    Plugin to make a hole in a group?
    43 Posts 15 Posters 4.5k Views 15 Watching
    • fredo6F Offline
      @mitcorb said:
      Just a question:
      Does the punching shape have to address a face? Or, in the examples above can the punch start midway down a wall. Why? No reason. I just saw that the cutter can turn as it changes position. And I saw it align on an edge/corner as if resolving the normals for the adjacent faces.
      VisuHole is based on a projection plane (I may address draping later on).
      So the plane is determined, in a similar way as MoveAlong, that is:
      1. based on picked object (face, edge, vertex)
      2. you can lock an axis plane
      3. you can pick and force a plane from the model
      • mitcorbM Offline
        mitcorb
        Excellent work, sir!!
          dedmin
          There are enough Fredos plugins to make a standalone application! πŸ˜†
          • Bob JamesB Offline
            Bob James
            Interesting. That thought occurred to me even before this new marvel. I've already replaced shortcuts to lines, moves, etc to Fredo versions.
            FredoSketch. πŸ˜„
            • tt_suT Offline
              tt_su
              Fred'Up? πŸ˜„
              • fredo6F Offline
                @bob james said:
                FredoSketch. πŸ˜„
                @tt_su said:
                Fred'Up? πŸ˜„
                Too much honor!
                It's when I write these plugins that I realize how rich is Sketchup, and the incredible amount of work that has been put in it over time.
                  KrisM
                  Well deserved honour in my opinion.
                  KrisM
                  • jolranJ Offline
                    jolran
                    @Sam
                    With Fredo on the job, I can stop wasting my time!!!!!!!!
                    Copy that! As Jack Bauer use to say.
                    BTW, looking at the video the response time seams to be pretty good. Does it work well with denser geometry ?
                    How the h&#l do you do that ?
                    • jolranJ Offline
                      jolran
                      I meant Fredo's video about the stamp-boolean thing, double-sorry 😳
                      I can see how that got misinterpreted.. My english is not fluid sometimes.
                      Watching your video again, Sam. I clearly see you do the same thing. So thanks for the code πŸ‘
                      You only have to do some fancy widgets now, and you are good to go!
                      • fredo6F Offline
                        Which video do you refer to exactly?
                        • jolranJ Offline
                          jolran
                          Ah, now I see. It wasent a video. Last "Gif", which seams to have cause some confusion from my part.
                          I say no more...
                          • sdmitchS Offline
                            sdmitch
                            never mind
                            http://sdmitch.blogspot.com/
                            • W Offline
                              Whaat
                              Looking awesome, Fredo! Very exciting stuff! You know, a lot of other plugins might want to take advantage of the core features of your plugin.
                              Is there any chance you could develop a library and API for the hole drilling functions?
                              Very excited about the possibilities of this new tool... πŸ‘
                              • fredo6F Offline
                                Dale,
                                Thanks for your encouragements, I appreciate.
                                The algorithm is not that complex actually (the GUI is more time-consuming), but I have isolated it anyway in a separate class with no GUI dependencies. Note that the hole shape itself is specified as another class, called Stencil, which allows to aggregate several faces to build the hole pattern.
                                • 2 / 3
