    Vray Leaf Material Haze
    renderpluginsextensions
    14 Posts 4 Posters 3.5k Views 4 Watching
      rspierenburg
      I was thinking perhaps turbidity settings in Environment.
      • TedVitale_CGT
        TedVitale_CG
        I would suggest not using refraction at all but rather a V-Ray two sided material instead. Two sided materials allow for light transmission with out having to use opacity settings or refraction settings.
        Take a look at the leaf material I've attached here and test it out in a sample scene. I think using a material like this will give you the desired results.
        A Simple 2-Sided V-Ray Leaf Material
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
          shueda
          Thanks for the thoughts and suggestions for things to look into. I haven't gotten the issue resolved, yet. See this image for a close up of the phenomenon.
            shueda
            Thanks Ted! I'll give it a shot and report back!
              shueda
              Here's the result using the Oak leaves shared by Ted. What the heck?
              • TedVitale_CGT
                TedVitale_CG
                How are you applying the materials? Are you painting them with the paint bucket or are you applying the double sided material with V-Ray? It looks like you used the base material not the 2 Sided. Could you possibly share the model? I'd like to take a look and see whats happening. The last thing I can think of is you're not using the cutout of the leaf so you're getting artifacts rendered from the transparency of the .png file.
                Ted Vitale
                  shueda
                  Ted,
                  I've exported VRMesh from 3DS Max, loaded the VRMessh into SketchUp, and used the Vray material editor to re-map or, as with your Oak leaves, import the materials. In addition, I've erased all of the VRMesh geometry and replaced it with a 2D always-face-camera image of the model. The tree file is apparently too large to attach to this post (15MB). Thanks for your help!!!
                  See if this link works: https://drive.google.com/file/d/0B9WMaFDh7ps6Y2hPS2k2YVdHRDg/edit?usp=sharing
                  • TedVitale_CGT
                    TedVitale_CG
                    @shueda said:
                    Ted,
                    As a side note, when ever you share files from Sketchup, save them first and then go to Plugins> V-Ray> Pack Scene. This will allocate all the associated files into one zip folder. As it stands, I cant test the file you sent. I don't have the material information, or the proxy. If you re-upload the file I can take a look at it again though.
                    Ted Vitale
                      shueda
                      Ted,
                      Here's the packed scene - thanks for the tip!
                      (drive.google.com)
                      Greg
                      • TedVitale_CGT
                        TedVitale_CG
                        So, after some review I finally found the problem! In your materials diffuse bitmap there is an option to "Enable double-sided mode" by default its enabled because you can apply materials to both sides of a face in Sketchup (I had mine set up like this as well, oops). Go ahead and disable it for all your leaf textures, bump maps, and transparency maps. This should help speed up your renderings as well. Let me know how it goes!
                        Updated Model:
                        https://drive.google.com/a/usa.chaosgroup.com/file/d/0B_z-28sFcwxOS1hvNjViSjBxXzA/edit?usp=sharing
                        Updated Model w/2Sided
                        https://drive.google.com/a/usa.chaosgroup.com/file/d/0B_z-28sFcwxON0hTV0N1QlgzQzQ/edit?usp=sharing
                        Ill have them up for a couple weeks and then take them down to save space in my Google drive, so download them as soon as you can.
                        Enable double-sided mode off
                        Ted Vitale
                          shueda
                          OMG - you are a genius! Thank you!!!!!
