    Plugin to make a hole in a group?
    43 Posts 15 Posters 5.0k Views 15 Watching
    • fredo6F Offline
      @rv1974 said:
      Could the Cutter have multiple (not connected) shapes?
      Yes, it should. Actually, I still have to buld the GUI to pick a stencil pattern from faces in the model, but multiple shapes is possible
      • fredo6F Offline
        @krism said:
        The walls were created with Building Structure Tool. The wall groups are composed of some solid group wall parts. There are some underlying attributes attached to the group to identify it as a BST structure which allows the BST tools to do various things.
        I noticed a strange thing in the wall. It seems all normals are reversed and Sketchup is messed up with that. Very strange!
        EDIT: this has to do with how the groups were created. If you explode each group and then make them group invidually, this odd behavior disappears.
          KrisM
          Fredo,
          The only problem with exploding the walls is that they would no longer be recognized as a structure by BST and then you can't use the BST tools on them. The BST tools allow you to extend walls to other walls, extend to faces and mitre the corners. These are great tools but don't work on non BST objects. The only thing missing was a way to make holes in the walls which doesn't work with Hole on Solid but appears to work with your plugin.
          The wall in the sample file comes with BST (its called MWALL). You can actually create your own mwalls which is really the power of BST. I will look at a mwall I created and see if the same issue is present.
          KrisM
          • fredo6F Offline
            Kris,
            I don't suggest you change anything. But it seems that all of these BST groups are systematically 'mirrored', that is one of their axes is reversed.
            And when you create a group within such 'mirrored' groups, it is also mirrored.
            • pep75P Offline
              pep75
              Fredo....when can we kiss your feet?
              • mitcorbM Offline
                mitcorb
                Just a question:
                Does the punching shape have to address a face? Or, in the examples above can the punch start midway down a wall. Why? No reason. I just saw that the cutter can turn as it changes position. And I saw it align on an edge/corner as if resolving the normals for the adjacent faces.
                • fredo6F Offline
                  @mitcorb said:
                  Just a question:
                  VisuHole is based on a projection plane (I may address draping later on).
                  So the plane is determined, in a similar way as MoveAlong, that is:
                  1. based on picked object (face, edge, vertex)
                  2. you can lock an axis plane
                  3. you can pick and force a plane from the model
                  • mitcorbM Offline
                    mitcorb
                    Excellent work, sir!!
                      dedmin
                      There are enough Fredos plugins to make a standalone application! 😆
                      • Bob JamesB Offline
                        Bob James
                        Interesting. That thought occurred to me even before this new marvel. I've already replaced shortcuts to lines, moves, etc to Fredo versions.
                        FredoSketch. 😄
                        • tt_suT Offline
                          tt_su
                          Fred'Up? 😄
                          • fredo6F Offline
                            @bob james said:
                            FredoSketch. 😄
                            @tt_su said:
                            Fred'Up? 😄
                            Too much honor!
                            It's when I write these plugins that I realize how rich is Sketchup, and the incredible amount of work that has been put in it over time.
                              KrisM
                              Well deserved honour in my opinion.
                              KrisM
                              • jolranJ Offline
                                jolran
                                @Sam
                                With Fredo on the job, I can stop wasting my time!!!!!!!!
                                Copy that! As Jack Bauer use to say.
                                BTW, looking at the video the response time seams to be pretty good. Does it work well with denser geometry ?
                                How the h&#l do you do that ?
                                • jolranJ Offline
                                  jolran
                                  I meant Fredo's video about the stamp-boolean thing, double-sorry 😳
                                  I can see how that got misinterpreted.. My english is not fluid sometimes.
                                  Watching your video again, Sam. I clearly see you do the same thing. So thanks for the code 👍
                                  You only have to do some fancy widgets now, and you are good to go!
                                  • fredo6F Offline
                                    Which video do you refer to exactly?
                                    • jolranJ Offline
                                      jolran
                                      Ah, now I see. It wasent a video. Last "Gif", which seams to have cause some confusion from my part.
                                      I say no more...
                                      • sdmitchS Offline
                                        sdmitch
                                        never mind
                                        http://sdmitch.blogspot.com/
                                        • W Offline
                                          Whaat
                                          Looking awesome, Fredo! Very exciting stuff! You know, a lot of other plugins might want to take advantage of the core features of your plugin.
                                          Is there any chance you could develop a library and API for the hole drilling functions?
                                          Very excited about the possibilities of this new tool... 👍
                                          • fredo6F Offline
                                            Dale,
                                            Thanks for your encouragements, I appreciate.
                                            The algorithm is not that complex actually (the GUI is more time-consuming), but I have isolated it anyway in a separate class with no GUI dependencies. Note that the hole shape itself is specified as another class, called Stencil, which allows to aggregate several faces to build the hole pattern.
                                            • 2 / 3
