    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 176.1k Views 41 Watching
      Aerilius
      Great to see it finished! I can't wait to build our railroad with it.
      We have a MΓ€rklin H0. If we had a bigger one, we could lay rails from the kitchen outside to the terrace and transport dishes, drinks and food. So there's something to plan πŸ˜‰
      • eneroth3E
        eneroth3
        I wouldn't exactly call it finished but at least it's finished enough for a thread:)
        I hope I can see the model when it's done!
        My website: http://julia-christina-eneroth.se/
        • CadFatherC
          CadFather
          Goodness...! πŸ˜†
          • olisheaO
            olishea
            I don't think I'll ever need this plugin, but all I can say is wow! Looks like fun! πŸ‘ πŸ˜„
            Eneroth: I believe I've seen your plugins before? Did you make a terrain eroder or something along those lines?
            oli
              Yep! 😎
                Anton_S
                Professionally done!
                Works like a charm πŸ‘
                And a suggestion, are you planning to add a reset button?
                Some sounds would be awesome as well
                • alexandre skA
                  alexandre sk
                  Fantastic plugin AND model. I miss those ICE from Germany, 300km/h without a bump.
                  Ohh and thx for your Texture Positioning plug-in I use a lot.
                  • pbacotP
                    Genious!
                    • KrisidiousK
                      Krisidious
                      She's got a few Oli...
                      http://eneroth.port0.org
                      By: Kristoff Rand
                      • PixeroP
                        Pixero
                        Fantastiskt! πŸ‘
                        I'm not sure how often I will be able to use this for work but it's an amazing plugin.
                        Does it work on terrain as well?
                        Have you thought of doing a road and cars version?
                        • eneroth3E
                          eneroth3
                          i haven't really thought about a reset button. In Sketchyphysics I think the whole animation runs inside a tool and that Sketchup.abort_operation runs to move everything back when the user stops the animation. In my plugin the animation doesn't run inside an active tool since you need several tools so set switches, connect/disconnect couplings etc.
                          I've though about sounds but then I need to be able to play the same sound at different speeds to match the speed of the train. Also I would need lots and lots of sounds.
                          Yup ,that's mine. You can see all my plugins here:
                          ERROR: The request could not be satisfied
                          (extensions.sketchup.com)
                          404 Not Found
                          (sketchucation.com)
                          @pixero said:
                          Fantastiskt! πŸ‘
                          It should work on terrain but you might need to alter the terrain after adding the tracks so there's no gap under them. you can also add a new track type that has more ballast under it to prevent this gap. The same thing can be done with roads, create a road as a track type and initialize a car as rolling stock.
                          Under Plugins > Railroad > Documentation it's written how you make custom track types and rolling stocks. saving a rolling stock to the library however isn't very stable at the moment (some observers seem to get upset when I've tried in SU 2013). After saving a rolling stock to the rolling stock library it's recommended to restart Sketchup. Otherwise you can just initialize one without adding to the library.
                            rv1974
                            Without spaghetti western style bandits in library the plugin is rather pointless.
                            How am I supposed to robber the train? πŸ˜„
                            bang-bang
                            • KrisidiousK
                              Krisidious
                              bang-bang
                              By: Kristoff Rand
                              • eneroth3E
                                eneroth3
                                bang-bang
                                Make a 2d face me component of a person pointing a gun and follow the train with the camera. Then you can be inside the train and have a person standing at the side of the track pointing the gun at you when driving by πŸ˜„
                                  rv1974
                                  SurstrΓΆmming western?
                                  I see..πŸ˜„
                                    Reading the "Read me" ! 😎
                                    That is a complete universe! 😲
                                      Added to PluginStore
                                      • eneroth3E
                                        eneroth3
                                        πŸ‘
                                        • L
                                          Lz
                                          Very impressive. It's a shame that it doesn't seem to work on my SU 8 (i'm using WinXP btw). But i'm planning on upgrading anyway so i might take another look sometime in the future.
                                          either way, if you need help adding new rolling stock/locomotives for future versions, please let me know and i'll gladly try to help out with some models. German locomotives are one of my favorites too.
                                          • OxerO
                                            Oxer
                                            I tried to install on Mac 10.9.3 &SU2014 but it appears Load Error
                                            %(#BF0000)[Error al cargar archivo ene_railroad.rb
                                            Error: #<TypeError: wrong argument type nil (expected Regexp)>
                                            /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/ene_railroad.rb:202:in `gsub'
                                            /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/ene_railroad.rb:202:in `module:Ene_Railroad'
                                            /Users/Oxer/Library/Application Support/SketchUp 2014/SketchUp/Plugins/ene_railroad.rb:200:in `<top (required)>']
                                            • 18
                                            • 19
                                            • 1 / 19
