[Plugin] FredoTools - v4.5a - 02 Apr 24
NEW RELEASE: FredoTools v1.8e - 20 Apr 14
FredoTools 1.8d is a release fixing a problem in MoveAlong v1.0.
The issue was about moving a selection containing a huge number of entities, as signaled by rv1974.
Thanks for the new version and new tool Move Along
I have made a new Spanish Language (Spain) file to include the new tool.
Oxer,
Thanks. I will integrate in the next release.
Also, for info, all the tooltips for inferences in MoveAlong are actually defined in LibFredo6, not in FredoTools. This is why they won't appear in Spanish.
Thanks for the info Fredo. I have made the new Spanish Language (Spain) file to LibFredo6, do you want that i upload it here or in LibFredo6 topic?
Oxer,
Better in the LibFredo6 thread.
Ok.
NEW RELEASE: FredoTools v1.9a - 15 May 14
FredoTools 1.9a is a release for
See main post of this thread for Download of FredoTools.
Great update!!
Thank you. -
New Spanish Language File for FredoTools - v1.9a - 15 May 14
P.S: If you have like preference Spanish Language (Spain) simply change the ES in filename to --> SP
Oxer,
Thanks very much. This will go in the next update.
NEW RELEASE: FredoTools v1.9b - 17 May 14
FredoTools 1.9b is a release for
It includes:
- a fix for VCB inputs in architectural units in DrawAlong and MoveAlong
- an updated translation in Spanish-Spain (ES) by Oxer
NEW RELEASE: FredoTools v2.0a - 18 Jun 14
FredoTools 2.0a is a release for
MoveAlong v1.2,
DrawAlong v1.1.See main post of this thread for Download.
NEW RELEASE: FredoTools v2.0b - 07 Jul 14
FredoTools 2.0b is a release fixing a bug in MoveAlong (signaled by dedmin)
Since the beginning of language files 2.0A, there has been a lot of abandoned character, can not be cleared, it can not be translated
What do you mean exactly?
I have been updating all my plugins to 2014, but have been stuck on some error messages. Is there an old file in conflict or is there something in the coding:
Error Loading File Fredo6_!LibFredo6.rb
Error: #<ArgumentError: invalid byte sequence in UTF-8>
C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:inmatch' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in
block (2 levels) in load_from_config'
C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:ineach' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in
block in load_from_config'
C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:inforeach' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in
load_from_config'
C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:inblock in load_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:in
each'
C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1060:inload_all_plugins' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in
load_from_config'
C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:186:instartup' C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:307:in
module:LibFredo6'
C:/Users/Geo/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>' -
Have you updated the actual LibFredo version?
Looks like something in the 'set' is NOT updated to me -
I removed all Fred06 plugins and restarted SU14. I did not get any errors. The I installed LibFredo6 and the errors came back.
The best is to show the file list in your Plugins directory. There is definitely an old file, non converted to UTF8.
I added back all your plugins and now there are no errors. Does FredoTools return an error message when it finds no plugins to manage?
