    Vray Leaf Material Haze
    renderpluginsextensions
    14 Posts 4 Posters 3.0k Views 4 Watching
      shueda
      Hi everyone - this is my first post after many months of reading the excellent posts here!
      I'm posting because I cannot figure out what's going on with this one particular tree type! It seems that the edges are almost transparent.
      Here's the back story:
      Exported tree model as VRMesh in 3ds Max
      Imported VRMesh into Sketchup and re-mapped materials
      I have experimented with refraction and transparency/alpha to no avail.
      I'm using SketchUp 2013 Pro and Vray 2.0.
      See image of straight rendering. You can see the issue at the top where the white background is showing through the leaves. Looks like fog, but there is no fog (multiplier set to 0 in refraction layer for leaf material).
      Please help!!! πŸ˜„
        shueda
        I was initially concerned that the issue had to do with materials not being mapped on both sides of surfaces, and it may be just that, but I have no idea how to map materials on specific sides of a VRMesh.
        • V Offline
          valerostudio
          Doesn't this have something to do with sub pixel mapping? Thought I read that on Peter Guthries blog.
            rspierenburg
            I was thinking perhaps turbidity settings in Environment.
            • TedVitale_CGT Offline
              TedVitale_CG
              I would suggest not using refraction at all but rather a V-Ray two sided material instead. Two sided materials allow for light transmission with out having to use opacity settings or refraction settings.
              Take a look at the leaf material I've attached here and test it out in a sample scene. I think using a material like this will give you the desired results.
              A Simple 2-Sided V-Ray Leaf Material
              Ted Vitale
              Owner | Creative Director
              http://www.voxl.vision
                shueda
                Thanks for the thoughts and suggestions for things to look into. I haven't gotten the issue resolved, yet. See this image for a close up of the phenomenon.
                  shueda
                  Thanks Ted! I'll give it a shot and report back!
                    shueda
                    Here's the result using the Oak leaves shared by Ted. What the heck?
                      TedVitale_CG
                      How are you applying the materials? Are you painting them with the paint bucket or are you applying the double sided material with V-Ray? It looks like you used the base material not the 2 Sided. Could you possibly share the model? I'd like to take a look and see whats happening. The last thing I can think of is you're not using the cutout of the leaf so you're getting artifacts rendered from the transparency of the .png file.
                      Ted Vitale
                        shueda
                        Ted,
                        I've exported VRMesh from 3DS Max, loaded the VRMessh into SketchUp, and used the Vray material editor to re-map or, as with your Oak leaves, import the materials. In addition, I've erased all of the VRMesh geometry and replaced it with a 2D always-face-camera image of the model. The tree file is apparently too large to attach to this post (15MB). Thanks for your help!!!
                        See if this link works: https://drive.google.com/file/d/0B9WMaFDh7ps6Y2hPS2k2YVdHRDg/edit?usp=sharing
                          TedVitale_CG
                          @shueda said:
                          Ted,
                          As a side note, when ever you share files from Sketchup, save them first and then go to Plugins> V-Ray> Pack Scene. This will allocate all the associated files into one zip folder. As it stands, I cant test the file you sent. I don't have the material information, or the proxy. If you re-upload the file I can take a look at it again though.
                          Ted Vitale
                            shueda
                            Ted,
                            Here's the packed scene - thanks for the tip!
                            (drive.google.com)
                            Greg
                              TedVitale_CG
                              So, after some review I finally found the problem! In your materials diffuse bitmap there is an option to "Enable double-sided mode" by default its enabled because you can apply materials to both sides of a face in Sketchup (I had mine set up like this as well, oops). Go ahead and disable it for all your leaf textures, bump maps, and transparency maps. This should help speed up your renderings as well. Let me know how it goes!
                              Updated Model:
                              https://drive.google.com/a/usa.chaosgroup.com/file/d/0B_z-28sFcwxOS1hvNjViSjBxXzA/edit?usp=sharing
                              Updated Model w/2Sided
                              https://drive.google.com/a/usa.chaosgroup.com/file/d/0B_z-28sFcwxON0hTV0N1QlgzQzQ/edit?usp=sharing
                              Ill have them up for a couple weeks and then take them down to save space in my Google drive, so download them as soon as you can.
                              Enable double-sided mode off
                              Ted Vitale
                                shueda
                                OMG - you are a genius! Thank you!!!!!
