    [REQ] Green Wall
    23 Posts 5 Posters 13.0k Views 5 Watching
    • KrisidiousK
      Krisidious
      Nice Pilou... thanks. I ended up going with just flat textures. I couldn't find anything to cover the area without it being massive poly.
      By: Kristoff Rand
        Something like (same surface and number)
          It's not so "massive" as it's "Instances" & "Proxies"! ๐Ÿ˜‰
          You can also try "Make Fur" by Tak2hata who results in a little more big file but very more speedy in using renderer! ๐Ÿ˜„
          • bazB
            baz
            I have struggled with this myself, even the lowest poly plants at this density will stall Su. My solution was to make up the plant areas in Su and export hires images to import into the model. Not ideal and required some touchup in PS.
            I haven't tried using proxies in Twilight or similar, could work as an overlay perhaps?
            Your image looks ok, perhaps you could 'Greeble' the plant planes to give them some depth/volume?
            Image exported from SU
            Plant images imported into SU
            • srxS
              srx
              Try using a few see through PNG textures on non - flat surfaces stacked like layers on small distance.
              www.saurus.rs
              • bazB
                baz
                What about the 'z Fighting' with surfaces so close.
                • KrisidiousK
                  Krisidious
                  Nice trick srx...
                  here's a few with 3D Tree Maker.
                  By: Kristoff Rand
                  • KrisidiousK
                    Krisidious
                    I useually move a face about a 1/8th of an inch to 1/2 and inch and don't have issues with Z fighting.
                    By: Kristoff Rand
                    • bazB
                      baz
                      Gosh, I do. Further away, worse it gets.
                      • KrisidiousK
                        Krisidious
                        are you working on house sized projects or large land sized or small object sized?
                        By: Kristoff Rand
                          You have also Sketchup Ivy by Pierreden ! โ˜€
                          http://i716.photobucket.com/albums/ww163/Onslaught869/ivy.jpg
                          • bazB
                            baz
                            First and last, But I will get back to you, have to find a good example...
                            • bazB
                              baz
                              This roof tin is 12mm off the purlins. And at this distance it shows. Closer the z dispersers, for me at large or small tis a dimensional problem when I intend to accurate meas in layout.
                              I often spend time hiding edges, which solves the problem, (as long as you remember not to unhide when in the group).
                              • KrisidiousK
                                Krisidious
                                Oh yes... I get it anytime I have framing in the model. Something about the close proximity of vertices or something.I hide framing when I want to take a shot.
                                By: Kristoff Rand
                                • bazB
                                  baz
                                  Quote
                                  "I hide framing"
                                  Methinks I will have to stop being lazy with layers ๐Ÿ˜ž
                                  PS: check out some real advanced green walls here, disclaimer: I do stuff for them, but they are leading the field IMHO, really good technology and results.
                                  http://www.fytogreen.com.au/vertical_gardens/projects.htm
                                  • KrisidiousK
                                    Krisidious
                                    @baz said:
                                    Quote
                                    Very nice... Thanks for the resource.
                                    By: Kristoff Rand
                                      have you seen this post ? ๐Ÿ˜„
                                      https://lh3.googleusercontent.com/3b0V4zYV-KLIKORww-59M26DOV9NmCuU58JjBH8GAf37ZWonM6Fh5NiA8tyjuYkNj4s06cm10NoH7SClcDfYhTlz91Aa8krrL58_BqhgPEpcJi4prAlD6-MITs3S-Y9yCEdFwSZjgag
                                      • KrisidiousK
                                        Krisidious
                                        I saw their components on 3D warehouse... but they were 11 megs a piece.
                                        By: Kristoff Rand
                                        • BoxB
                                          Baz that isn't Z-fighting it's part of opengl rendering.
                                          An explanation and workarounds can be found here.
                                          http://sketchucation.com/resources/tutorials/37-beginner/315-edges-bleeding-through-geometry
                                          • KrisidiousK
                                            Krisidious
                                            Awesome Box... thanks.
                                            By: Kristoff Rand
