    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 152.0k Views 85 Watching
      pgarmyn
      @pgarmyn said:
      UPDATE 0.5.0 published in the Sketchucation PLUGINSTORE HERE
      KNOWN ISSUE:
      RichSections created with older versions must be updated manually.
      I will work on it to fix that.
        priestonaray
        trying to install this extension on my SU2014 but cannot find this on my toolbar, and every time i restart SU, it shows:
        Error: #<LoadError: cannot load such file -- fileutils.rb>
        c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:133:in require' c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:133:in module:PiGaRSection'
        c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:106:in <main>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in eval'
        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in require' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in module:PiGa'
        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:3:in <top (required)>' C:/PROGRA~1/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
        C:/PROGRA~1/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:40:in register_extension'
        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:40:in <module:PiGa>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:17:in <top (required)>'
        any idea?
          The fileutils.rb is a standard file found in the RubyStdLib subfolder within the SketchUp Tools.
          It does not auto-load when SketchUp starts, BUT can be required thus:
          require "fileutils.rb"
          Since the path to the RubyStdLib subfolder should be auto-added to the $: the .rb should be found in that folder.
          Obviously something is failing...
          Check a few things...
          Is the RubyStdLib subfolder within the SketchUp Tools ?
          Does it contain a file named fileutils.rb ?
          If not reinstall SketchUp v2014 [latest version]...
          Is the path to RubyStdLib included in the $: ? To check that you just type $: in the Ruby Console...
          If you type require "fileutils.rb" in the Ruby Console what is the result ?
          Report back...
            pgarmyn
            UPDATE 0.5.1 published in the Sketchucation PLUGINSTORE HERE
            RichSections created with an older plugin version don't need manual update any more (bug in 0.5.0) when changing the sectionplan
            • KrisidiousK Offline
              Krisidious
              Thanks pgarmyn...
              By: Kristoff Rand
                priestonaray
                Report back...
                Is the RubyStdLib subfolder within the SketchUp Tools ?yes
                Does it contain a file named fileutils.rb ? yes
                If not reinstall SketchUp v2014 [latest version]... 14.0.49
                Is the path to RubyStdLib included in the $: ? To check that you just type $: in the Ruby Console... i don't think so
                If you type require "fileutils.rb" in the Ruby Console what is the result ? false
                  caronte01
                  Hi Piet,
                  I“m having some issues with this new version 0.5.1
                  When I right click on a rs to update it, I get the new dialog, and then after a second right click, I can update it. Previously, on the first right click, I was able to update the section directly.
                  The other thing is that, once the new dialog (which looks great btw, big improvement over the previous one), takes the focus, the main window can be orbited, but not zoomed in/out. This happens without notice, so that results in apparent sluggish navigation. Is there a way to switch between modal and non modal dialogs? It may be a matter of personal preference, but I like to have all these aux windows go away once they have served their purpose. This would avoid the first problem.
                  Other than that, I“ve had no issues with this new version. I“ll keep testing.
                  Thank you!
                  Santiago
                    pgarmyn
                    Fileutils is used by my plugin, but it is part of the standard library since Sketchup 2014.
                    Did you reinstall Sketchup ? (Even if you have the latest)
                    Tell me....
                      pgarmyn
                      @caronte01 said:
                      Hi Piet,
                      Thank you!
                      Santiago
                      About zooming : If you click on the titlebar of the Sketchup-window, the main window will have the scope, and zoom-behaviour will be normal.
                      About updating with one click: Yes my context-menu is buggy. I will work on it. But instant update is still possible if you use the update button on the panel, and then click on the sectionplan or Richsection group.
                      About non-modal or modal dialog: The idea was to use a non modal dialog to allow the creation of materials, scenes.... to use within the RichSection. If necessary i will switch back to modal, or let you the chose, but first give me last chance to try the non-model way.
                      Thanks for testing Santiago!
                        cesaro36
                        Hi Piet
                        Since the last UI interface I can't get my sections to update (no section name change). These are the errors shown:
                        Error: #<ArgumentError: 'DarkRed' not valid values in list.>
                        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/listbox.rb:238:in value=' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSpanel.rb:583:in block in create'
                        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in call' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in block in trigger_event'
                        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in each' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in trigger_event'
                        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:358:in event_control_callback' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:312:in callback_handler'
                        C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:270:in block in add_callback' -e:1:in call'
                          pgarmyn
                          @cesaro36 said:
                          Hi Piet
                          What is your SU version, what windows or mac version ?
                          It seems that 'DarkRed' (Sketchup color or material) doesn't exist on your computer.
                          What happens if you make a material 'DarkRed' before opening the RichSection panel?
