    [REQ] Green Wall
    23 Posts 5 Posters 13.0k Views 5 Watching
    • bazB
      baz
      @srx said:
      Try using a few see through PNG textures on non - flat surfaces stacked like layers on small distance.
      What about the 'z Fighting' with surfaces so close.
      • KrisidiousK
        Krisidious
        Nice trick srx...
        here's a few with 3D Tree Maker.
        By: Kristoff Rand
        • KrisidiousK
          Krisidious
          I useually move a face about a 1/8th of an inch to 1/2 and inch and don't have issues with Z fighting.
          By: Kristoff Rand
          • bazB
            baz
            Gosh, I do. Further away, worse it gets.
            • KrisidiousK
              Krisidious
              are you working on house sized projects or large land sized or small object sized?
              By: Kristoff Rand
                You have also Sketchup Ivy by Pierreden ! β˜€
                http://i716.photobucket.com/albums/ww163/Onslaught869/ivy.jpg
                • bazB
                  baz
                  First and last, But I will get back to you, have to find a good example...
                  • bazB
                    baz
                    This roof tin is 12mm off the purlins. And at this distance it shows. Closer the z dispersers, for me at large or small tis a dimensional problem when I intend to accurate meas in layout.
                    I often spend time hiding edges, which solves the problem, (as long as you remember not to unhide when in the group).
                    • KrisidiousK
                      Krisidious
                      Oh yes... I get it anytime I have framing in the model. Something about the close proximity of vertices or something.I hide framing when I want to take a shot.
                      By: Kristoff Rand
                      • bazB
                        baz
                        Quote
                        "I hide framing"
                        Methinks I will have to stop being lazy with layers 😞
                        PS: check out some real advanced green walls here, disclaimer: I do stuff for them, but they are leading the field IMHO, really good technology and results.
                        http://www.fytogreen.com.au/vertical_gardens/projects.htm
                        • KrisidiousK
                          Krisidious
                          @baz said:
                          Quote
                          Very nice... Thanks for the resource.
                          By: Kristoff Rand
                            have you seen this post ? πŸ˜„
                            https://lh3.googleusercontent.com/3b0V4zYV-KLIKORww-59M26DOV9NmCuU58JjBH8GAf37ZWonM6Fh5NiA8tyjuYkNj4s06cm10NoH7SClcDfYhTlz91Aa8krrL58_BqhgPEpcJi4prAlD6-MITs3S-Y9yCEdFwSZjgag
                            • KrisidiousK
                              Krisidious
                              I saw their components on 3D warehouse... but they were 11 megs a piece.
                              By: Kristoff Rand
                              • BoxB
                                Baz that isn't Z-fighting it's part of opengl rendering.
                                An explanation and workarounds can be found here.
                                http://sketchucation.com/resources/tutorials/37-beginner/315-edges-bleeding-through-geometry
                                • KrisidiousK
                                  Krisidious
                                  Awesome Box... thanks.
                                  By: Kristoff Rand
                                  • bazB
                                    baz
                                    I knew that πŸ˜’ 😳
