    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.2m Views 150 Watching
    • fredo6F
      @huyvuvn said:
      Hello,
      I update this plugin today but I prefer the way of old way to use: click , and move mouse , and click (or typing measurement). The new way is so inconvinent : click and drag (hold the mouse button).
      If you long-click and then release, you can then drag freely (i.e. with mouse button up).
      Also, you can click to select faces. When you have selected the last face you wish to include, click again and release and you are in free dragging mode.
      Finally,
      • you can type an offset value in the VCB at any time
      • once a push pull is done, you can also type an offset value in the VCB or change parameters (ex: Thicken vs. pull)
        dimasaga
        just awesome.
          ramces7
          gracias
          • fredo6F
            NEW RELEASE: JointPushPull Classic - v2.2a - 26 Apr 17
            This is a resurrection of the OLD version of the plugin.
            Although the plugin is obsolete now, this old version is published on the Sketchucation PluginStore under the name JointPushPull Classic.
            IMPORTANT: This version can co-exist with the NEW version JointPushPull Interactive (v3.x).
            In case you had the old JoinPushPull already installed on your computer, it is advised to remove:
            • the folder JPP_Dir_21
            • the file jointpushpull.rb
            • the file LibTraductor.rb
            This old version is not interactive, but maybe more intuitive:
            • You have to pre-select the faces before launching it
            • PushPull is shown interactive with a wireframe as you drag the mouse
            • You need to double-click to generate the geometry
            • Only Joint, Normal and Vector modes are supported
            • pbacotP
              Ask and you shall receive! Not me, but someone was posting about how they wish the old joint push pull would still work! Can't find the thread right off, but they liked the way the clicks worked better before. Thank you Fredo-- All of them are great tools!
              • N
                NADEM
                HI THANK YOU G,DS SDF SDFFFFFFFFFFS SDF SDRDS SE SE FD
                • jujuJ
                  juju
                  work less late nights, falling asleep on your keyboard isn't pretty
                  • B
                    bzqp Newcomers
                    Hey, this version seems to be crashing Sketchup on SKP 2023. Crashes anytime I try to apply the extrusion by pressing enter. Any ideas what's up?
                    Dave RD 1 Reply Last reply
                      Dave R @bzqp
                      @bzqp use the current version of Joint Push/Pull. Theold version is not suitable for SketchUp 2023.
                      SketchUp Plugins | PluginStore | SketchUcation
                      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                      (sketchucation.com)
                      Make sure to also install the latest version of LiFredo6 and the Sketchucation ExtensionStore which are both required.
                      • B
                        bzqp Newcomers
                        Hmm, the starting post states LibFredo6 is not required and the classic version works with all Sketchup versions. The new version seems to be paid from what I see, I'd very much prefer the free one.
                        Dave RD Rich O BrienR 2 Replies Last reply
                          Dave R @bzqp
                          @bzqp The first post in THIS thread was last updated in 2017. SketchUp has changed since then. I gave you the link to the version of Joint Push/Pull which works in newer versions of SketchUp.
                          The current version of Joint Push/Pull requires LibFredo6 and Sketchucation ExtensionStore..
                            Rich O Brien Moderator @bzqp
                            @bzqp said in Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17:
                            Classic JPP fails on SketchUp 2018 and above because of changes to the ruby API. It is available for anyone on older versions of SketchUp.
                            • 15
                            • 16
                            • 17
                            • 18
                            • 19
                            • 19 / 19
