    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 104.7k Views 41 Watching
      @Julia
      You know you have access to plugins.sketchucatio.com ?
      • eneroth3E Offline
        eneroth3
        Videos showing how tracks and trains are added:
        My website: http://julia-christina-eneroth.se/
        • eneroth3E Offline
          eneroth3
          @rich o brien said:
          @Julia
          At the moment I'm busy fighting against phpBB but I might look into it later (for instance I just had to figure out myself that youtube videos must use the http protocol, not https as the link I copied from the address bar used).
            Take your time...
            I'll look after the upload to your PluginStore account.
              Incredible! 😲 😎
              I am fan of the rainbow one! ! β˜€
                Aerilius
                Great to see it finished! I can't wait to build our railroad with it.
                We have a MΓ€rklin H0. If we had a bigger one, we could lay rails from the kitchen outside to the terrace and transport dishes, drinks and food. So there's something to plan πŸ˜‰
                • eneroth3E Offline
                  eneroth3
                  I wouldn't exactly call it finished but at least it's finished enough for a thread:)
                  I hope I can see the model when it's done!
                  • CadFatherC Offline
                    CadFather
                    Goodness...! πŸ˜†
                    • olisheaO Offline
                      olishea
                      I don't think I'll ever need this plugin, but all I can say is wow! Looks like fun! πŸ‘ πŸ˜„
                      Eneroth: I believe I've seen your plugins before? Did you make a terrain eroder or something along those lines?
                      oli
                        Yep! 😎
                          Anton_S
                          Professionally done!
                          Works like a charm πŸ‘
                          And a suggestion, are you planning to add a reset button?
                          Some sounds would be awesome as well
                          • alexandre skA Offline
                            alexandre sk
                            Fantastic plugin AND model. I miss those ICE from Germany, 300km/h without a bump.
                            Ohh and thx for your Texture Positioning plug-in I use a lot.
                            • pbacotP Offline
                              Genious!
                              • KrisidiousK Offline
                                Krisidious
                                She's got a few Oli...
                                http://eneroth.port0.org
                                By: Kristoff Rand
                                • PixeroP Offline
                                  Pixero
                                  Fantastiskt! πŸ‘
                                  I'm not sure how often I will be able to use this for work but it's an amazing plugin.
                                  Does it work on terrain as well?
                                  Have you thought of doing a road and cars version?
                                  • eneroth3E Offline
                                    eneroth3
                                    i haven't really thought about a reset button. In Sketchyphysics I think the whole animation runs inside a tool and that Sketchup.abort_operation runs to move everything back when the user stops the animation. In my plugin the animation doesn't run inside an active tool since you need several tools so set switches, connect/disconnect couplings etc.
                                    I've though about sounds but then I need to be able to play the same sound at different speeds to match the speed of the train. Also I would need lots and lots of sounds.
                                    Yup ,that's mine. You can see all my plugins here:
                                    SketchUp Extension Warehouse
                                    Your library of custom third-party extensions created to optimize your SketchUp workflow.
                                    (extensions.sketchup.com)
                                    http://sketchucation.com/pluginstore?pauthor=eneroth3
                                    @pixero said:
                                    Fantastiskt! πŸ‘
                                    It should work on terrain but you might need to alter the terrain after adding the tracks so there's no gap under them. you can also add a new track type that has more ballast under it to prevent this gap. The same thing can be done with roads, create a road as a track type and initialize a car as rolling stock.
                                    Under Plugins > Railroad > Documentation it's written how you make custom track types and rolling stocks. saving a rolling stock to the library however isn't very stable at the moment (some observers seem to get upset when I've tried in SU 2013). After saving a rolling stock to the rolling stock library it's recommended to restart Sketchup. Otherwise you can just initialize one without adding to the library.
                                      rv1974
                                      Without spaghetti western style bandits in library the plugin is rather pointless.
                                      How am I supposed to robber the train? πŸ˜„
                                      bang-bang
                                        Krisidious
                                        bang-bang
                                        By: Kristoff Rand
                                        • eneroth3E Offline
                                          eneroth3
                                          bang-bang
                                          Make a 2d face me component of a person pointing a gun and follow the train with the camera. Then you can be inside the train and have a person standing at the side of the track pointing the gun at you when driving by πŸ˜„
                                            rv1974
                                            SurstrΓΆmming western?
                                            I see..πŸ˜„
                                            • 18
                                            • 19
                                            • 1 / 19
