    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 201.9k Views 109 Watching
      smuncky
      @jiminy-billy-bob said:
      This error is related to Dynamic components, not Layers Panel.
      Do you have any idea as to why this error only happens when Layers Panel is on?
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Hmmm, I'll look into it.
          jiminy-billy-bob
          For those who want Layers Panel to support Thea Render (or the other way around), please say so in this thread : http://sketchucation.com/forums/viewtopic.php?f=384%26amp;t=58168
          • Bob JamesB Offline
            Bob James
            Still get the occasional "Undo Layers Panel ID" when trying to undo an action.
            • danchoD Offline
              dancho
              Can you put inside plugin to arange layers in alphabetica order?
                smuncky
                Any luck on replicating the problem or finding the cause in the code?
                  jiminy-billy-bob
                  I couldn't replecate the issue. Could you send me your model?
                    smuncky
                    PM sent.
                      jiminy-billy-bob
                      New version 1.2.0 !
                      Changelog :
                      • Added an History dialog, to easily revert back if groups/order disappear
                      • Added a right-click menu
                      • Fixed an issue causing an infinite undo loop
                      • Fixed encoding issue with non-english characters and alphabets
                      • The dialog now remembers its position in OSX
                      • Fixed minimizing
                      • Added support for KeyShot5
                      http://i.imgur.com/bzlLnCc.png
                      Download in the plugin store !
                        jiminy-billy-bob
                        If you already updated to 1.2.0, please redownload it. I fixed a minor glitch.
                        • cmeedC Offline
                          cmeed
                          Amazing job. Thank you.
                          • BoxB Offline
                            I just noticed your toolbar is persistent, meaning even if you choose to close it it will reopen on next startup. Is it possible to remove this behavior.
                            I've notice quite a few tools do this and it makes for a minor nuisance when you want to use a minimal number of toolbars.
                              jiminy-billy-bob
                              Box > On windows 7 64bits, with SU2014?
                              It works fine for me.
                              • BoxB Offline
                                Hmmm, interesting, I'm on the same setup. I just updated the plugin and it still does it. I'll have to have a look around and see if it's something up my end although both Sdmitch and Eneroth3 were able to give me the line edit to stop it opening.
                                  jiminy-billy-bob
                                  Could you send me what they told you to modify for their plugin?
                                  • BoxB Offline
                                    Here you go.
                                    Deck builder
                                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58084%26amp;p=533860#p533827
                                    Railway
                                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=57831%26amp;start=240#p533089
                                      jiminy-billy-bob
                                      Ok, try to redownload, I added Eneroth's fix.
                                      • BoxB Offline
                                        Yep, that's done the trick. Thanks.
                                          glro
                                          I tried
                                          I got an error message while i was trying to move some layers to a group
                                          too bad
                                          the appearance is well finished, and it fits a need
                                          error message
                                            @giro
                                            What version of Internet Explorer do you have ?
                                            • 33
                                            • 34
                                            • 7 / 34
