    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 176.1k Views 41 Watching
      Take your time...
      I'll look after the upload to your PluginStore account.
        Incredible! 😲 😎
        I am fan of the rainbow one! ! β˜€
          Aerilius
          Great to see it finished! I can't wait to build our railroad with it.
          We have a MΓ€rklin H0. If we had a bigger one, we could lay rails from the kitchen outside to the terrace and transport dishes, drinks and food. So there's something to plan πŸ˜‰
          • eneroth3E
            eneroth3
            I wouldn't exactly call it finished but at least it's finished enough for a thread:)
            I hope I can see the model when it's done!
            My website: http://julia-christina-eneroth.se/
            • CadFatherC
              CadFather
              Goodness...! πŸ˜†
              • olisheaO
                olishea
                I don't think I'll ever need this plugin, but all I can say is wow! Looks like fun! πŸ‘ πŸ˜„
                Eneroth: I believe I've seen your plugins before? Did you make a terrain eroder or something along those lines?
                oli
                  Yep! 😎
                    Anton_S
                    Professionally done!
                    Works like a charm πŸ‘
                    And a suggestion, are you planning to add a reset button?
                    Some sounds would be awesome as well
                    • alexandre skA
                      alexandre sk
                      Fantastic plugin AND model. I miss those ICE from Germany, 300km/h without a bump.
                      Ohh and thx for your Texture Positioning plug-in I use a lot.
                      • pbacotP
                        Genious!
                        • KrisidiousK
                          Krisidious
                          She's got a few Oli...
                          http://eneroth.port0.org
                          By: Kristoff Rand
                          • PixeroP
                            Pixero
                            Fantastiskt! πŸ‘
                            I'm not sure how often I will be able to use this for work but it's an amazing plugin.
                            Does it work on terrain as well?
                            Have you thought of doing a road and cars version?
                            • eneroth3E
                              eneroth3
                              i haven't really thought about a reset button. In Sketchyphysics I think the whole animation runs inside a tool and that Sketchup.abort_operation runs to move everything back when the user stops the animation. In my plugin the animation doesn't run inside an active tool since you need several tools so set switches, connect/disconnect couplings etc.
                              I've though about sounds but then I need to be able to play the same sound at different speeds to match the speed of the train. Also I would need lots and lots of sounds.
                              Yup ,that's mine. You can see all my plugins here:
                              ERROR: The request could not be satisfied
                              (extensions.sketchup.com)
                              404 Not Found
                              (sketchucation.com)
                              @pixero said:
                              Fantastiskt! πŸ‘
                              It should work on terrain but you might need to alter the terrain after adding the tracks so there's no gap under them. you can also add a new track type that has more ballast under it to prevent this gap. The same thing can be done with roads, create a road as a track type and initialize a car as rolling stock.
                              Under Plugins > Railroad > Documentation it's written how you make custom track types and rolling stocks. saving a rolling stock to the library however isn't very stable at the moment (some observers seem to get upset when I've tried in SU 2013). After saving a rolling stock to the rolling stock library it's recommended to restart Sketchup. Otherwise you can just initialize one without adding to the library.
                                rv1974
                                Without spaghetti western style bandits in library the plugin is rather pointless.
                                How am I supposed to robber the train? πŸ˜„
                                bang-bang
                                • KrisidiousK
                                  Krisidious
                                  bang-bang
                                  By: Kristoff Rand
                                  • eneroth3E
                                    eneroth3
                                    bang-bang
                                    Make a 2d face me component of a person pointing a gun and follow the train with the camera. Then you can be inside the train and have a person standing at the side of the track pointing the gun at you when driving by πŸ˜„
                                      rv1974
                                      SurstrΓΆmming western?
                                      I see..πŸ˜„
                                        Reading the "Read me" ! 😎
                                        That is a complete universe! 😲
                                          Added to PluginStore
                                          • eneroth3E
                                            eneroth3
                                            πŸ‘
                                            • 18
                                            • 19
                                            • 1 / 19
