    [REQ] Green Wall
    23 Posts 5 Posters 11.7k Views 5 Watching
      Tree maker has a cool green creation!
      • KrisidiousK Offline
        Krisidious
        Nice Pilou... thanks. I ended up going with just flat textures. I couldn't find anything to cover the area without it being massive poly.
        By: Kristoff Rand
          Something like (same surface and number)
            It's not so "massive" as it's "Instances" & "Proxies"! ๐Ÿ˜‰
            You can also try "Make Fur" by Tak2hata who results in a little more big file but very more speedy in using renderer! ๐Ÿ˜„
            • bazB Offline
              baz
              I have struggled with this myself, even the lowest poly plants at this density will stall Su. My solution was to make up the plant areas in Su and export hires images to import into the model. Not ideal and required some touchup in PS.
              I haven't tried using proxies in Twilight or similar, could work as an overlay perhaps?
              Your image looks ok, perhaps you could 'Greeble' the plant planes to give them some depth/volume?
              Image exported from SU
              Plant images imported into SU
              • srxS Offline
                srx
                Try using a few see through PNG textures on non - flat surfaces stacked like layers on small distance.
                www.saurus.rs
                • bazB Offline
                  baz
                  What about the 'z Fighting' with surfaces so close.
                    Krisidious
                    Nice trick srx...
                    here's a few with 3D Tree Maker.
                    By: Kristoff Rand
                      Krisidious
                      I useually move a face about a 1/8th of an inch to 1/2 and inch and don't have issues with Z fighting.
                      By: Kristoff Rand
                      • bazB Offline
                        baz
                        Gosh, I do. Further away, worse it gets.
                          Krisidious
                          are you working on house sized projects or large land sized or small object sized?
                          By: Kristoff Rand
                            You have also Sketchup Ivy by Pierreden ! โ˜€
                            http://i716.photobucket.com/albums/ww163/Onslaught869/ivy.jpg
                            • bazB Offline
                              baz
                              First and last, But I will get back to you, have to find a good example...
                              • bazB Offline
                                baz
                                This roof tin is 12mm off the purlins. And at this distance it shows. Closer the z dispersers, for me at large or small tis a dimensional problem when I intend to accurate meas in layout.
                                I often spend time hiding edges, which solves the problem, (as long as you remember not to unhide when in the group).
                                  Krisidious
                                  Oh yes... I get it anytime I have framing in the model. Something about the close proximity of vertices or something.I hide framing when I want to take a shot.
                                  By: Kristoff Rand
                                  • bazB Offline
                                    baz
                                    Quote
                                    "I hide framing"
                                    Methinks I will have to stop being lazy with layers ๐Ÿ˜ž
                                    PS: check out some real advanced green walls here, disclaimer: I do stuff for them, but they are leading the field IMHO, really good technology and results.
                                    http://www.fytogreen.com.au/vertical_gardens/projects.htm
                                      Krisidious
                                      @baz said:
                                      Quote
                                      Very nice... Thanks for the resource.
                                      By: Kristoff Rand
                                        have you seen this post ? ๐Ÿ˜„
                                        https://lh3.googleusercontent.com/3b0V4zYV-KLIKORww-59M26DOV9NmCuU58JjBH8GAf37ZWonM6Fh5NiA8tyjuYkNj4s06cm10NoH7SClcDfYhTlz91Aa8krrL58_BqhgPEpcJi4prAlD6-MITs3S-Y9yCEdFwSZjgag
                                          Krisidious
                                          I saw their components on 3D warehouse... but they were 11 megs a piece.
                                          By: Kristoff Rand
                                          • BoxB Offline
                                            Baz that isn't Z-fighting it's part of opengl rendering.
                                            An explanation and workarounds can be found here.
                                            http://sketchucation.com/resources/tutorials/37-beginner/315-edges-bleeding-through-geometry
