    Plugin to make a hole in a group?
    43 Posts 15 Posters 5.3k Views 15 Watching
    • fredo6F
      @krism said:
      The walls were created with Building Structure Tool. The wall groups are composed of some solid group wall parts. There are some underlying attributes attached to the group to identify it as a BST structure which allows the BST tools to do various things.
      I noticed a strange thing in the wall. It seems all normals are reversed and Sketchup is messed up with that. Very strange!
      EDIT: this has to do with how the groups were created. If you explode each group and then make them group invidually, this odd behavior disappears.
      • K
        KrisM
        Fredo,
        The only problem with exploding the walls is that they would no longer be recognized as a structure by BST and then you can't use the BST tools on them. The BST tools allow you to extend walls to other walls, extend to faces and mitre the corners. These are great tools but don't work on non BST objects. The only thing missing was a way to make holes in the walls which doesn't work with Hole on Solid but appears to work with your plugin.
        The wall in the sample file comes with BST (its called MWALL). You can actually create your own mwalls which is really the power of BST. I will look at a mwall I created and see if the same issue is present.
        KrisM
        • fredo6F
          Kris,
          I don't suggest you change anything. But it seems that all of these BST groups are systematically 'mirrored', that is one of their axes is reversed.
          And when you create a group within such 'mirrored' groups, it is also mirrored.
          • pep75P
            pep75
            Fredo....when can we kiss your feet?
            • mitcorbM
              mitcorb
              Just a question:
              Does the punching shape have to address a face? Or, in the examples above can the punch start midway down a wall. Why? No reason. I just saw that the cutter can turn as it changes position. And I saw it align on an edge/corner as if resolving the normals for the adjacent faces.
              • fredo6F
                @mitcorb said:
                Just a question:
                VisuHole is based on a projection plane (I may address draping later on).
                So the plane is determined, in a similar way as MoveAlong, that is:
                1. based on picked object (face, edge, vertex)
                2. you can lock an axis plane
                3. you can pick and force a plane from the model
                • mitcorbM
                  mitcorb
                  Excellent work, sir!!
                    dedmin
                    There are enough Fredos plugins to make a standalone application! 😆
                    • Bob JamesB
                      Bob James
                      Interesting. That thought occurred to me even before this new marvel. I've already replaced shortcuts to lines, moves, etc to Fredo versions.
                      FredoSketch. 😄
                      • tt_suT
                        tt_su
                        Fred'Up? 😄
                        • fredo6F
                          @bob james said:
                          FredoSketch. 😄
                          @tt_su said:
                          Fred'Up? 😄
                          Too much honor!
                          It's when I write these plugins that I realize how rich is Sketchup, and the incredible amount of work that has been put in it over time.
                          • K
                            KrisM
                            Well deserved honour in my opinion.
                            KrisM
                            • jolranJ
                              jolran
                              @Sam
                              With Fredo on the job, I can stop wasting my time!!!!!!!!
                              Copy that! As Jack Bauer use to say.
                              BTW, looking at the video the response time seams to be pretty good. Does it work well with denser geometry ?
                              How the h&#l do you do that ?
                              • jolranJ
                                jolran
                                I meant Fredo's video about the stamp-boolean thing, double-sorry 😳
                                I can see how that got misinterpreted.. My english is not fluid sometimes.
                                Watching your video again, Sam. I clearly see you do the same thing. So thanks for the code 👍
                                You only have to do some fancy widgets now, and you are good to go!
                                • fredo6F
                                  Which video do you refer to exactly?
                                  • jolranJ
                                    jolran
                                    Ah, now I see. It wasent a video. Last "Gif", which seams to have cause some confusion from my part.
                                    I say no more...
                                    • sdmitchS
                                      sdmitch
                                      never mind
                                      http://sdmitch.blogspot.com/
                                      • W
                                        Whaat
                                        Looking awesome, Fredo! Very exciting stuff! You know, a lot of other plugins might want to take advantage of the core features of your plugin.
                                        Is there any chance you could develop a library and API for the hole drilling functions?
                                        Very excited about the possibilities of this new tool... 👍
                                        • fredo6F
                                          Dale,
                                          Thanks for your encouragements, I appreciate.
                                          The algorithm is not that complex actually (the GUI is more time-consuming), but I have isolated it anyway in a separate class with no GUI dependencies. Note that the hole shape itself is specified as another class, called Stencil, which allows to aggregate several faces to build the hole pattern.
                                          • 2 / 3
