    Cutting Boolean
    18 Posts 5 Posters 1.1k Views 5 Watching
      robertWan
      I don't know how to cut with that green in the red. Plugin OSCoolean doesn't work with my objects. Perhaps too complex.
      That green is a routers trail, which is to choose material in the red (door).
      Somehow I made that cut (purple door) by scaling selected edges, but it isn't precise.
      Does someone have an idea how to make such complicated cuts?
      Robert
      front fala uchwyt.skp
        Robert
        it's too small (or- the some of the individual segments in the round-overs are too small..
        scale it up 10x or so.. afterwards, you can scale it back down to proper size
          robertWan
          @jeff hammond said:
          scale it up 10x
          Run, but error.
          Robert
          • TIGT Online
            Try scaling x100.
            Do the cut.
            Then scale back down.
            This is a well known issue...
            The original has some edges <~0.5mm long - these are likely to produce issues because SketchUp's tolerance is 1/1000th inch, so it presumes points closer that that are coincident, the edge isn't made, so the face isn't either...
              oh. right-- I forgot you're using a different plugin. I tried with solid tools and it worked fine.
              I'm not familiar with oscoolean.
                robertWan
                Those built in SU Pro?
                I tried x100 and x1000, but the plugin doesn't react at all, or artifacts appear.
                http://www.screencast.com/t/k2lOEnw9J
                (how do I attach links witch a film) Insert Flash doesn't work.
                RObert
                  Did you try the native Intersect Faces? It works fine for me.
                    robertWan
                    OSCoolean or Solid Tools (SU Pro)?
                    Robert
                      cotty
                      my SketchUp gallery
                        robertWan
                        YES!
                        10x magnitude objects.
                        Intersect Faces With Selection
                        Erase, erase, erase, erase... πŸ˜„
                        Works, thank you.
                        Robert
                          robertWan
                          First test on MDF.
                          Robert
                          Furniture door handle
                            Robert
                            Yes. What Carsten said.
                            You'll note in the SKP file I posted, your group is inside a component. I initially made a nested component of your cutter and the panel. Then I did the same thing I've shown many times; I copied the component, scaled up the copy (I used a scale factor of 1000 but 100 probably worked fine), and did the intersection and erasure of the unwanted bits. When I was satisfied things were cleaned up correctly and face orientation was correct, I closed the component to get out of edit mode and deleted the giant copy. No need to scale back down and potentially have to worry about getting the original component in the proper location.
                            I should have exploded your group to leave the panel a simple component but I didn't do it before uploading the file.
                            The MDF looks good that way. What finish do you put on these panels? How durable is the cut edge?
                              robertWan
                              But do you scale down a copy before erasing it?
                              Izolant - Primer - Topcoat (I'm not sure about english name for it)
                              Edges after painting is durable enough. Izolant hardens MDF well. It has the consistency of water, it penetrates deep and hardens. For MDF hardening I use an izolant for wood. Not for MDF.
                              Robert
                                No. There's no need for scaling down. I start with a component, make a copy and scale that copy up. The original remains where it is and at its normal size. I work on the scaled up copy and because I'm working on an instance of the component, the same things get done to the original. This doesn't work if you use groups, though.
                                Robert
                                I see. I wonder if we have access to something like that here.
                                  robertWan
                                  Do not understand something. When prescaling copy at the same time scaling original.
                                  http://www.screencast.com/t/owYqxIwxyBi
                                  http://icaamerica.biz/isol.php
                                  I use IS207
                                    Do not open the copy of the component before scaling.
                                    Do you know about using the Move tool to make copies?
                                    Thanks for the info on the "stuff".
                                      robertWan
                                      It's so obvious ... now
                                      Yes. I wanted you to see what I click.
                                      Robert
                                        πŸ‘ πŸ‘
