    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 357.4k Views 109 Watching
      kabezoon
      @sdmitch said:
      @kabezoon said:
      first time it works for me... but now just crush the sketchup, even updating... any help?
      http://www.subeimagenes.com/img/captura-953712.JPG
      All pattern options or just one?
      all patterns, all sizes and all size of faces... its weird 😐
      • tt_suT Offline
        tt_su
        Are you submitting those BugSplats? Did you enter any info in the description or name that we can use to look it up?
          lamandrion
          @ Pixero
          could you share your brick textures? I really like the results of your renders!
          • PixeroP Offline
            Pixero
            @lamandrion said:
            @ Pixero
            There's a link in my first post of this thread. They are in a sub folder of the one (BTW_Textures) they should be in when used by the script.
            (And don't forget to move any textures you DON'T want to use into a subfolder.)
            Might be a good idea to make a shortcut to the plugins folder for easy access since you'll have to move textures in and out.
            • JQLJ Offline
              JQL
              Sdmitch,
              It doesn't work well for me. I've clicked on wood, it assumed default values and the cursor changed to the face picker. I choose the face and it went on creating the floor tiles:
              • I couldn't change parameters at firts;
              • After that I couldn't use the plugin again until I restarted SU
              • After restart the same thing problem started all over.
              I hope this is a minor fix, because this is big for arch viz. If you need a video showing the steps, I'll reproduce them as they were consistently repeating.
              Thank you,
              JQL
              www.casca.pt
              Visit us on facebook!
              • Rich O BrienR Online
                @Sam
                I made some changes to your account privilelges.
                You can now visit plugins.sketchucation.com
                • sdmitchS Offline
                  sdmitch
                  @rich o brien said:
                  @Sam
                  Thanks Rich. Maybe I'll have this plugin done someday.
                  http://sdmitch.blogspot.com/
                  • sdmitchS Offline
                    sdmitch
                    @jql said:
                    Sdmitch,
                    Thank you,
                    JQL
                    I think you had better do the video for me. Also, please provide info on your operating system, SketchUp version, and plugin version you are using.
                    • sdmitchS Offline
                      sdmitch
                      I wish I could help you, but I don't have a clue. It has to be a something unique to you and not a common problem. What version of SketchUp are you using? Are you using a Mac or PC?
                      • JQLJ Offline
                        JQL
                        Here you go,
                        I thought this sort of info would show up in the forum (it used to):
                        • SU 2014;
                        • Windows 7;
                        • Last plugin version. The first one seemed fine.
                        I can't embed the video here so it's attached.
                        Thanks again,
                        JQL
                        2014-05-06_1436.swf
                        www.casca.pt
                          cuttingedge
                          Hi SD Mitch..Excellent , excellent , plugin, wow...this will be very useful. There are two things though. How do you control the magnitude of the imperfections. For example in the wood type, the imperfections( like the levels )are a bit to strong.
                          The other thing is, in reality when tiles are set they are not perfectly leveled in Z , it will be most evident when you see the reflection of objects in aglossy floor. Is it possible to randomly rotate each by its center axis say about .2 to .5 degree in both x & y?
                          This might be too much to ask.. Otherwise hey, I can do it manually...Thanks for the wonderful plugin...
                          • sdmitchS Offline
                            sdmitch
                            @jql said:
                            Here you go,
                            • SU 2014;
                            • Windows 7;
                            Thanks again,
                            JQL
                            Since you had used a previous version, the problem may be a conflict in the stored defaults. I suggest that you select the "Reset" option at the bottom of the pattern list. This will initialize all defaults. Hopefully this will clear up the problem.
                            • sdmitchS Offline
                              sdmitch
                              the "imperfection" is currently limited to a maximum of 1/8"
                              I suppose that could be incorporated into the imperfections. Currently the rotation is around either the x or y axis but not both.
                              • guanjinG Offline
                                guanjin
                                Calculate how many tiles you can achieve it? πŸ‘
                                • JQLJ Offline
                                  JQL
                                  Thanks that solved it!
                                  www.casca.pt
                                  • Z Offline
                                    Zacchia
                                    Many thanks for this plugin!! I tried to install it with the Plugin Store but there I could not find it. Are not all plugins listed there? I mean I could install it but I was just wondering...
                                    • KrisidiousK Offline
                                      Krisidious
                                      All plugins are not in the store... just a heck of a lot of them. some are in the warehouse and then some others are on people's websites and then some others are just small things buried in forums and various author's computers.
                                      By: Kristoff Rand
                                      • Z Offline
                                        Zacchia
                                        Thanks for answer!
                                          Because this tool is 'work-in-progress', its author [Sam] has opted not to put it into the PluginStore just yet.
                                          When he has sorted out any 'beta' issues I'm sure it'll become available there as an RBZ in due course.
                                          At the moment it's available in the first post as an RB file, which needs downloading and manually placing into the default SketchUp Plugins folder.
                                          If you have the SketchUcation PluginStore toolset Plugin installed then it has is a submenu option to find and open the Plugins folder.
                                          If you are using < v2014 on PC you need to ensure that you have FULL security permissions to read/write to the Plugins folder - there is a Tutorial about fixing those, accessed from the menu above...
                                          • N Offline
                                            notareal
                                            Nice work so far! I am sure that when released as "final" this will be a hit.
                                            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
