          @fredo6 said:
                                          Eozel,
                                          [attachment=2:3s9bb5jv]<!-- ia2 -->Lib6Core.rb<!-- ia2 -->[/attachment:3s9bb5jv]
                                          Thanks in advance
                                          Fredotools now can ben seen in tools menu:)).
                                          After than i install roundcorner it is working too but when opening the SU it give error below.
                                          Then i install Su draw parametric shape 2.27 but it gives error too which is given below. Error Loading File C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb
                                          Error: cannot load such file -- C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/parametric.rb
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                          C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes/shapes.rb:8:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                                          C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in register_extension'
                                          C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:24:in <module:Shapes>' C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:12:in module:JWM'
                                          C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/jwm_shapes.rb:11:in `<top (required)>'
                                          Curviloft gives errors too.
                                          • fredo6F
                                            Eozel,
                                            Thanks very much. We are progressing
                                            1. for Parametric shapes, this can be a similar problem with non-ascii characters, but that's not a plugin of mine
                                            2. For RoundCorner and possibly Curviloft, could you replace the following files in the SU Plugins directory
                                              Fredo6_RoundCorner.rbFredo6_Curviloft.rb
                                            3. For Curviloft, there may be an additional problem.
                                            Anyway, once this is solved, I will republish the scripts.
                                            Thanks again
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 115
                                            • 116
                                            • 43 / 116
