    [Plugin] Shortcutter Beta
    98 Posts 14 Posters 53.9k Views 14 Watching
      OK, so this tool is failing in SU2013. Sorry, we will look at a fix. In the meantime try it in SU2014 or v8
      • BoxB
        Works in 2013 and 2014 for me.
        • cottyC
          cotty
          Great!
          Does the GIF shows a different version?
          I've found it here (as described in the plugin store)...
          my SketchUp gallery
            It does, because the .gif was an alpha when the initial idea was the place it in the Window menu.
            • T
              TECHDAVE02
              I don't get an option in the window menu
                See SketchUcation Tools menu
                • T
                  TECHDAVE02
                  Thanks got it
                    Very nice. And it looks great cosmetically. Is it possible to save the page as an HTML file? I tried right clicking on it but don't get a Save or Save as... option.
                    • G
                      GĂĄbor
                      No, not in the current version. For what purpose would you use that? If for printing out maybe a .pdf would be better which might be in some of the next versions if needed. (Well, Ctrl+P does the printing job until it is implemented...)
                        It prints nice too but over a couple of pages
                          Not specifically for printing but possibly for including in a tutorial or other web page about using SketchUp. It's too large to get into a single screen shot so I was thinking maybe I could work from the HTML page.
                          • G
                            GĂĄbor
                            The problem with the HTML is: As this webdialog uses loads of .css stuff (created by Rich) you couldn't do anything with the .html even if you could download it without the corresponding .css files.
                              We'll do something bespoke for you Dave.
                              • N
                                numerobis
                                Nice one! Thanks! 😄
                                  @techdave02 said:
                                  Had an error see jpeg
                                  Your screenshot shows an error when SketchUp tries to load a file that does not [or at least should not!] exist đŸ˜Č
                                  Here is my theory on what happen... đŸ€“
                                  You downloaded the shortcutter_v0.1.0.rbz archive for the Plugin from the PluginStore's web-page.
                                  You did NOT install it using the v2013 Preferences > Extensions > Install... button.
                                  But [for some reason which only you can explain] you renamed it as shortcutter_v0.1.0.rb and then you just put it into your v2013 Plugins folder 😒
                                  So when SketchUp.exe v2013 tried to load that file it could not because it is NOT a Ruby file - the \003 is a binary character found early in the .rbz archive [actually a .zip renamed] 😼
                                  So the first thing to do is remove that fake .rb file from the v2013 Plugins folder.
                                  Say onto your Desktop.
                                  You can rename it with its final 'z' again.
                                  Now use v2013 Preferences > Extensions > Install... button, find the correctly named .rbz and it'll get installed properly for you where it should be.
                                  You need to restart SketchUp to effect the full integration of the addon into the SketchUcation Toolset/submenu...
                                  Alternatively, since this addon only works if the SketchUcation Toolset is installed. then you could use the SketchUcation PluginStore dialog to AutoInstall the addon directly, without even worrying about the RBZ at all...
                                  Remember that you will still need to restart SketchUp to effect the full integration of the addon into the SketchUcation Toolset/submenu...
                                    Just in case some of you think that this tool doesn't work in v2013... I can assure you that it works just fine in version 8/2013/2014.
                                    I have successfully tested it in all versions. đŸ€“
                                    The comment added to the original post was following some spurious results - user-error rather than anything inherent in the code...
                                      driven
                                      @tig said:
                                      I have successfully tested it in all versions. :geek:
                                      and mac?it's nice and clean, almost minimalist...
                                      EDIT: I do have shortcuts, but maybe it's a encoding issue...
                                      Note. "§\t/Plugins/Key Scene/Key Scene 1",
                                      Sketchup.get_shortcuts.sort
                                      ["A\tselectArcTool;", "B\tselectPaintTool;", "C\tselectCircleTool;", "D\tselectDimensionTool;", "E\tselectEraseTool;", "F\tselectExtrudeTool;", "G\tmakeComponent;", "H\tviewShowHidden;", "K\t/Plugins/Keyboard Shortcuts", "L\tselectLineTool;", "M\tselectMoveTool;", "O\tselectOffsetTool;", "P\tselectPushPullTool;", "Q\tselectRotateTool;", "R\tselectRectangleTool;", "S\tselectScaleTool;", "Space\tselectSelectionTool;", "T\tselectMeasureTool;", "U\teditUnlockSelected;", "V\ttoggleHideRestOfModel;", "W\t/Plugins/Weld", "Z\tselectZoomTool;", "§\t/Plugins/Key Scene/Key Scene 1", "⇧A\t/File/Export/Animation...", "⇧E\t/File/Export/2D Graphic...", "⇧P\tviewParallelProjection;", "⇧R\t/Draw/Rotated Rectangle", "⇧S\t/File/Export/Section Slice...", "⇧T\ttogglePageTabsDsiplay;", "⇧V\tpasteInPlace;", "⇧Z\tviewZoomExtents;", "⌃S\tsaveCopy;", "⌃⌄⇧T\tviewTop;", "⌄B\torderFrontColorPanel;", "⌄M\t/Plugins/Mirror Selection", "⌄T\tdoThreeDText;"]
                                      • G
                                        GĂĄbor
                                        Could you please try to cache-erase reload the contents of the webdialog? (Ctrl+F5 in Winows browsers, I do not know Mac) Does it help?
                                          driven
                                          It's not that simple on a mac...
                                          There are three different caches involved in WebKit on Mac OS X.
                                          A) The resource cache in the NSURL networking layer, which caches both in memory and on disk.
                                          B) The resource cache inside WebCore, which caches in memory.
                                          C) The page cache in WebCore, a higher level cache which only affects "go back" and "go forward" commands.
                                          they aren't the easiest to erase...
                                          besides you already have
                                          Pragma; no-cache
                                          Cache-Control; no-cache
                                          which are the two sure-fire ways of not cacheing...
                                          On the surface it looks like Sketchup may have broken get_shortcuts, which I'm assuming is being used for the harvest...
                                          • G
                                            GĂĄbor
                                            TIG Tested it with MAC and it worked for him. My suspition - and that's why I asked for a re-load - is that we have again some problem with the asynchronous nature of MAC running javascript. Of course I'm not sure in it as I have no chance to test it on MAC but we have run into this async/sync problem several times with the SketchUcation tools during the dev.
                                            Anyhow thank you for testing/noticing/explaining. Let's wait for TIG if he has any idea,
                                            • 1 / 5
