    [REQ] Green Wall
    23 Posts 5 Posters 13.0k Views 5 Watching
      Something like (same surface and number)
        It's not so "massive" as it's "Instances" & "Proxies"! πŸ˜‰
        You can also try "Make Fur" by Tak2hata who results in a little more big file but very more speedy in using renderer! πŸ˜„
        • bazB
          baz
          I have struggled with this myself, even the lowest poly plants at this density will stall Su. My solution was to make up the plant areas in Su and export hires images to import into the model. Not ideal and required some touchup in PS.
          I haven't tried using proxies in Twilight or similar, could work as an overlay perhaps?
          Your image looks ok, perhaps you could 'Greeble' the plant planes to give them some depth/volume?
          Image exported from SU
          Plant images imported into SU
          • srxS
            srx
            Try using a few see through PNG textures on non - flat surfaces stacked like layers on small distance.
            www.saurus.rs
            • bazB
              baz
              What about the 'z Fighting' with surfaces so close.
              • KrisidiousK
                Krisidious
                Nice trick srx...
                here's a few with 3D Tree Maker.
                By: Kristoff Rand
                • KrisidiousK
                  Krisidious
                  I useually move a face about a 1/8th of an inch to 1/2 and inch and don't have issues with Z fighting.
                  By: Kristoff Rand
                  • bazB
                    baz
                    Gosh, I do. Further away, worse it gets.
                    • KrisidiousK
                      Krisidious
                      are you working on house sized projects or large land sized or small object sized?
                      By: Kristoff Rand
                        You have also Sketchup Ivy by Pierreden ! β˜€
                        http://i716.photobucket.com/albums/ww163/Onslaught869/ivy.jpg
                        • bazB
                          baz
                          First and last, But I will get back to you, have to find a good example...
                          • bazB
                            baz
                            This roof tin is 12mm off the purlins. And at this distance it shows. Closer the z dispersers, for me at large or small tis a dimensional problem when I intend to accurate meas in layout.
                            I often spend time hiding edges, which solves the problem, (as long as you remember not to unhide when in the group).
                            • KrisidiousK
                              Krisidious
                              Oh yes... I get it anytime I have framing in the model. Something about the close proximity of vertices or something.I hide framing when I want to take a shot.
                              By: Kristoff Rand
                              • bazB
                                baz
                                Quote
                                "I hide framing"
                                Methinks I will have to stop being lazy with layers 😞
                                PS: check out some real advanced green walls here, disclaimer: I do stuff for them, but they are leading the field IMHO, really good technology and results.
                                http://www.fytogreen.com.au/vertical_gardens/projects.htm
                                • KrisidiousK
                                  Krisidious
                                  @baz said:
                                  Quote
                                  Very nice... Thanks for the resource.
                                  By: Kristoff Rand
                                    have you seen this post ? πŸ˜„
                                    https://lh3.googleusercontent.com/3b0V4zYV-KLIKORww-59M26DOV9NmCuU58JjBH8GAf37ZWonM6Fh5NiA8tyjuYkNj4s06cm10NoH7SClcDfYhTlz91Aa8krrL58_BqhgPEpcJi4prAlD6-MITs3S-Y9yCEdFwSZjgag
                                    • KrisidiousK
                                      Krisidious
                                      I saw their components on 3D warehouse... but they were 11 megs a piece.
                                      By: Kristoff Rand
                                      • BoxB
                                        Baz that isn't Z-fighting it's part of opengl rendering.
                                        An explanation and workarounds can be found here.
                                        http://sketchucation.com/resources/tutorials/37-beginner/315-edges-bleeding-through-geometry
                                        • KrisidiousK
                                          Krisidious
                                          Awesome Box... thanks.
                                          By: Kristoff Rand
                                          • bazB
                                            baz
                                            I knew that πŸ˜’ 😳
