[Plugin] TIG-Smart_offset
wonder why sketchup guys don't have the normal and ordinary offset that you invented
@tig said:
@Stan, any donation is more than welcome... I assume you meant ยฃ5 because 5p=~8ยข...
I think I have a fix for your probable issue - these 3m inset/outset offsets worked OK with a new version that I am working on [native fails with twisted parts].
It fixes some issues with multi-curve loops and also some curves that straddle a loop's start/end vertex not all offsetting as curves...
So far it seems to trap various permutations of offset size and loop contents and convolutions, that have been some unexpected causing issues...
I hope to have that version ready for release tomorrow...
hi tig, yes, i ment pounds, but had not the sign on my german keyboard.
thanx for solving the problem, thats fantastic. i'll try soon.
stan -
I just tried to install this into my SU ver 8, not Pro, using the Window/preference/extensions/Install extension button. The .rb file appears in my plugins directory and the icon appears on the SU screen but it is greyed out and inactive. Can you make a suggestion as to what the problem might be?
Steve -
Sounds like you have installed it just fine from its RBZ archive!
The problem seems to be you
Please [re]read the instructions on the tool's download page: where its uses clearly explained...
The tool is only 'enabled' if you have already made an appropriate selection: ONE FACE.
So preselect ONE FACE... and 'miraculously' you will find that the tool's toolbar button etc is then available for use...
Surely you have noticed how some tools only become 'enabled' when circumstances are appropriate... like you have one suitable thing selected... -
excellent time saving tool, thanks Tig.
where would sketchup be without guys like you, tom tom and fredo. -
Rocks.
Just wondering? Is "TIG_Random _Shape_Generator.rb.v2.1" the final offer.
Thanks for working at it over 'The End of the world', Christmas and New Years.
Great Plugin. Thank you! You rock.
No.
It is in the middle of a revamp...
BUT other more pressure projects have intervened.
Keep watching, an update will arrive one day...
See attached video - SU PRO 2014, Win 7 64 bit
[attachment=0:1e099geg]<!-- ia0 -->Video_2014-05-31_075712.wmv<!-- ia0 -->[/attachment:1e099geg]
It should offset any arcs/circles/curves as curves NOT arcs/circles.
BUT I' unsure why one of the curve's edges is failing to be incorporated in that new curve...remember that it's not really intended to replace the native Offset for these kinds of very simple operations, but rather to avoid the annoying 'bow-tie' issues it can cause in complex concave/narrowing loops
This tool IS long overdue its annual update...
Keep watching [but don't hold your breath]... -
@tig said:
No.
Keep watching, an update will arrive one day...Does the ruby API have code similar to your offset and reveal Ruby. But that instead of selecting faces one would select lines, similar to the "edge loops" concept used in Zbrush or C4D? see attachment
how instal this plugin?
Either 1. download its RBZ from the SCF PluginStore page linked above... and 2. use the Preferences > Extensions > Install... button.
OR one off - get the SketchUcation Toolset RBZ from the Resources menu [above], then install it - and thereafter use that to install all of your needs from the PluginStore directly using AutoInstall from the PluginStore dialog in one step. -
Positive.
Yes, +ve and -ve are common English abbreviations for Positive and Negative respectively: used with numbers - e.g. 2, -2
Thx for the info!
Version 3.0 is released. https://sketchucation.com/pluginstore?pln=TIG_Smart_offset It's now updated to work with newer versions of SketchUp [including 'signing'].
If used within another tool it also properly returns the newly created face[s] within an array...
See usage notes in first post... -
good morning I am a university student this plugin interests me many I would like to know how to download the plugin
Click the Download button in TIG's post immediately above yours.
