    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 433.5k Views 109 Watching
    • JQLJ
      JQL
      @sdmitch said:
      I think you had better do the video for me. Also, please provide info on your operating system, SketchUp version, and plugin version you are using.
      Here you go,
      I thought this sort of info would show up in the forum (it used to):
      • SU 2014;
      • Windows 7;
      • Last plugin version. The first one seemed fine.
      I can't embed the video here so it's attached.
      Thanks again,
      JQL
      2014-05-06_1436.swf
      www.casca.pt
      Visit us on facebook!
      • C
        cuttingedge
        Hi SD Mitch..Excellent , excellent , plugin, wow...this will be very useful. There are two things though. How do you control the magnitude of the imperfections. For example in the wood type, the imperfections( like the levels )are a bit to strong.
        The other thing is, in reality when tiles are set they are not perfectly leveled in Z , it will be most evident when you see the reflection of objects in aglossy floor. Is it possible to randomly rotate each by its center axis say about .2 to .5 degree in both x & y?
        This might be too much to ask.. Otherwise hey, I can do it manually...Thanks for the wonderful plugin...
        • sdmitchS
          sdmitch
          @jql said:
          Here you go,
          • SU 2014;
          • Windows 7;
          Thanks again,
          JQL
          Since you had used a previous version, the problem may be a conflict in the stored defaults. I suggest that you select the "Reset" option at the bottom of the pattern list. This will initialize all defaults. Hopefully this will clear up the problem.
          http://sdmitch.blogspot.com/
          • sdmitchS
            sdmitch
            the "imperfection" is currently limited to a maximum of 1/8"
            I suppose that could be incorporated into the imperfections. Currently the rotation is around either the x or y axis but not both.
            • guanjinG
              guanjin
              Calculate how many tiles you can achieve it๏ผŸ ๐Ÿ‘
              • JQLJ
                JQL
                Thanks that solved it!
                www.casca.pt
                • Z
                  Zacchia
                  Many thanks for this plugin!! I tried to install it with the Plugin Store but there I could not find it. Are not all plugins listed there? I mean I could install it but I was just wondering...
                  • KrisidiousK
                    Krisidious
                    All plugins are not in the store... just a heck of a lot of them. some are in the warehouse and then some others are on people's websites and then some others are just small things buried in forums and various author's computers.
                    By: Kristoff Rand
                    • Z
                      Zacchia
                      Thanks for answer!
                        Because this tool is 'work-in-progress', its author [Sam] has opted not to put it into the PluginStore just yet.
                        When he has sorted out any 'beta' issues I'm sure it'll become available there as an RBZ in due course.
                        At the moment it's available in the first post as an RB file, which needs downloading and manually placing into the default SketchUp Plugins folder.
                        If you have the SketchUcation PluginStore toolset Plugin installed then it has is a submenu option to find and open the Plugins folder.
                        If you are using < v2014 on PC you need to ensure that you have FULL security permissions to read/write to the Plugins folder - there is a Tutorial about fixing those, accessed from the menu above...
                        • N
                          notareal
                          Nice work so far! I am sure that when released as "final" this will be a hit.
                          • sdmitchS
                            sdmitch
                            Floor Generator has been moved to the Plugin Store.
                            • guanjinG
                              guanjin
                              The plug-in is perfect, but unfortunately does not support Chinese language ๐Ÿ˜’
                              • OxerO
                                Oxer
                                ~~There is a conflict with offset.rb required for Protude.rb, the next Patterns don't work:
                                • Irregular Polygons
                                • HopScotch3
                                • I_Block
                                  The rest of patterns work fine.~~
                                Another question, is it possible give support to translate the plugin?
                                EDIT: I found a version of offset.rb that it isn't conflict with Floor Generator.
                                • sdmitchS
                                  sdmitch
                                  • HopScotch3
                                  • I_Block
                                  I can't see how Floor Generator could ever have a conflict with offset.rb since I use a method of my own creation to do the offsets and every pattern uses the same offset method.
                                  I have no ability or plans to do any translations of the plugin.
                                  • OxerO
                                    Oxer
                                    Thanks for the reply.
                                    • tt_suT
                                      tt_su
                                      I think offset.rb modifies core classes which breaks plugins.
                                      • O
                                        Openspaces
                                        Thank you so very much, very useful Plugin. ๐Ÿ‘
                                        • sdmitchS
                                          sdmitch
                                          Shortly after finding and using offset.rb, it was pointed out that that could be a potential problem so I did away with the class and just used it as a method. The first versions of Floor Generator used this offset method until I tried to add the Herringbone pattern. It failed apparently because the way the faces are arranged it cause multiple edges to be reversed in the face and it couldn't handle that. So I had to create my own version.
                                            azumayugo
                                            hi,
                                            i've used your script for several times, it's nice and run well. But suddenly, the script didn't load. When I check ruby console, it show some error message like this :
                                            Error: #<NoMethodError: undefined method to_l' for nil:NilClass> C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:89:in dialog'
                                            C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:63:in initialize' C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:33:in new'
                                            C:/Users/Design/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:33:in block in <top (required)>' -e:1:in call'
                                            What should I do to make the script run again?
                                            Thank's before
                                            • 16
                                            • 17
                                            • 4 / 17
