    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
    • BoxB Offline
      To answer your question in both threads, yes it does work in SU2013.
      Make sure you have installed the latest version of it and libfredo.
        @porter159 said:
        A version for 2013 that works just like the one for sketchup 8 would be FANTASTIC!!!
        The best place to start is the first post in the thread. You can download the current version there and as Box wrote, get the current version of LibFredo6, too. Better yet, install the Sketchucation Plugin Store tool and auto install Joint Push/Pull.
        If you are using SU 2013, please update your profile. It'll help in the future when you need help.
        • N Offline
          nicmask
          Thanks!! πŸ‘ πŸ‘
          • cottyC Offline
            cotty
            I would love a fuction which rounds corners while push pulling like in this video... πŸ˜‰
            my SketchUp gallery
              Oh boy! That's cool! 😍
              • H Offline
                huyvuvn
                Hello,
                I update this plugin today but I prefer the way of old way to use: click , and move mouse , and click (or typing measurement). The new way is so inconvinent : click and drag (hold the mouse button).
                happiness on the way, not in the destination.
                • BoxB Offline
                  Click drag release type.
                  • fredo6F Offline
                    @huyvuvn said:
                    Hello,
                    If you long-click and then release, you can then drag freely (i.e. with mouse button up).
                    Also, you can click to select faces. When you have selected the last face you wish to include, click again and release and you are in free dragging mode.
                    Finally,
                    • you can type an offset value in the VCB at any time
                    • once a push pull is done, you can also type an offset value in the VCB or change parameters (ex: Thicken vs. pull)
                      dimasaga
                      just awesome.
                        ramces7
                        gracias
                        • fredo6F Offline
                          NEW RELEASE: JointPushPull Classic - v2.2a - 26 Apr 17
                          This is a resurrection of the OLD version of the plugin.
                          Although the plugin is obsolete now, this old version is published on the Sketchucation PluginStore under the name JointPushPull Classic.
                          IMPORTANT: This version can co-exist with the NEW version JointPushPull Interactive (v3.x).
                          In case you had the old JoinPushPull already installed on your computer, it is advised to remove:
                          • the folder JPP_Dir_21
                          • the file jointpushpull.rb
                          • the file LibTraductor.rb
                          This old version is not interactive, but maybe more intuitive:
                          • You have to pre-select the faces before launching it
                          • PushPull is shown interactive with a wireframe as you drag the mouse
                          • You need to double-click to generate the geometry
                          • Only Joint, Normal and Vector modes are supported
                          • pbacotP Offline
                            Ask and you shall receive! Not me, but someone was posting about how they wish the old joint push pull would still work! Can't find the thread right off, but they liked the way the clicks worked better before. Thank you Fredo-- All of them are great tools!
                            • N Offline
                              NADEM
                              HI THANK YOU G,DS SDF SDFFFFFFFFFFS SDF SDRDS SE SE FD
                              • jujuJ Offline
                                juju
                                work less late nights, falling asleep on your keyboard isn't pretty
                                  bzqp Newcomers
                                  Hey, this version seems to be crashing Sketchup on SKP 2023. Crashes anytime I try to apply the extrusion by pressing enter. Any ideas what's up?
                                    Dave R @bzqp
                                    @bzqp use the current version of Joint Push/Pull. Theold version is not suitable for SketchUp 2023.
                                    https://sketchucation.com/pluginstore?pln=JointPushPull
                                    Make sure to also install the latest version of LiFredo6 and the Sketchucation ExtensionStore which are both required.
                                      bzqp Newcomers
                                      Hmm, the starting post states LibFredo6 is not required and the classic version works with all Sketchup versions. The new version seems to be paid from what I see, I'd very much prefer the free one.
                                      Dave RD Rich O BrienR 2 Replies Last reply Reply Quote 0
                                        Dave R @bzqp
                                        @bzqp The first post in THIS thread was last updated in 2017. SketchUp has changed since then. I gave you the link to the version of Joint Push/Pull which works in newer versions of SketchUp.
                                        The current version of Joint Push/Pull requires LibFredo6 and Sketchucation ExtensionStore..
                                          Rich O Brien Moderator @bzqp
                                          @bzqp said in Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17:
                                          Classic JPP fails on SketchUp 2018 and above because of changes to the ruby API. It is available for anyone on older versions of SketchUp.
                                          • 15
                                          • 16
                                          • 17
                                          • 18
                                          • 19
                                          • 18 / 19
