    How do you do this?
    14 Posts 7 Posters 647 Views 7 Watching
      Anarchist86ed
      This is probably easy, but I can't figure it out. I can't figure out how to make what I've illustrated in the picture.
        What have you illustrated? I think you'll have to use words. All I see is a rendered space ship image. I can't tell what you're asking for.
        • cottyC Offline
          cotty
          How do you know it's rendered? πŸ˜‰
          my SketchUp gallery
            Anarchist86ed
            I don't know the technical term for it.
            Curving... like that.
              Good question. I suppose it could just be a photograph. πŸ˜„ It was the red box and the arrow that tipped me off.
                Oh. Well, where to start? It would be a good idea to know what you know about using SketchUp first.
                  I presume you mean the hull panelisation?
                  It's a greeble type effect
                    Anarchist86ed
                    I'm tired of making box shapes cylinders and lathes.
                    Trying to move on.
                      Anarchist86ed
                      let me see if I can be clearer.
                        As Sketchup is a sort of "box modeling" program ... πŸ˜„
                        Seems you can make your space illustation without any effort! πŸ˜„
                        Here Protrude by Jim
                        http://www.polyloop.net/imagehosting/196496bcab26731d.jpg
                        or here simply the Joint PushPull by Fredo 6 + Suforyou πŸ˜‰ time realisation 10 second! πŸ’š
                        http://s6.postimg.org/ujv4ivopd/simili1.jpg
                        http://s6.postimg.org/5kuubufgx/suforyou.jpg
                          Ps Take a look at this thread! πŸ˜‰
                          By Liam887
                          http://sketchucation.com/forums/download/file.php?id=25875
                          Or the making of for this one by Karanak πŸ˜‰
                          http://star-conflict.com/upload/image/materials/Making_of4/50.jpg
                          • KrisidiousK Offline
                            Krisidious
                            You want Curviloft...
                            SketchUp Plugins | PluginStore | SketchUcation
                            SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                            (sketchucation.com)
                            By: Kristoff Rand
                              Anarchist86ed
                              Sketchup Crashed 3 times using Curviloft.
                              But...
                              • xiombargX Offline
                                xiombarg
                                Curviloft has a low tolerance for messy operations and it won't work around geometry it sees as invalid. I've found that the key with Curviloft is to try and keep your operations in smaller grouped sections and don't try to get complex shapes in one big pass. Once you have each section worked out, then you can explode the groups if needed.
                                Curviloft is great, but you have to do things nice and clean. Ramming together lots of elements with irregular spacing or breaks you will give you problems. It's also a good idea to use Curvilizard to weld your splines together when necessary.
                                And be sure to save inbetween each successfully lofted piece.