                            pgarmyn
                            RichSection UPDATE 0.5.3 is published on the Sketchucation PLUGINSTORE HERE
                            Release Notes for RichSection V0.5.3
                            • bugs on panel removed (?)
                            • to prevent issues on Mac : don't open multiple models; close and reopen the RS-panel when opening a model
                              bimbachi
                              hello,
                              (mac version) i'm having only 2 materials default and black?
                              shall i change something ?
                                pgarmyn
                                @bimbachi said:
                                hello,
                                Hy bimbachi
                                To load automatically 14 predefined hatches
                                • In RichSection/settings : Load materials .... :
                                  replace "materials/RichSection-v0.3/#default.mat.skp"
                                  by "materials/RichSection-v0.3/RS_V0_14.mat.skp"
                                • For new models : 14 materials will be loaded at the first RS creation
                                • In models with RichSections : delete the "#default" material and create a new RichSection
                                šŸ˜‰
                                  caronte01
                                  Hi Piet,
                                  I've been using your latest version.
                                  I'm having some issues:
                                  The main rs dialog contracts to a size smaller than it's intended one. Text overlaps, and some buttons will dissapear. This happens a lot when creating new rs, not when editing existing ones.
                                  Section name has to be changed two times, when creating rs. The first time will default to #00x. The second time, the corrresponding layer will change it's name, the section has to be renamed manually. In setttings, I have rs create 1 scene, with section hidden, and camera aligned.
                                  I have to change layer visibility so the layer with the rs group is visible. I remember doing this for different views that used the rs (perspective sections for example), but not for the main rs scene.
                                  Once the scene and rs name is changed, I have to manually delete the original layer, (#00x)
                                  Running win 10, x64
                                    bimbachi
                                    ok thanks,
                                    but now I have list of all hatch materials , hoever they dont show on sections when selected šŸ˜•
                                    [sup:3ntsc15e][/sup:3ntsc15e]
                                    @pgarmyn said:
                                    @bimbachi said:
                                    hello,
                                    Hy bimbachi
                                    šŸ˜‰
                                      pgarmyn
                                      @bimbachi said:
                                      ok thanks,
                                      You will have to change the names of th materials (or make a copy with another name).
                                      Read the documentation (pdf in first post). Frome page 4:
                                      [dir=ltr:24wchjke]If the selected option for 'RichSection section material name' is 'prefix+layername, default',
                                      then the following section-materials will be asigned :
                                      If a group (or componentinstance) is in layer 'Layer1' and the prefix is '#' : Then the plugin will look for the RS material '#Layer1'. If it exist in the Model (<=> in the library), it will be assigned. If not, the RS material assigned to the cut-face will be 'default' witch means that the RS material of the Component(instance) or Group containing this nested element will be used. If no corresponding RS material can be found, the default RS material will be used.[/dir:24wchjke]
                                        pgarmyn
                                        @caronte01 said:
                                        Hi Piet,
                                        Running win 10, x64
                                        Dialog to small : Webdialogs are running on internet explorer (IE version 10? on windows 8, and not win 10?)
                                        I have IE 9 i think, i will test with IE10 to find a solution.
                                        RS name not correct after creation: behaviour of Webdialogs is not always logic : before closing the panel, you will have to leave the inputfield by selecting another control on the same panel or by using the tabulation button.
                                        RS layers are defined 'switched off in new scenes' : to use them in another scene you will have to update once the scene after creation.
                                        The programmers API can't purge layers, nor styles. Thus i can't clean up.
                                          cesaro36
                                          Sorry the lack of feedback PiGa.
                                          I'm having issues with version 0.5.3
                                          Can't change the properties of the default created richsection.
                                          Error: #<NoMethodError: undefined method attribute_dictionary' for nil:NilClass> c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:2330:in optionsRShRetrieve'
                                          c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:2083:in updateRichSection1' c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:3593:in changeOptionsRSh'
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSpanel.rb:381:in block in create' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in call'
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in block in trigger_event' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in each'
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in trigger_event' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:364:in event_control_callback'
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:318:in callback_handler' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:276:in block in add_callback'
                                          -e:1:in `call'
                                          SKUPro2014
                                          Win8
                                          regards
                                          Before trying to update richsection name and options
                                          After
                                            pgarmyn
                                            @cesaro36
                                            Strange, I have also Win 8 and SU2014, without that problem.
                                            Did you try to change the settings before creating the section?
                                            Are you updating a RichSection created with an older plugin version?
                                            What parameter did you modifiy?
                                            Did you changed options in the menu plugings/RichSection/settings ?
                                            If so, can you reset the settings for user and model and try again?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 15 / 20
