    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 461.3k Views 109 Watching
    • sdmitchS
      sdmitch
      @oxer said:
      Thanks you very much for this useful plugin!! πŸ‘
      It works perfectly on Mac & SU2014. One question, the Row2Row Offset for Brick is 0.5 by default when you use mm units, I changed to 50 in line 69 of the rb file.
      @defaults=["Corner","0","Current","Yes","Yes","50","No","No","0","No","No","30","150","50","12","6","3"] if @@opt=="Brick"
      Thanks for pointing that out. Originally I was using a fraction(0.5) instead of a %. Once it is corrected from within the plugin and Update is clicked, that should take care of it.
      @pixero said:
      I think you forgot to say that if you place a folder called BTW_Textures in your plugin folder and choose use Apply material: Rand_Tex it will use all textures in that folder.
      Thanks Pixero for the info and Textures πŸ‘
      Another question, what units uses the Texture Size, mm, inches or pixels?
      What ever units you are using in the model, either mm or inches. The API says inches but mm seemed to work for me.
      http://sdmitch.blogspot.com/
      • OxerO
        Oxer
        I use metric units in my models for that, I suppose the Texture Size it will expressed in mm, is it so?
        The Options Window is a bit little on Mac, I changed the window hight to 530 so I can see all options.
        @@dlg=UI::WebDialog.new("FloorGenerator", false,"BTW",300,530,10,10,true)
        • OxerO
          Oxer
          I have created a icon for the plugin.
          Floor Generator Icon
          Icons FloorGenerator
          • KrisidiousK
            Krisidious
            Can we get something like this as a pattern?
            Can you show us some patterns to build for you? let us help.
            3D_Hatching_LedgeStone.skp
            By: Kristoff Rand
            • sdmitchS
              sdmitch
              That pattern is just a bit to random I think. the closest I could get is a random length, width and thickness using the wood pattern
              • pbacotP
                Still after the holy grail, ay Kris? lol. I am trying to figure out how to do a stone wall surface (with SU hole punch components for windows etc.) and make some sort of detail at the corners that suggests the stone profile...
                That's not bad sdmitch Should keep looking at it!
                • KrisidiousK
                  Krisidious
                  lmao... And I will have it.
                  By: Kristoff Rand
                  • KrisidiousK
                    Krisidious
                    That looks pretty dame good sdmitch... if I had used a better tiling texture it would look better.
                    By: Kristoff Rand
                    • rvizR
                      rviz
                      1. inconsistent grid origin\rotation (tried on simple cube, see pic.1)
                        By design, the plugin aligns the pattern length with the longest edge of the face picked. In this case, I would undo and redo the face with 90 rotation selected.
                      After 90 rotating the tool takes origins randomly: sometimes it's the upper corner, sometimes the lower one.
                      But the most important: is there place for code optimization? It takes approx 5 min to put 2k tiles (to do it manually would take may be 0.5 min πŸ˜• ).
                      • sdmitchS
                        sdmitch
                        As with any plugin, if you can do it faster manually, then don't use the plugin.
                        If you are using Corner origin, the corner closest to the point on the face that you pick will be used.
                        • zieiosZ
                          zieios
                          love it.... πŸ‘
                          • EarthMoverE
                            EarthMover
                            Drooling. I've been hoping for this for a long while. Thanks Sam. Brilliant work! πŸ‘
                            Content Creator at Skapeup
                            • sdmitchS
                              sdmitch
                              Yet another update!!!
                                This should be available in the SCF PluginStore...
                                Is it now 'stable' enough to be added ?
                                • sdmitchS
                                  sdmitch
                                  Perhaps not just yet. There will probably more pattern options added in the near future.
                                  Is there a way for me to add it to the plugin store or do you have to do that?
                                  • TandemT
                                    Tandem
                                    @sdmitch said:
                                    ...Is there a way for me to add it to the plugin store or do you have to do that?
                                    There really should be a page or topic that explains the process of adding a plugin to the SketchUcation Plugin Store. I have searched the whole site, but could not find anything. Would be useful for developers and end users.
                                    • K
                                      kabezoon
                                      first time it works for me... but now just crush the sketchup, even updating... any help?
                                      http://www.subeimagenes.com/img/captura-953712.JPG
                                        mustafa1972
                                        Hi Pixero
                                        How can I use BTW_Textures textures.
                                        I have copy the file in to the plugin folder
                                        but it dont work.
                                        • sdmitchS
                                          sdmitch
                                          This plugin is still very much a work in progress. We will try to address all suggestions as time permits.
                                          • sdmitchS
                                            sdmitch
                                            All pattern options or just one?
                                            • 16
                                            • 17
                                            • 2 / 17
