    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 213.9k Views 85 Watching
    • Y Offline
      youemailme
      Just downloaded yesterday, and figuring out how to use it. Unfortunately, no matter what I do, I can't get audio on any of the videos. Computer speakers, through my stereo, videos on your site, or on YouTube. No problem with any other videos on the internet.
        pgarmyn
        Nothing is wrong, there is no sound.
        Do you want me to sing ? 😄
        Please read the pdf doc.
        • tt_suT Offline
          tt_su
          😆 Yes! I do!
          • Y Offline
            youemailme
            I don't know how good a voice you have, so I suppose not. Guess that explains why there's no sound! I saw that someone complained about how fast they were, but I figured it wouldn't matter if I could hear what you were saying. Makes the pdf all the more indispensable. I'll watch the vids again after I study the pdf....
              pgarmyn
              @ youemailme & tt_su
              sorry,, english is not my mother tongue...
              I will make some slow 'how to' videos with text.
              I will be on holiday the next three weeks ..... 😎
              • Y Offline
                youemailme
                No apologies necessary! I'm in awe of anyone that can write plug-ins like this, while still carrying on a "day job"! No rush, and thanks again for your contribution to the world of SketchUp!
                • SkalpS Offline
                  Skalp
                  To make a decent plugin take a lot of work. And it's much more than having an idea and writing a little bit of ruby code. That is the easy part. But testing it. Because it should run on all version of windows and os x, and on all versions of sketchup. It can conflict with other plugins. And the userinterface had to be easy to use too. Oh did I mension there are all kind of browsers and they are different on win and mac and the UI is depended on these browsers. Than there is documentation. The user want a manual and tutorial movies. You should give support on it and a lot of support as nothing to do with your plugin itself but is an os, sketchup or browser issue... Or just stupidity of the user (oh yes I switched of showing images in my browser yesterday, now I understand why your webdialog isn't showing icons anymore... But this is after a join.me session of half an hour.)
                  Most of the plugins make money for the users by saving a lot of time. Please respect the developers and support there efforts by paying for there hard work.
                  Skalp
                  http://www.skalp4sketchup.com
                    caronte01
                    Hi Piet,
                    Here's a small sample of recent work using your plugin. All these are 100% sketchup/layout.
                    Thanks a lot!
                    Santiago
                      pgarmyn
                      UPDATE 0.5.0 published in the Sketchucation PLUGINSTORE HERE
                        pgarmyn
                        @caronte01 said:
                        Hi Piet,
                        Thanks a lot!
                        Santiago
                        Good work !!!
                          pgarmyn
                          KNOWN ISSUE:
                          RichSections created with older versions must be updated manually.
                          I will work on it to fix that.
                            priestonaray
                            trying to install this extension on my SU2014 but cannot find this on my toolbar, and every time i restart SU, it shows:
                            Error: #<LoadError: cannot load such file -- fileutils.rb>
                            c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:133:in require' c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:133:in module:PiGaRSection'
                            c:/users/administrator/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/piga_richsection/richsection.rbs:106:in <main>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in eval'
                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in require' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in module:PiGa'
                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:3:in <top (required)>' C:/PROGRA~1/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                            C:/PROGRA~1/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:40:in register_extension'
                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:40:in <module:PiGa>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection.rb:17:in <top (required)>'
                            any idea?
                              The fileutils.rb is a standard file found in the RubyStdLib subfolder within the SketchUp Tools.
                              It does not auto-load when SketchUp starts, BUT can be required thus:
                              require "fileutils.rb"
                              Since the path to the RubyStdLib subfolder should be auto-added to the $: the .rb should be found in that folder.
                              Obviously something is failing...
                              Check a few things...
                              Is the RubyStdLib subfolder within the SketchUp Tools ?
                              Does it contain a file named fileutils.rb ?
                              If not reinstall SketchUp v2014 [latest version]...
                              Is the path to RubyStdLib included in the $: ? To check that you just type $: in the Ruby Console...
                              If you type require "fileutils.rb" in the Ruby Console what is the result ?
                              Report back...
                                pgarmyn
                                UPDATE 0.5.1 published in the Sketchucation PLUGINSTORE HERE
                                RichSections created with an older plugin version don't need manual update any more (bug in 0.5.0) when changing the sectionplan
                                • KrisidiousK Offline
                                  Krisidious
                                  Thanks pgarmyn...
                                  By: Kristoff Rand
                                    priestonaray
                                    Report back...
                                    Is the RubyStdLib subfolder within the SketchUp Tools ?yes
                                    Does it contain a file named fileutils.rb ? yes
                                    If not reinstall SketchUp v2014 [latest version]... 14.0.49
                                    Is the path to RubyStdLib included in the $: ? To check that you just type $: in the Ruby Console... i don't think so
                                    If you type require "fileutils.rb" in the Ruby Console what is the result ? false
                                      caronte01
                                      Hi Piet,
                                      I´m having some issues with this new version 0.5.1
                                      When I right click on a rs to update it, I get the new dialog, and then after a second right click, I can update it. Previously, on the first right click, I was able to update the section directly.
                                      The other thing is that, once the new dialog (which looks great btw, big improvement over the previous one), takes the focus, the main window can be orbited, but not zoomed in/out. This happens without notice, so that results in apparent sluggish navigation. Is there a way to switch between modal and non modal dialogs? It may be a matter of personal preference, but I like to have all these aux windows go away once they have served their purpose. This would avoid the first problem.
                                      Other than that, I´ve had no issues with this new version. I´ll keep testing.
                                      Thank you!
                                      Santiago
                                        pgarmyn
                                        Fileutils is used by my plugin, but it is part of the standard library since Sketchup 2014.
                                        Did you reinstall Sketchup ? (Even if you have the latest)
                                        Tell me....
                                          pgarmyn
                                          @caronte01 said:
                                          Hi Piet,
                                          Thank you!
                                          Santiago
                                          About zooming : If you click on the titlebar of the Sketchup-window, the main window will have the scope, and zoom-behaviour will be normal.
                                          About updating with one click: Yes my context-menu is buggy. I will work on it. But instant update is still possible if you use the update button on the panel, and then click on the sectionplan or Richsection group.
                                          About non-modal or modal dialog: The idea was to use a non modal dialog to allow the creation of materials, scenes.... to use within the RichSection. If necessary i will switch back to modal, or let you the chose, but first give me last chance to try the non-model way.
                                          Thanks for testing Santiago!
                                            cesaro36
                                            Hi Piet
                                            Since the last UI interface I can't get my sections to update (no section name change). These are the errors shown:
                                            Error: #<ArgumentError: 'DarkRed' not valid values in list.>
                                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/listbox.rb:238:in value=' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/RSpanel.rb:583:in block in create'
                                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in call' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:82:in block in trigger_event'
                                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in each' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/events.rb:78:in trigger_event'
                                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:358:in event_control_callback' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:312:in callback_handler'
                                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/PiGa_RichSection/SKUI/window.rb:270:in block in add_callback' -e:1:in call'
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 19
                                            • 20
                                            • 14 / 20
