    [REQ] Ctrl+Push pull without internal faces
    21 Posts 6 Posters 875 Views 6 Watching
    • cottyC Offline
      cotty
      There is a plugin Remove Inner Faces for
      Removes unwanted internal faces in a selection as a result of using CTRL+PushPull
      my SketchUp gallery
      • PixeroP Offline
        Pixero
        Yes I know of these workaround solutions but I would like to have it as a stand alone tool for better workflow. Running a clean up script might erase things you actually want to be kept also.
          does artisan push/pull not do as you ask?
            Well, then, use Rich's suggestion. It works fine although I think it is a little slower than my method of copying edges. I don't really consider copying the edges a work around.
            • PixeroP Offline
              Pixero
              Yes, but as it is part of a commercial script it won't suit the workflow I'm trying to create for our firm with lots of users. 😐
              Buying Artisan for all of them just to get this functionality is not a solution.
              I'm thinking maybe it's possible to create such a tool.
              Is there a way of testing for internal faces while doing a pushpull in ruby?
                Then I think it is best to ask Fredo if his PushPull suite would have such an option.
                He just about does on toggle of CTRL except he create the face and loop
                • JQLJ Offline
                  JQL
                  But it does it already Rich.
                  • Normal push pull
                  • Erase original faces
                  • Faces on contours
                  With all the bells and whistles that also come with it...
                  www.casca.pt
                  Visit us on facebook!
                  • KrisidiousK Offline
                    Krisidious
                    You had me excited for a minute... I was hoping for a version that doesn't flip the original push face to a backface. When I create walls and such I always get backfaces on the outside of and on top of walls.
                    By: Kristoff Rand
                      You don't have to create that problem for yourself. πŸ˜‰
                        @jql
                        I must admit I tried every tool but missed that combination.
                        Apologies to Fredo
                          Krisidious
                          I don't really see your point Dave. It's not really up/normal that's my problem, but negative push from the front. I pull all my walls up and then push back down for header and door/widow height. I've learned to pull doors and windows up separately to stop this from happening but it increases workflow.
                          By: Kristoff Rand
                            @jql
                            Apologies to Fredo
                              That's weird?
                              My reply posted twice with a three hour interval?
                                Kris, Push/Pull is doing what it should in those cases. Get rid of the floor inside the walls and it won't give you the reversed faces.
                                I thought you and I went through this a few years back and had you had it all sorted out.
                                  Krisidious
                                  You're thinking of the wrong face. The top face extruding downwards. it's already a front face and when I extrude it (push/pull) it downwards it flips the top face to a back face.
                                  By: Kristoff Rand
                                    Krisidious
                                    My point is that any face should retain its front/back status when push pulled.
                                    By: Kristoff Rand
                                    • 2 / 2
