    Can I have a Gripes & Bitchin' for Su 2014 thread?
    102 Posts 37 Posters 15.3k Views 37 Watching
      Bruce Watt
      I purchased Bonzai 3D when it first came out thinking it was the way to go. I have upgraded to version 2 and 3.2. I am sure Formz is a great program and was tempted to upgrade to Formz thinking it may iron out some of my gripes with Bonzai 3D but did not. I then discovered SU plugins that gave me all the capability I needed coupled with the easy base functions known within Sketchup and a community that can write code that can probably satisfy most users. I have not used Bonzai for any project yet and i can not see myself doing so. Sorry this was not a bitch or a gripe.
      SKUP PRO 2021 latest version / update
      Windows 10 Pro
      Dell Alienware Aurora R10 AMD
      AMD Ryzen™ 9 3900X
      NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
      • arail1A Offline
        arail1
        @jeff hammond said:
        fwiw, i'm constantly bumping into people using sketchup in their work.. as in, most of the architectural, engineering, landscape design, production firms i collaborate with on per project basis have sketchup and we'll often share files/ideas through sketchup (even though it may not be either of our main software).. a few of the firms are using sketchup as their main software.
        Increasingly, when I send out SU files, I get SU files back. What I mean by that is a lot of the work that I do is shop drawings for contractors, millwork companies, etc. The majority of that work is done in AutoCAD LT (although I'm migrating my 2D drafting to Rhino). I send the drawings to the contractor and they pass them along to the architect who sends back red lines for revisions. Sometimes, to clarify a point, I'll send along a SU to show a detail in question in 3D. Almost as a rule now, the architect responds with a SketchUp reply. That wasn't true a couple of years ago but now it's almost standard. It's like once I've established that SketchUp is a acceptable means of communication, the architects dump their Revit, MAX and whatnot in favor of SU to communicate with me. And the work goes faster.
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          @valerostudio said:
          So a whole bunch of plugins do not work with 2014 and this is pissing me off.
          Maxwell, Vali Architects Instant scripts, Compo Sprayer???
          Was there really no way of making the old ruby scripts work regardless of the Ruby 2.0 changes? Cmon man! WTF 2014!!!!!
          A lot of softwares break plugin compatibility with new versions. SU was spared until now, but it's more like an exception.
          So yeah, a little patience is requiered until the remaining 10% plugins get a compatible version, but sometimes this kind of change is really worth it.
          It's not like SU2013 was suddenly broken, you can still work.
          • tt_suT Offline
            tt_su
            There really wasn't. Ruby 1.8 have reached end of life long ago and 1.9 is heading that way. Ruby 2.1 has already been released and Ruby 2.2 is due next Christmas.
            Ruby 1.8 to Ruby 1.9 was the biggest change as the Ruby interpreter changed their core to a new one. There was no way for us to avoid plugins breaking as the development of Ruby isn't done by us.
            The reason we updated was many. One of the biggest reasons was that Ruby 1.8 had no Unicode support so a large potion of our international user base experienced problems regularly unless they took extra care to use only English characters.
            Another issue was that due to the lack of Unicode support we could not move the Plugins folder out of Program Files. This caused a number of security permission issues with plugins that haunted many users.
            For SketchUp 2014 we included more developers than ever before in the testing. We even had an alpha testing phase so developers could get in early to update their plugins. Unfortunately there is always someone who we missed to invite and even of the ones we invited not everyone had gotten around to update.
            I think extensions warehouse is at ~65% 2014 compatibility - though I suspect there real number is higher, it's just that some developers haven't updated their information yet.
            It's unfortunate that extensions broke, but it really was a damned if we do, damned if we don't situation and going with the Ruby 2.0 upgrade was really the only way to move forward.
            The lack of updates to the SketchUp Ruby API under the Google area gave a good stability for end users, but not good for developers in terms of lacking features. Eventually we had to do this, but it's not something we anticipate would happen often. It looks like the Ruby 2.x branch is being kept backwards compatible - which should allow us to keep up to date with Ruby while at the same time not breaking extensions.
            • PixeroP Offline
              Pixero
              I was hoping for a tabbed plugin menu system where you could customise and organise plugins under different tabs depending on usage.
              That way you would also have more screen for modeling.
                kaas
                Could it be the 'large tool set' is less than 2 columns wide?
                I try to put some icons in 2 columns under the large tool set and whatever I do I always end up with 3 columns. If I remove the large toolset it's fine but as soon as I put it back... 3 columns.
                edit: also tried making a custom 2 column toolbar but as soon as I dock it, it reverts to a long one-column toolbar again.
                • FrederikF Offline
                  Frederik
                  That's a great idea, Jan... 👍
                  Have you written it up as a wish/feature request...?
                  Cheers
                  Kim Frederik
                  • jason_marantoJ Offline
                    jason_maranto
                    I have to laugh, I found this in my inbox this morning:
                    http://www.formz.com/email/formz8betaannouncment_4_15_2014/formz8betaannouncement1.html
                    They "get" it.
                    • HieruH Offline
                      Hieru
                      It's got to be said, that's the kind of progressive attitude I would like to see from the SU devs.
                      Sure you can do a lot of those things with plugins and I particularly love subD modelling in SU, but it would be great if we could see some sign that SUs native tools will grow to meet the needs, advancement and expectations it's users.
                      Put it another way, if all the plugins were to disappear overnight and you could only use native SU tools, how many of us would continue to use Sketchup? My guess would be 'very few' and both Trimble and John Bacus should find that very worrying.
                      The flip side of that is, how happy would you be to use software that has a pretty good range of native tools but offers very little room for expansion via plugins? It's swings and roundabouts really, but I think that the Sketchup way of doing things is probably the better option, but I don't think that means we should accept what comes across as a stagnation in the development of Sketchup.
                      Maybe some of the people who've been to this year's Basecamp will have a better perspective on what we can expect from Sketchup in the future.
                      www.davidhier.co.uk
                      • N Offline
                        numerobis
                        where is subD modeling in sketchup?!?
                        • HieruH Offline
                          Hieru
                          Artisan 😉
                          It's not 'proper' subD and no quads, but I'd struggle without it. How else can you do something like fillet the corner on a right-angle tube joint (which should be very simple)?
                          www.davidhier.co.uk
                          • N Offline
                            numerobis
                            sorry... i couldn't resist 😉
                            I knew it would be Artisan - but as you said, real subd is something different... and it's really sad that sketchup still doesn't support it. 😞
                            • HieruH Offline
                              Hieru
                              Yes I agree, but although I consider it essential I suspect that the devs do not. With the average user in mind I don't think subD is something they will ever need or even be on their radar.
                              Even if you only look at professionals working mostly on architectural projects, subD or Artisan won't come in useful - unless you need to subdivide faces for displacement (now that function should deffinately be an essential part of the sandbox toolset).
                              www.davidhier.co.uk
                              • 5 / 6
