    Another Shape Bender Problem
    20 Posts 9 Posters 2.2k Views 9 Watching
    • pbacotP Offline
      [off:1xcwis0t]Do you think some people post problems here just to get us going, then lurk to watch the fun? [/off:1xcwis0t]
        @dave r said:
        I did draw the can first. Then I got the circumference of it and drew the rectangle for the label to match.
        Well, exactly like in that example I linked to. πŸ˜‰
        whenever I bring any material image into SketchUp I create a face of the known dimension of the texture and apply it to that face.
        πŸ‘ Ditto. Then you can easily scale/snap to the boundaries of the rectangle. Did you know that if the aspect ratio of the rectangle and the image do not perfectly match, you can press the Shift key to distort the material to adopt to the face?
        Well, as the learned Chinese used to say in Ancient times, "Repetitio est mater studiorum" - so in the newbie section, this is not an issue I hope. πŸ˜‰
          I didn't know that the Chinese had latin accents. Golly, you learn something new every day. πŸ˜†
            πŸ˜’ I even used to teach Latin at university. To me, each Chinese has a Latin accent. πŸ˜‰
              "Don't let the bastards grind you down..."
              Perhaps...
              Id imperfectum manet dum confectum ...
              or more colloquially
              Nolite te bastardes carborundorum ...
              or more obviously...
              Nolite bastardes te carborundorum ...
              or in mock-latin...
              Illegitimi non carborundum ...
              • pbacotP Offline
                I dunno about newbies. I usually take something away, or get reminded, that's why I check in so often. (the other reason is boredom I guess πŸ˜’ 😳 )
                • O Offline
                  Openspaces
                  +1 πŸ‘
                    LJPlace
                    You all seem to know your stuff so hopefully have some advice for me. I have watched several tutorials and read several problem forums, but I must be missing a key part of the process.
                    I want to bend a flat plane to a curve. I have made the plan a component, both that and the curve it on the red axis, they are both the same length. However, once I activate shape bender, it wont even let me select a line, let a lone a second. Any thoughts?
                    Thanks,
                    LJ
                    Here's the plane and curve...
                    • ely862meE Offline
                      ely862me
                      Can you upload the file ?
                      Elisei (sketchupper)
                      Come and See EliseiDesign
                        Where's the line you're trying to select? It cannot be inside the component.
                        Note in my example that the component to be bent is located directly above the straight line. After the plugin runs, the bent version of the component is located directly above the curve. If there is any horizontal displacement between the straight line and the original component, there'll be a horizontal displacement between the curve and the bent component.
                          LJPlace
                          Good Morning,
                          The line was parallel with the base of the rectangle, as shown in Chris's tutorial. Even if I separate it out I still cannot select a line. Nothing highlights in blue. I almost think I've downloaded the program wrong!
                          Unfortunately I can't upload the file as it is too big. This is a nightmare =/
                            LJPlace
                            I knew it was a straight forward piece of software, just reloaded it and it works fine! Thanks for your help.
                            LJ
                              πŸ‘ πŸ‘
