    [REQ] Green Wall
    23 Posts 5 Posters 12.6k Views 5 Watching
    • bazB
      baz
      I have struggled with this myself, even the lowest poly plants at this density will stall Su. My solution was to make up the plant areas in Su and export hires images to import into the model. Not ideal and required some touchup in PS.
      I haven't tried using proxies in Twilight or similar, could work as an overlay perhaps?
      Your image looks ok, perhaps you could 'Greeble' the plant planes to give them some depth/volume?
      Image exported from SU
      Plant images imported into SU
      • srxS
        srx
        Try using a few see through PNG textures on non - flat surfaces stacked like layers on small distance.
        www.saurus.rs
        • bazB
          baz
          What about the 'z Fighting' with surfaces so close.
          • KrisidiousK
            Krisidious
            Nice trick srx...
            here's a few with 3D Tree Maker.
            By: Kristoff Rand
            • KrisidiousK
              Krisidious
              I useually move a face about a 1/8th of an inch to 1/2 and inch and don't have issues with Z fighting.
              By: Kristoff Rand
              • bazB
                baz
                Gosh, I do. Further away, worse it gets.
                • KrisidiousK
                  Krisidious
                  are you working on house sized projects or large land sized or small object sized?
                  By: Kristoff Rand
                    You have also Sketchup Ivy by Pierreden ! โ˜€
                    http://i716.photobucket.com/albums/ww163/Onslaught869/ivy.jpg
                    • bazB
                      baz
                      First and last, But I will get back to you, have to find a good example...
                      • bazB
                        baz
                        This roof tin is 12mm off the purlins. And at this distance it shows. Closer the z dispersers, for me at large or small tis a dimensional problem when I intend to accurate meas in layout.
                        I often spend time hiding edges, which solves the problem, (as long as you remember not to unhide when in the group).
                        • KrisidiousK
                          Krisidious
                          Oh yes... I get it anytime I have framing in the model. Something about the close proximity of vertices or something.I hide framing when I want to take a shot.
                          By: Kristoff Rand
                          • bazB
                            baz
                            Quote
                            "I hide framing"
                            Methinks I will have to stop being lazy with layers ๐Ÿ˜ž
                            PS: check out some real advanced green walls here, disclaimer: I do stuff for them, but they are leading the field IMHO, really good technology and results.
                            http://www.fytogreen.com.au/vertical_gardens/projects.htm
                            • KrisidiousK
                              Krisidious
                              @baz said:
                              Quote
                              Very nice... Thanks for the resource.
                              By: Kristoff Rand
                                have you seen this post ? ๐Ÿ˜„
                                https://lh3.googleusercontent.com/3b0V4zYV-KLIKORww-59M26DOV9NmCuU58JjBH8GAf37ZWonM6Fh5NiA8tyjuYkNj4s06cm10NoH7SClcDfYhTlz91Aa8krrL58_BqhgPEpcJi4prAlD6-MITs3S-Y9yCEdFwSZjgag
                                • KrisidiousK
                                  Krisidious
                                  I saw their components on 3D warehouse... but they were 11 megs a piece.
                                  By: Kristoff Rand
                                  • BoxB
                                    Baz that isn't Z-fighting it's part of opengl rendering.
                                    An explanation and workarounds can be found here.
                                    http://sketchucation.com/resources/tutorials/37-beginner/315-edges-bleeding-through-geometry
                                    • KrisidiousK
                                      Krisidious
                                      Awesome Box... thanks.
                                      By: Kristoff Rand
                                      • bazB
                                        baz
                                        I knew that ๐Ÿ˜’ ๐Ÿ˜ณ
