    [REQ] Green Wall
    23 Posts 5 Posters 13.0k Views 5 Watching
    • srxS
      srx
      Try using a few see through PNG textures on non - flat surfaces stacked like layers on small distance.
      www.saurus.rs
      • bazB
        baz
        What about the 'z Fighting' with surfaces so close.
        • KrisidiousK
          Krisidious
          Nice trick srx...
          here's a few with 3D Tree Maker.
          By: Kristoff Rand
          • KrisidiousK
            Krisidious
            I useually move a face about a 1/8th of an inch to 1/2 and inch and don't have issues with Z fighting.
            By: Kristoff Rand
            • bazB
              baz
              Gosh, I do. Further away, worse it gets.
              • KrisidiousK
                Krisidious
                are you working on house sized projects or large land sized or small object sized?
                By: Kristoff Rand
                  You have also Sketchup Ivy by Pierreden ! โ˜€
                  http://i716.photobucket.com/albums/ww163/Onslaught869/ivy.jpg
                  • bazB
                    baz
                    First and last, But I will get back to you, have to find a good example...
                    • bazB
                      baz
                      This roof tin is 12mm off the purlins. And at this distance it shows. Closer the z dispersers, for me at large or small tis a dimensional problem when I intend to accurate meas in layout.
                      I often spend time hiding edges, which solves the problem, (as long as you remember not to unhide when in the group).
                      • KrisidiousK
                        Krisidious
                        Oh yes... I get it anytime I have framing in the model. Something about the close proximity of vertices or something.I hide framing when I want to take a shot.
                        By: Kristoff Rand
                        • bazB
                          baz
                          Quote
                          "I hide framing"
                          Methinks I will have to stop being lazy with layers ๐Ÿ˜ž
                          PS: check out some real advanced green walls here, disclaimer: I do stuff for them, but they are leading the field IMHO, really good technology and results.
                          http://www.fytogreen.com.au/vertical_gardens/projects.htm
                          • KrisidiousK
                            Krisidious
                            @baz said:
                            Quote
                            Very nice... Thanks for the resource.
                            By: Kristoff Rand
                              have you seen this post ? ๐Ÿ˜„
                              https://lh3.googleusercontent.com/3b0V4zYV-KLIKORww-59M26DOV9NmCuU58JjBH8GAf37ZWonM6Fh5NiA8tyjuYkNj4s06cm10NoH7SClcDfYhTlz91Aa8krrL58_BqhgPEpcJi4prAlD6-MITs3S-Y9yCEdFwSZjgag
                              • KrisidiousK
                                Krisidious
                                I saw their components on 3D warehouse... but they were 11 megs a piece.
                                By: Kristoff Rand
                                • BoxB
                                  Baz that isn't Z-fighting it's part of opengl rendering.
                                  An explanation and workarounds can be found here.
                                  http://sketchucation.com/resources/tutorials/37-beginner/315-edges-bleeding-through-geometry
                                  • KrisidiousK
                                    Krisidious
                                    Awesome Box... thanks.
                                    By: Kristoff Rand
                                    • bazB
                                      baz
                                      I knew that ๐Ÿ˜’ ๐Ÿ˜ณ
