    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [REQ] Green Wall
    23 Posts 5 Posters 11.5k Views 5 Watching
    • KrisidiousK Offline
      Krisidious
      I'm in search of some good quality, visually pleasing, low poly Green Wall components. I suppose this would be something better done in an after market software like Vue or Lumen, but I'd like something inside SketchUp. Anyone know of anything?
      https://www.google.com/search?q=green+wall%26amp;biw=1460%26amp;bih=819%26amp;source=lnms%26amp;tbm=isch%26amp;sa=X%26amp;ei=4xA4VJbAHNewyASAq4LAAg%26amp;ved=0CAYQ_AUoAQ#facrc=%26amp;imgdii=%26amp;imgrc=UPFPkTPrqbKEOM%253A%3BC45QP1MIiCGBmM%3Bhttp%253A%252F%252Fwww.tjsl.edu%252Fsites%252Fdefault%252Ffiles%252Fwebsite_photo.jpg%3Bhttp%253A%252F%252Fwww.tjsl.edu%252Fnode%252F2395%3B4368%3B2912
      By: Kristoff Rand
        Tree maker has a cool green creation!
          Krisidious
          Nice Pilou... thanks. I ended up going with just flat textures. I couldn't find anything to cover the area without it being massive poly.
          By: Kristoff Rand
            Something like (same surface and number)
              It's not so "massive" as it's "Instances" & "Proxies"! ๐Ÿ˜‰
              You can also try "Make Fur" by Tak2hata who results in a little more big file but very more speedy in using renderer! ๐Ÿ˜„
              • bazB Offline
                baz
                I have struggled with this myself, even the lowest poly plants at this density will stall Su. My solution was to make up the plant areas in Su and export hires images to import into the model. Not ideal and required some touchup in PS.
                I haven't tried using proxies in Twilight or similar, could work as an overlay perhaps?
                Your image looks ok, perhaps you could 'Greeble' the plant planes to give them some depth/volume?
                Image exported from SU
                Plant images imported into SU
                • srxS Offline
                  srx
                  Try using a few see through PNG textures on non - flat surfaces stacked like layers on small distance.
                  www.saurus.rs
                  • bazB Offline
                    baz
                    What about the 'z Fighting' with surfaces so close.
                      Krisidious
                      Nice trick srx...
                      here's a few with 3D Tree Maker.
                      By: Kristoff Rand
                        Krisidious
                        I useually move a face about a 1/8th of an inch to 1/2 and inch and don't have issues with Z fighting.
                        By: Kristoff Rand
                        • bazB Offline
                          baz
                          Gosh, I do. Further away, worse it gets.
                            Krisidious
                            are you working on house sized projects or large land sized or small object sized?
                            By: Kristoff Rand
                              You have also Sketchup Ivy by Pierreden ! โ˜€
                              http://i716.photobucket.com/albums/ww163/Onslaught869/ivy.jpg
                              • bazB Offline
                                baz
                                First and last, But I will get back to you, have to find a good example...
                                • bazB Offline
                                  baz
                                  This roof tin is 12mm off the purlins. And at this distance it shows. Closer the z dispersers, for me at large or small tis a dimensional problem when I intend to accurate meas in layout.
                                  I often spend time hiding edges, which solves the problem, (as long as you remember not to unhide when in the group).
                                    Krisidious
                                    Oh yes... I get it anytime I have framing in the model. Something about the close proximity of vertices or something.I hide framing when I want to take a shot.
                                    By: Kristoff Rand
                                    • bazB Offline
                                      baz
                                      Quote
                                      "I hide framing"
                                      Methinks I will have to stop being lazy with layers ๐Ÿ˜ž
                                      PS: check out some real advanced green walls here, disclaimer: I do stuff for them, but they are leading the field IMHO, really good technology and results.
                                      http://www.fytogreen.com.au/vertical_gardens/projects.htm
                                        Krisidious
                                        @baz said:
                                        Quote
                                        Very nice... Thanks for the resource.
                                        By: Kristoff Rand
                                          have you seen this post ? ๐Ÿ˜„
                                          https://lh3.googleusercontent.com/3b0V4zYV-KLIKORww-59M26DOV9NmCuU58JjBH8GAf37ZWonM6Fh5NiA8tyjuYkNj4s06cm10NoH7SClcDfYhTlz91Aa8krrL58_BqhgPEpcJi4prAlD6-MITs3S-Y9yCEdFwSZjgag
                                            Krisidious
                                            I saw their components on 3D warehouse... but they were 11 megs a piece.
                                            By: Kristoff Rand
