    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • P
      pgarmyn
      @youemailme said:
      Unfortunately, no matter what I do, I can't get audio on any of the videos.
      Nothing is wrong, there is no sound.
      Do you want me to sing ? 😄
      Please read the pdf doc.
      • tt_suT
        tt_su
        😆 Yes! I do!
        • Y
          youemailme
          I don't know how good a voice you have, so I suppose not. Guess that explains why there's no sound! I saw that someone complained about how fast they were, but I figured it wouldn't matter if I could hear what you were saying. Makes the pdf all the more indispensable. I'll watch the vids again after I study the pdf....
          • P
            pgarmyn
            @ youemailme & tt_su
            sorry,, english is not my mother tongue...
            I will make some slow 'how to' videos with text.
            I will be on holiday the next three weeks ..... 😎
            • Y
              youemailme
              No apologies necessary! I'm in awe of anyone that can write plug-ins like this, while still carrying on a "day job"! No rush, and thanks again for your contribution to the world of SketchUp!
              • SkalpS
                Skalp
                To make a decent plugin take a lot of work. And it's much more than having an idea and writing a little bit of ruby code. That is the easy part. But testing it. Because it should run on all version of windows and os x, and on all versions of sketchup. It can conflict with other plugins. And the userinterface had to be easy to use too. Oh did I mension there are all kind of browsers and they are different on win and mac and the UI is depended on these browsers. Than there is documentation. The user want a manual and tutorial movies. You should give support on it and a lot of support as nothing to do with your plugin itself but is an os, sketchup or browser issue... Or just stupidity of the user (oh yes I switched of showing images in my browser yesterday, now I understand why your webdialog isn't showing icons anymore... But this is after a join.me session of half an hour.)
                Most of the plugins make money for the users by saving a lot of time. Please respect the developers and support there efforts by paying for there hard work.
                Skalp
                http://www.skalp4sketchup.com
                • C
                  caronte01
                  Hi Piet,
                  Here's a small sample of recent work using your plugin. All these are 100% sketchup/layout.
                  Thanks a lot!
                  Santiago
                  • P
                    pgarmyn
                    UPDATE 0.5.0 published in the Sketchucation PLUGINSTORE HERE
                    • P
                      pgarmyn
                      @caronte01 said:
                      Hi Piet,
                      Thanks a lot!
                      Santiago
                      Good work !!!
                      • P
                        pgarmyn
                        KNOWN ISSUE:
                        RichSections created with older versions must be updated manually.
                        I will work on it to fix that.
                        • P
                          priestonaray
                          trying to install this extension on my SU2014 but cannot find this on my toolbar, and every time i restart SU, it shows:
                          Error: #<LoadError: cannot load such file -- fileutils.rb>
                          c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:133:in require' c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:133:in module:PiGaRSection'
                          c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:106:in <main>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in eval'
                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in require' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in module:PiGa'
                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:3:in <top (required)>' C:/PROGRA~1/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                          C:/PROGRA~1/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:40:in register_extension'
                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:40:in <module:PiGa>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:17:in <top (required)>'
                          any idea?
                            The fileutils.rb is a standard file found in the RubyStdLib subfolder within the SketchUp Tools.
                            It does not auto-load when SketchUp starts, BUT can be required thus:
                            require "fileutils.rb"
                            Since the path to the RubyStdLib subfolder should be auto-added to the $: the .rb should be found in that folder.
                            Obviously something is failing...
                            Check a few things...
                            Is the RubyStdLib subfolder within the SketchUp Tools ?
                            Does it contain a file named fileutils.rb ?
                            If not reinstall SketchUp v2014 [latest version]...
                            Is the path to RubyStdLib included in the $: ? To check that you just type $: in the Ruby Console...
                            If you type require "fileutils.rb" in the Ruby Console what is the result ?
                            Report back...
                            • P
                              pgarmyn
                              UPDATE 0.5.1 published in the Sketchucation PLUGINSTORE HERE
                              RichSections created with an older plugin version don't need manual update any more (bug in 0.5.0) when changing the sectionplan
                              • KrisidiousK
                                Krisidious
                                Thanks pgarmyn...
                                By: Kristoff Rand
                                • P
                                  priestonaray
                                  Report back...
                                  Is the RubyStdLib subfolder within the SketchUp Tools ?yes
                                  Does it contain a file named fileutils.rb ? yes
                                  If not reinstall SketchUp v2014 [latest version]... 14.0.49
                                  Is the path to RubyStdLib included in the $: ? To check that you just type $: in the Ruby Console... i don't think so
                                  If you type require "fileutils.rb" in the Ruby Console what is the result ? false
                                  • C
                                    caronte01
                                    Hi Piet,
                                    I´m having some issues with this new version 0.5.1
                                    When I right click on a rs to update it, I get the new dialog, and then after a second right click, I can update it. Previously, on the first right click, I was able to update the section directly.
                                    The other thing is that, once the new dialog (which looks great btw, big improvement over the previous one), takes the focus, the main window can be orbited, but not zoomed in/out. This happens without notice, so that results in apparent sluggish navigation. Is there a way to switch between modal and non modal dialogs? It may be a matter of personal preference, but I like to have all these aux windows go away once they have served their purpose. This would avoid the first problem.
                                    Other than that, I´ve had no issues with this new version. I´ll keep testing.
                                    Thank you!
                                    Santiago
                                    • P
                                      pgarmyn
                                      Fileutils is used by my plugin, but it is part of the standard library since Sketchup 2014.
                                      Did you reinstall Sketchup ? (Even if you have the latest)
                                      Tell me....
                                      • P
                                        pgarmyn
                                        @caronte01 said:
                                        Hi Piet,
                                        Thank you!
                                        Santiago
                                        About zooming : If you click on the titlebar of the Sketchup-window, the main window will have the scope, and zoom-behaviour will be normal.
                                        About updating with one click: Yes my context-menu is buggy. I will work on it. But instant update is still possible if you use the update button on the panel, and then click on the sectionplan or Richsection group.
                                        About non-modal or modal dialog: The idea was to use a non modal dialog to allow the creation of materials, scenes.... to use within the RichSection. If necessary i will switch back to modal, or let you the chose, but first give me last chance to try the non-model way.
                                        Thanks for testing Santiago!
                                        • C
                                          cesaro36
                                          Hi Piet
                                          Since the last UI interface I can't get my sections to update (no section name change). These are the errors shown:
                                          Error: #<ArgumentError: 'DarkRed' not valid values in list.>
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/listbox.rb:238:in value=' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSpanel.rb:583:in block in create'
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in call' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in block in trigger_event'
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in each' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in trigger_event'
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:358:in event_control_callback' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:312:in callback_handler'
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:270:in block in add_callback' -e:1:in call'
                                          • P
                                            pgarmyn
                                            @cesaro36 said:
                                            Hi Piet
                                            What is your SU version, what windows or mac version ?
                                            It seems that 'DarkRed' (Sketchup color or material) doesn't exist on your computer.
                                            What happens if you make a material 'DarkRed' before opening the RichSection panel?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 15 / 20
