    [REQ] List of 2014 incompatible plugins
    14 Posts 9 Posters 964 Views 9 Watching
    • john2J Offline
      john2
      Hello
      Is there anywhere list of 2014 version incompatible/unstable plugins available?
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        driven
        No,
        that's a bit like requiring a list of uncaught fish in the ocean...
        • tt_suT Offline
          tt_su
          Extension Warehouse has a 2014 filter. Some plugins that aren't marked will probably work, but those explicitly marked should have been tested and verified to work.
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            Some of Didier Bur's plugins are not yet compatible with 2014.
            • john2J Offline
              john2
              aaaaaaaaah! Why isn't didier concerned about it man! 😠
              • jeff hammondJ Offline
                life is different for him now than it was when he originally wrote the plugins?
                • tt_suT Offline
                  tt_su
                  I haven't seen him being active for a long time. It's something that often happen to freeware developers - as they usually spend their little extra time for these types of projects.
                    I suggested this to you before. Maybe if you offer to pay him for some of his time, he'd fix up the plugins you want. He's probably got things going on that are more important than fixing up some old Ruby scripts.
                      jiminy-billy-bob
                      Or he could share unscrambled versions of his plugins so that other authors can fix them. (It's usually minor issues easily fixed)
                        driven
                        all of the ones I use aren't scrambled, they're binary...
                        you can convert and edit them, but only for yourself without the authors consent...
                          jiminy-billy-bob
                          Oh ok. I looked only at UCS Manager, Compo Spray, and Layer Manager. These three are scrambled.
                          • W Offline
                            wahoowetzel
                            This is my current list of plugins that don't work in 2014. Obviously, the list is limited to what I've been using, so it's by no means comprehensive.
                            • BoxB Offline
                              And most if not all of that list simply means you haven't installed the newest versions that work with 2014.
                                Moving files over from an earlier version is a recipe for errors...
                                If you get the latest versions of Plugins [from the PluginStore/EWH], then most of the ones you list should be v2014 friendly.
                                For example Fredo's tools are all compliant as far as I know, so the far superior RoundCorner would replace the ancient BZRoundEdge ?
                                Fredo's ToolsOnSurface covers many of the others you listed, as does his newer JointPushPull...
                                I also know that TT's Cleanup is also made v2014 compliant.
                                Remember also to get the latest Lib's for TT & Fredo's tools...
                                Shapes.rb was also updated by the su_ team and is available from the EWH.
                                The only one which I don't know of regarding v2014 compatibility/updates is CADspan's πŸ˜•
